I put the code in the very first post of this thread, but changed it slightly after the suggestion of g_u_e_s_t. So here's what I have so far
#define CONTROL0 5
#define CONTROL1 4
#define CONTROL2 3
#define CONTROL3 2
byte muxarray0[33];
byte muxarray1[16];
pinMode(CONTROL0, OUTPUT);
pinMode(CONTROL1, OUTPUT);
pinMode(CONTROL2, OUTPUT);
pinMode(CONTROL3, OUTPUT);
muxarray0[0] = 0xc0; // denote beginning of data
byte k = 1;
for (int i = 0; i < 16; i++) {
digitalWrite(CONTROL0, (i&15)>>3);
digitalWrite(CONTROL1, (i&7)>>2);
digitalWrite(CONTROL2, (i&3)>>1);
digitalWrite(CONTROL3, (i&1));
unsigned int mod = analogRead(0);
muxarray0[k++] = mod & 0x007f;
muxarray0[k++] = (mod >> 7) & 0x0007; /* I got this from some other sketch. I multiply this by 128 in Pd and then add it to the result of the line of code above this, this way I'm supposed to get a range of 0-1023, cause byte will take only 8bit...
for (int j = 0; j < 16; j++) {
digitalWrite(CONTROL0, (j&15)>>3);
digitalWrite(CONTROL1, (j&7)>>2);
digitalWrite(CONTROL2, (j&3)>>1);
digitalWrite(CONTROL3, (j&1));
muxarray1[j] = digitalRead(A1);
Serial.write(muxarray0, 33);
Serial.write(muxarray1, 16);
This is for two multiplexers in pin 0 and 1, the first one with 16 potentiometers and the second with 16 push buttons. I have also attached the Pd patch where I'm trying to read all the data, in case you're using Pd you could give it a glimpse...I've also attached the patch where I'm testing the bitwise operations, the one I've included in the code above and the one you suggested.
Thanks
