Topic: Write register values in code (Read 2357 times) previous topic - next topic
vorkiej
How can I directly write a register value in my code?
For example the PWM_CMR_CPOL (0x1u << 9) change the register value 0 to 1.
// This doesn't work
#define PWM_CMR_CPOL 1;
Markus_L811
That won't work. #define works like a placeholder everywhere the compilers find the term PWM_CMR_CPOL he would replace it with a 1.
Something like this should set the register Value to a 1
PWM->PWM_CMR = PWM_CMR_CPOL;
vorkiej
#2
Mar 25, 2013, 04:30 pm Last Edit: Mar 25, 2013, 04:33 pm by vorkiej Reason: 1
Thanks Markus_L811, that really helped me!
// solution of my problem was (don't forget the channel number!):
PWM->PWM_CH_NUM[6].PWM_CMR |= PWM_CMR_CPOL;
PWM->PWM_CH_NUM[6].PWM_CMR |= (1 << 9);                // or this
// simple test for printing the register values:
void test() {
   uint32_t registervalues;
   registervalues = PWM->PWM_CH_NUM[6].PWM_CMR;
   Serial.println(registervalues,BIN);
// look in the header files for register names, in my case: component_pwm.h  and instance_pwm.h
Markus_L811
Good, but sorry really missed the channelname.
