Topic: Problem with MF522 (Read 2544 times) previous topic - next topic
kwyjib0
I have an MF522 RFID reader hooked up using softwareserial to my Arduino uno.
I was playing around, was able to read the serial number, the card's make, read and write data to/off the card and initialize the wallet.
All of a sudden it stops working and just replies 0xFF and it looks like it's stuck.
Code: [Select]
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2,3);
  Serial.println("Waiting for card");
  mySerial.begin(9600);
  mySerial.write(0x02);
  if (mySerial.available()){
    Serial.print(mySerial.read(),HEX);
    Serial.print(" ");
  if (Serial.available()){
    Serial.println("");
    mySerial.write(Serial.read());
this used to work like a charm and return the card's serial but now the output is
Code: [Select]
Waiting for card
FF
the MF522 answers the 0xFF to the mySerial.write(0x02) command and then it looks like the arduino freezes as it does not update anything. The RFID Card LED flashes when it detects an RFID but the state LED won't flash.
pylon
How did you connect the reader to the Arduino (including wiring, external components, etc)? Do you have a link to the device you're using (to get the exact model)?
afremont
Try using AltSoftSerial, it might solve your problems.  SoftwareSerial can't xmit and recv at the same time.  You'll have to switch to pins 8 and 9 to use AltSoftSerial.
http://www.pjrc.com/teensy/td_libs_AltSoftSerial.html
Experience, it's what you get when you were expecting something else.
kwyjib0
#3
Mar 26, 2013, 11:13 pm Last Edit: Mar 26, 2013, 11:32 pm by kwyjib0 Reason: 1
sorry for the late response...
anyway... this is what I bought on ebay: Serial 13.56MHZ RFID Reader/Writer Module Kits
Here the documents I worked with
Manual
Test code
When I first connected the RFID reader, the State and the Mode LED were on:
(There's 3 smd leds in the bottom left corner).
When the mode led is on it means that it's in "compact command" mode, which means it expects 1 byte. So I sent 0x02 and the module responded by sending back the serial number of the tag when passed over the the reader.
I then also sent some "basic commands" like to initialize the cards wallet, deduct from the wallet and so on.
But now the mode led is always off. Which would mean it's still in basic command mode. But no matter what command I send now it returns back "FF" immediately.
From the manual:
"For any wrong command sending to this module, 0xFF will be returned."
It looks like it's stuck in basic command mode...
pylon
Is it possible that you changed the baud rate? Have you tried sending the "reset factory defaults" command?
I would try to send that command with every baud rate specified on page 10 of the user manual. And don't use the SoftwareSerial for that, use a hardware serial (on the UNO you only have one, so you're not able to use the serial interface for debugging during that procedure).
kwyjib0
I did try to send the reset factory defaults command with no success.
Thanks for the hint with the baud rates and the hw serial though. Will try it out tonight and let you know!
kwyjib0
@pylon, thank you so much!!!
I did exactly what you told me to do and my rfid reader works as before! I must have overridden the config settings.
kwyjib0
btw, put the description and the code onto my blog.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
