Topic: need some help (Read 556 times) previous topic - next topic
altaier
hello everyone, i have a minor problem that i can't solve... maybe you could tell me where i am going wrong...
i am trying to create a digital clock using an arduino uno uc. the clock has to be 00:00:00 form, max being 23:59:59. when the time hits 00:05:10, another 0 appears at the seconds and i don't understand why... i know i could try setting the cursor over that zero and print a space but i don't like the ideea. the zero just stays there.
this is the code i used:
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int s=0;
int m=0;
int h=0;
boolean x=false;
#define LED 13
ISR(TIMER1_OVF_vect) {
  s++;
  if(s==60){
    s=0;
    m++;
  if(m==60){
    m=0;
    h++;
  if(h>23){
    h=0;
  x=!x;
  TCNT1=0x0BDC;
  lcd.begin(16, 2);
  lcd.setCursor(2,0);
  lcd.print(":");
  pinMode(LED, OUTPUT);
TIMSK1=0x01; // enabled global and timer overflow interrupt;
TCCR1A = 0x00; // normal operation page 148 (mode0);
TCNT1=0x0BDC; // set initial value to remove time error (16bit counter register)
TCCR1B = 0x04; // start timer/ set clock
void loop () {
  if(x==true){
    lcd.setCursor(5,0);
    lcd.print(":");
  else{
    lcd.setCursor(5,0);
  lcd.print(" ");}
  seconds();
  minutes();
  hours();
  digitalWrite(LED, x);
  int seconds(){
    lcd.setCursor(6,0);
    if(s<10){
      lcd.print("0");}
      lcd.print(s);
  int minutes(){
    lcd.setCursor(3,0);
    if(m<10){
      lcd.print("0");}
      lcd.print(m);
  int hours(){
    lcd.setCursor(0,0);
    if(h<10){
      lcd.print("0");}
      lcd.print(h);
i tried a lot of methods to get rid of that nasty 0, none worked... someone please explain me why this is happening. Waiting for some feedback. Thank you.
majenko
Please read the stickies at the top of the forum and then re-think the format of your post.
altaier
i re-edited the post with a new title and how it should be, sorry for any inconveniences. this post can be deleted.
nickgammon
He means code tags.
Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the # button above the posting area.
Read this before posting a programming question
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
