Topic: Unipolar stepper - one direction (Read 447 times) previous topic - next topic
ifugaopapercraft
Is this sketch the most direct method to run a unipolar stepper in one direction? Using the stepper library would seem to involve less code but I haven't been successful using it for a single direction.
int motorPin1 = 8;
int motorPin2 = 9;
int motorPin3 = 10;
int motorPin4 = 11;
int delayTime = 10;
pinMode(motorPin1, OUTPUT);
pinMode(motorPin2, OUTPUT);
pinMode(motorPin3, OUTPUT);
pinMode(motorPin4, OUTPUT);
digitalWrite(motorPin1, HIGH);
digitalWrite(motorPin2, LOW);
digitalWrite(motorPin3, LOW);
digitalWrite(motorPin4, LOW);
delay(delayTime);
digitalWrite(motorPin1, LOW);
digitalWrite(motorPin2, HIGH);
delay(delayTime);
digitalWrite(motorPin3, HIGH);
delay(delayTime);
digitalWrite(motorPin4, HIGH);
delay(delayTime);
larryd
Your code is OK.
Maybe play with the delay.
Do you have a common ground?
Your programming technique will improve as you become more knowledgeable.
What components are you using?
Show us how your motor is wired up, a schematic, a picture.
No technical PMs.
The last thing you did is where you should start looking.
ifugaopapercraft
I should have mentioned the ULN2003 to drive the motors. The sketch above I assume will run the stepper without this chip or the library. Fortunately, I adapted a much shorter sketch which works well. Thanks.
