Topic: Gauge controlled with Ajax shows Not A Number error (Read 6298 times) previous topic - next topic
luxxtek
I'm trying to use this gauge  http://www.wwvalue.com/web-design/jquery/pure-javascript-and-html5-canvas-gauge-canvgauge.html
with the webserver code below on the ethernet SD card to display the pool temperature using AJAX
data-onready="setInterval( function() { Gauge.Collection.get('gauge1').setValue(GetPoolTemp());}, 800);"
The first gauge should be displaying 22 (fixed as test) using AJAX but I get a NAN (Not A Number) error.
The second gauge works fine but that is a javascript generated value.
I am new to javascript and could use some help.
sketch and webserver code below
Code: [Select]
<!doctype html>
<html>
<head>
<meta http-equiv="content-type" content="text/html; charset=utf-8">
<title>SD-ARDUINO-WEBSERVER</title>
<script src="http://users.telenet.be/luxxtek/arduino/JS/gauge.min.js"></script>
<script src="http://users.telenet.be/luxxtek/arduino/JS/pooltemp.js"></script>
</head>
<body>
<center>
<h1> 2GB SD-CARD ARDUINO-WEBSERVER </h1>
<canvas id="gauge1" width="200" height="200"
data-type="canv-gauge"
data-title="GENT"
data-min-value="18"
data-max-value="30"
data-major-ticks="18 19 20 21 22 23 24 25 26 27 28 29 30"
data-minor-ticks="2"
data-stroke-ticks="true"
data-units="°C"
data-value-format="2.1"
data-glow="true"
data-animation-delay="10"
data-animation-duration="200"
data-animation-fn="elastic"
data-colors-needle="#f00 #00f"
    data-colors-major-ticks="#fff #fff"
data-colors-plate="#fb0 #aaf"
data-highlights="18 20 #66CCFF, 20 24 #00FF00, 24 28 #FFCC00, 28 30 #FF0000"
></canvas>
<canvas id="gauge2" width="200" height="200"
data-title="ALTEA"
data-min-value="18"
data-max-value="30"
data-units="°C"
data-glow="true"
data-onready="setInterval( function() { Gauge.Collection.get('gauge2').setValue((Math.random() * 1.5) + 25);}, 2000);"
></canvas>
</center>
</body>
</html>
Code: [Select]
  Program:      eth_websrv_SD
  Description:  Arduino web server that serves up a basic web
                page. The web page is stored on the SD card.
  Hardware:     Arduino Uno and official Arduino Ethernet
                shield. Should work with other Arduinos and
                compatible Ethernet shields.
                2Gb micro SD card formatted FAT16
  Software:     Developed using Arduino 1.0.3 software
                Should be compatible with Arduino 1.0 +
                SD card contains web page called index.htm
  References:   - WebServer example by David A. Mellis and
                  modified by Tom Igoe
                - SD card examples by David A. Mellis and
                  Tom Igoe
                - Ethernet library documentation:
                  http://arduino.cc/en/Reference/Ethernet
                - SD Card library documentation:
                  http://arduino.cc/en/Reference/SD
  Date:         10 January 2013
  Author:       W.A. Smith, http://startingelectronics.com
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
// MAC address from Ethernet shield sticker under board
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(10, 0, 1, 53); // IP address, may need to change depending on network
EthernetServer server(80);  // create a server at port 80
String HTTP_req;            // stores the HTTP request
int pooltemp;
File webFile;
    Ethernet.begin(mac, ip);  // initialize Ethernet device
    server.begin();           // start to listen for clients
    Serial.begin(9600);       // for debugging
    // initialize SD card
    Serial.println("Initializing SD card...");
    if (!SD.begin(4)) {
        Serial.println("ERROR - SD card initialization failed!");
        return;    // init failed
    Serial.println("SUCCESS - SD card initialized.");
    // check for index.htm file
    if (!SD.exists("index.htm")) {
        Serial.println("ERROR - Can't find index.htm file!");
        return;  // can't find index file
    Serial.println("SUCCESS - Found index.htm file.");
    EthernetClient client = server.available();  // try to get client
    if (client) {  // got client?
        boolean currentLineIsBlank = true;
        while (client.connected()) {
            if (client.available()) {   // client data available to read
                char c = client.read(); // read 1 byte (character) from client
                HTTP_req += c;  // save the HTTP request 1 char at a time
                // last line of client request is blank and ends with \n
                // respond to client only after last line received
                if (c == '\n' && currentLineIsBlank) {
                    // send a standard http response header
                    client.println("Content-Type: text/html");
                    client.println("Connection: keep-alive");
                    client.println();
                    // AJAX request for pool temp
                    if (HTTP_req.indexOf("pool_temp_switch") > -1) {
                        // read pool temperature (and send appropriate paragraph text causes NAN)
                        GetPoolTemp(client);
                    // send web page from SD card
                    webFile = SD.open("index.htm");        // open web page file
                    if (webFile) {
                        while(webFile.available()) {
                            client.write(webFile.read()); // send web page to client
                        webFile.close();
                    // display received HTTP request on serial port
                    Serial.print(HTTP_req);
                    HTTP_req = "";            // finished with request, empty string
                // every line of text received from the client ends with \r\n
                if (c == '\n') {
                    // last character on line of received text
                    // starting new line with next character read
                else if (c != '\r') {
                    // a text character was received from client
                    currentLineIsBlank = false;
            } // end if (client.available())
        } // end while (client.connected())
        delay(1);      // give the web browser time to receive the data
        client.stop(); // close the connection
    } // end if (client)
// send the temperature to the web browser
void GetPoolTemp(EthernetClient cl)
            cl.print(22);
Arduino leren ? ArdLab Gent - Lid van de STEM-Academie - www.ardlab.gent
robtillaart
no javascript expert either, but I think the number is send as a string and the receiving javascript expects a number.
So you should either do cl.write(22) ;  to send it binary
or better do a "string2int" conversion on the receiving end.
you can test this by making the ajax field a string type and check this
<disclaimers all=true />
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
billroy
Unless I'm mistaken, this javascript code, which runs in the browser, is trying to call GetPoolTemp(), a function from the Arduino C code.  Which isn't possible, right?
Code: [Select]
Is the intention to send the actual temperature as part of the data-onready attribute?  If so, you'll need to call GetPoolTemp() on the Arduino and insert its value into the page you send somehow.
-br
robtillaart
- http://startingelectronics.com/tutorials/arduino/ethernet-shield-web-server-tutorial/web-server-read-switch-automatically-using-AJAX/ -
shows a working version with strings
Rob Tillaart
luxxtek
Hi everybody,
I just got the input from my personal expert/friend/ex-collegue Ward (he is a genius) and he solved it.
I also contacted the canvgauge guy to solve a small remaining problem and it works fine.
Too late to post the code now but I will clean it up and post it tomorrow.
Thanks a lot.
luxxtek
This is the code for the index.htm file on the SD card
Code: [Select]
<!doctype html>
<html>
<head>
<script src="../../gauge.min.js"></script>
<script src="../../pooltemp.js"></script>
</head>
<body onload="GetPoolTemp()">
<center>
<h1> 2GB SD-CARD ARDUINO-WEBSERVER WITH AJAX GAUGE</h1>
<p> Left gauge driven by Arduino counter .1°C interval - Right gauge driven by javascript random number </p>
<br>
data-title="GENT"
data-min-value="18"
data-max-value="30"
data-units="°C"
data-glow="true"
></canvas>
data-title="ALTEA"
data-min-value="18"
data-max-value="30"
data-units="°C"
data-glow="true"
></canvas>
</center>
</body>
</html>
and this is the pooltemp.js file with the AJAX code
The pooltemp.js must be stored in a directory as defined in the index.htm file by the line below
Code: [Select]
function GetPoolTemp() {
nocache = "&nocache=" + Math.random() * 1000000;
var request = new XMLHttpRequest();
request.onreadystatechange = function() {
if (this.readyState == 4) {
if (this.status == 200) {
if (this.responseText != null) {
Gauge.Collection.get('gauge1').setValue(parseFloat(this.responseText));
request.open("GET", "pool_temp_switch" + nocache, true);
request.send(null);
setTimeout('GetPoolTemp()', 1000);
note that you also need to host 2 files:
the gauge.min.js file hosted on the same place
and save the gauge.js on the SD card
all files and the Arduino sketch can downloaded below
meetregel
Hello,
thanks for the "Guages Simple" sample files. Unfortunatly the example doesn't work for me. When I visit the specific webpage I only get two nummeric values (xx.xx), no gauges are displayed. Instead of a Ethernet Shield I'm using the Arduino WiFi shield.
Does somebody know what is going wrong. Can it be caused by the WiFi shield I'm using?
Thanks
shoqa
I tried your sketch and index.htm and also placed gauge.min.js & pooltemp.js on SD card root and modified the path in index.htm
The webpage title changes to "SD-ARDUINO-WEBSERVER" and it also displays:
But unfortunately the Gauge does not show. Could you please let me know what could be the problem.
Any help is very much appreciated.
Thanks.
