Topic: I need help with this code... (Read 429 times) previous topic - next topic
AvramIonut
Jun 27, 2015, 02:18 pm Last Edit: Jun 28, 2015, 10:50 am by AvramIonut
Hi everyone,
I've just started to work on a project using EasyVR Shield for Arduino uno Rev3 but i encountered an unexpected error in my code.
I've uploaded a code which is supposed to print in the serial monitor some strings according to my vocal commands.
Can you give me a help and explain me what does thie error means?
Quote
Quote
In file included from C:\Users\Ionut\Documents\Arduino\libraries\NewSoftSerial\NewSoftSerial.cpp:39:0:
C:\Users\Ionut\Documents\Arduino\libraries\NewSoftSerial\NewSoftSerial.h:70:16: error: conflicting return type specified for 'virtual void NewSoftSerial::write(uint8_t)'
   virtual void write(uint8_t byte);
In file included from C:\Users\Ionut\AppData\Roaming\Arduino15\packages\arduino\hardware\avr\1.6.6\cores\arduino/Stream.h:26:0
                from C:\Users\Ionut\AppData\Roaming\Arduino15\packages\arduino\hardware\avr\1.6.6\cores\arduino/HardwareSerial.h:29,
               from C:\Users\Ionut\AppData\Roaming\Arduino15\packages\arduino\hardware\avr\1.6.6\cores\arduino/Arduino.h:223,
               from C:\Users\Ionut\Documents\Arduino\libraries\NewSoftSerial\NewSoftSerial.cpp:37:
Quote
C:\Users\Ionut\AppData\Roaming\Arduino15\packages\arduino\hardware\avr\1.6.6\cores\arduino/Print.h:48:20: error:   overriding 'virtual size_t Print::write(uint8_t)'
   virtual size_t write(uint8_t) = 0;
AvramIonut
Hey guys,
I've started to work on a project using EasyVR and Arduino.
I've uploaded this code...
Quote
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#include "SoftwareSerial.h"
SoftwareSerial port(12,13);
#else // Arduino 0022 - use modified NewSoftSerial
#include "WProgram.h"
#include "NewSoftSerial.h"
NewSoftSerial port(12,13);
#endif
#include "EasyVR.h"
EasyVR easyvr(port);
//Groups and Commands
enum Groups
//GROUP_0  = 0,
GROUP_1  = 1,
enum Group0
G0_ARDUINO = 0,
enum Group1
G1_PLAY = 0,
G1_PAUSE = 1,
G1_PREVIOUS = 2,
G1_NEXT = 3,
G1_STOP = 4,
G1_VOLUME_UP = 5,
G1_VOLUME_DOWN = 6,
G1_MINIMIZE = 7,
G1_MUTE = 8,
G1_FULLSCREEN = 9,
G1_FOCUS_VIDEO = 10,
G1_FOCUS_PHOTO = 11,
G1_CLOSE = 12,
EasyVRBridge bridge;
int8_t group, idx;
// bridge mode?
if (bridge.check())
cli();
bridge.loop(0, 1, 12, 13);
// run normally
port.begin(9600);
if (!easyvr.detect())
Serial.println("EasyVR not detected!");
for (;;);
easyvr.setPinOutput(EasyVR::IO1, LOW);
Serial.println("EasyVR detected!");
easyvr.setTimeout(5);
easyvr.setLanguage(EasyVR::ENGLISH);
group = EasyVR::TRIGGER; //<- start group (customize)
pinMode(2, OUTPUT);
digitalWrite(2, LOW);    // set the LED off
pinMode(3, OUTPUT);
digitalWrite(3, LOW);
pinMode(4, OUTPUT);
digitalWrite(4, LOW);
pinMode(5, OUTPUT);
digitalWrite(5, LOW);
pinMode(6, OUTPUT);
digitalWrite(6, LOW);
void action();
easyvr.setPinOutput(EasyVR::IO1, HIGH); // LED on (listening)
Serial.print("Say a command in Group");
Serial.println(group);
easyvr.recognizeCommand(group);
do
// can do some processing while waiting for a spoken command
while (!easyvr.hasFinished());
easyvr.setPinOutput(EasyVR::IO1, LOW); // LED off
idx = easyvr.getWord();
if (idx >= 0)
// built-in trigger (ROBOT)
// group = GROUP_X; <- jump to another group X
return;
idx = easyvr.getCommand();
if (idx >= 0)
// print debug message
uint8_t train = 0;
char name[32];
Serial.print("Command: ");
Serial.print(idx);
if (easyvr.dumpCommand(group, idx, name, train))
Serial.print(" = ");
Serial.println(name);
easyvr.playSound(0, EasyVR::VOL_FULL);
// perform some action
action();
else // errors or timeout
if (easyvr.isTimeout())
Serial.println("Timed out, try again…");
int16_t err = easyvr.getError();
if (err >= 0)
Serial.print("Error ");
Serial.println(err, HEX);
group = GROUP_1;
void action()
switch (group)
// case GROUP_0:
// switch (idx)
//  case G0_ARDUINO:
// write your action code here
//      group = GROUP_1; //<- or jump to another group X for composite commands
//    break;
//  break;
case GROUP_1:
switch (idx)
case G1_PLAY:
Serial.print("PLAY");
digitalWrite(2, HIGH);
case G1_PAUSE:
Serial.print("PAUSE");
digitalWrite(3,HIGH);
case G1_PREVIOUS:
Serial.print("PREVIOUS");
digitalWrite(4,HIGH);
case G1_NEXT:
Serial.print("NEXT");
digitalWrite(5,HIGH);
case G1_STOP:
Serial.print("STOP");
digitalWrite(6,HIGH);
/*case G1_VOLUME_UP:
Serial.print("INCRESING VOLUME...");
digitalWrite(7,HIGH);
case G1_VOLUME_DOWN:
Serial.print("DECREASING VOLUME...");
digitalWrite(8,HIGH);
case G1_MINIMIZE:
Serial.print("MINIMIZE");
digitalWrite(9,HIGH);
case G1_MUTE:
Serial.print("MUTE");
digitalWrite(10,HIGH);
case G1_FULLSCREEN:
Serial.print("X");
digitalWrite(11,HIGH);
break;*/
/*case G1_FOCUS_VIDEO:
Serial.print("Y");
digitalWrite(12,HIGH);
case G1_FOCUS_PHOTO:
Serial.print("Z");
digitalWrite(13,HIGH);
case G1_CLOSE:
Serial.print("CLOSE");*/
//digitalWrite(13,HIGH);
BUT i have this problem
Quote
In file included from C:\Users\Ionut\AppData\Roaming\Arduino15\packages\arduino\hardware\avr\1.6.6\cores\arduino/Stream.h:26:0,
AvramIonut
PROBLEM SOLVED! I've got both NewSoftSerial and SoftwareSerial libraries. If you encounter the same issue just detele the NewSoftSerial library and the program will be compiled
