Hey guys, Im still very new to the world of arduino. For the project I have in mind I picked some parts from sparkfun including a LiPO fuel gauge (links below) and a 3.7v 2000 mah LiPO battery. I tried hooking it up today in multiple ways but couldnt get any data going to my arduino uno. I'm sure I've either got the wiring wrong or just dont know enough about coding yet to be able to see anything. I saw no data on the serial view in the arduino program. I searched online and followed multiple tutorials for similar things but still came up short. If someone could help give me the nudge I need to get going I'll be good to go from there. Ok so heres the links for the gear below:
djunohoo:
How are you trying to wire the 3.7vdc battery to your arduino? The external power connector requires at 6vdc minimum and 7-12vdc is the recommended voltage input.
oh.....well thats definitely good to know, for now im not trying to power the arduino from the battery (and may have to revise my future plans based on what you just told me) but mainly im just trying to get the reading from the fuel gauge to then use the arduino to light up a 10 segment led based on the level of charge the battery has. I think ive got the led portion worked out im just trying to get the data flowing so i can have an output correlating to the data.
* MAX1704* Driver for Arduino *
* Matthew Newberry *
* mattnewberry@me.com *
* This program is free software; you can redistribute it and/or modify *
* it under the terms of the GNU License. *
* This program is distributed in the hope that it will be useful, *
* but WITHOUT ANY WARRANTY; without even the implied warranty of *
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the *
* GNU License V2 for more details. *
#include "Arduino.h"
#include "Wire.h"
#include "MAX1704.h"
MAX1704 fuelGauge;
void setup(){
Wire.begin();
Serial.println("Starting up...");
fuelGauge.reset();
fuelGauge.quickStart();
fuelGauge.showConfig();
void loop(){
float charge = fuelGauge.stateOfCharge();
Serial.println(charge);
just tried the code you posted above, im pretty sure i tried that yesterday too without success, it compiles fine, loads on the uno fine but just nothing happens on the serial monitor, i followed this diagram for physical connections, am i doing something wrong on the physical connections? or do I have to declare something in the code with the a4/a5 ports? thanks for the help guys
yea i dont even get that message, while troubleshooting i thought i shouldve at least seen that, i just tried extracting the serial code and trying that by itself and still nothing on the serial monitor, i havent really done anything with the serial monitor until now so im not really sure what im looking for in troubleshooting this
i tried this on the uno and my micro and no dice on either one, ive barely even used the micro but from watching the LEDS on the board of the micro it looks like its still running one of the blink examples even though it said that it uploaded fine, im not sure whats going on
ok so i went out a bought a brand new arduino uno and tried it...same results with the serial test, what am i doing wrong? heres the serial test code i uploaded
I am having trouble getting the same Fuel Guage running myself. I get output on Serial though. The problem is I always get a value of 255 for the battery percent using the MattNewberry library @BillHo linked to.
I've got 4 sensors and a backlit LCD hooked up to an Arduino Micro powered by an 850mAh battery. I've left it running for a couple hours and I would expect over 2 hours to see at least some drop in the battery percent.
I've read through the data sheet and I have a hunch this is programming related. I also noticed the version reported back is "FF" instead of "0x08" which is defined in the library linked.
Anyone willing to help me trace down what might be going on or have ideas on how I can verify everything is setup address wise in the library / Wire interface code?
djunohoo:
I don't see anything wrong with the code, so I think you're looking for a more fundamental problem.
Have you successfully downloaded any of the example sketches to the Arduino? Have you opened the serial monitor and selected the correct speed as used in your sketch? Do you see the Arduino reset when you open the serial monitor? Do you then see the output from the Arduino in the serial monitor?
