Topic: Arduino Micro as ISP and atTiny84A (Read 15020 times) previous topic - next topic
Flips
Hi!
I'm done with building my first bigger project using an Arduino Micro.
Now I want to program the atTiny84A, which seems to be perfect for the project.
I red all examples about how to use an Arduino Uno as an ISP, but I'm not sure if these guides work with my 84A.
So here is what I made:
I flashed the ISP sketch to my arduino (right COM-Port, board set to Arduino Micro, Programmer set to avr isp witch is default).
According to the comments in the ISP sketch I added some LED's (heartbeat, error, programming). After flashing, the heartbeat LED pulses -> Very nice, it worked!
The comments also told me the following:
Code: [Select]
// pin name:    not-mega:         mega(1280 and 2560)
// slave reset: 10:               53
// MOSI:        11:               51
// MISO:        12:               50
// SCK:         13:               52
I red the data sheet (http://www.atmel.com/Images/8183S.pdf) of the 84A to find the right pins, and so I connected arduino-pin 10 to RESET-pin of the 84A, 11 to MOSI, 12 to MISO and 13 to SCK.
GND and VCC is also clear!
Now I opened the blink sketch (changed pin from 13 to 0), switched the programmer to Arduino as ISP and selected atTiny84 @ 20 MHz as board.
After uploading, the log (update.verbose=true) shows me the following:
Code: [Select]
C:\Arduino\arduino-1.0.4\hardware/tools/avr/bin/avrdude -CC:\Arduino\arduino-1.0.4\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -pattiny84 -cstk500v1 -P\\.\COM13 -b19200 -Uflash:w:C:\Users\Flips\AppData\Local\Temp\build746589376383792063.tmp\Blink.cpp.hex:i
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Arduino\arduino-1.0.4\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : \\.\COM13
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
avrdude: Send: 0 [30]   [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude done.  Thank you.
[\code]
Btw, neither the error nor the programming LED turned on...
I know that this error tells me that there seems to be no connection at all, connection between arduino and the 84A. But why?
Does anyone know how to connect the pins correctly?
Thanks,
Flips
spcomputing
In the command line, replace "-cstk500v1" with "-carduino".
Flips
Thank you, now it works a little bit more.
But I still get an error, this time the following:
Code: [Select]
avrdude: Device signature = 0xffffff
avrdude: Yikes!  Invalid device signature.
I googled it and all I found out were wrong fuse bits. I made the misstake, that on my first try I flashed the tiny with board = atTiny84 @ 20 MHz EXTERNAL (I do not have any oscillators here). Is this the problem? Has this set the fuse bit to external clock (which isn't there) and because of this a second flash won't work until there is an external clock?
Flips
Sorry for double posting, but I think I'll quit that...
I'll order a few new 84A and this time I am going to set the right board (8Mhz INTERNAL!!!!).
I tried everything, I added an external oscialltor with those two 22pf capacitors as near as possible to the XTAL1/2, tried a second 5V Vcc source and finally tried this HV tutorial:
http://mightyohm.com/blog/2008/09/arduino-based-avr-high-voltage-programmer
Nothing, still:
Code: [Select]
C:\Arduino\arduino-1.0.4\hardware/tools/avr/bin/avrdude -CC:\Arduino\arduino-1.0.4\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -pattiny84 -carduino -P\\.\COM13 -b19200 -Uflash:w:C:\Users\Flips\AppData\Local\Temp\build2346145638621125582.tmp\Blink.cpp.hex:i
         AVR Part                      : ATtiny84
         Chip Erase delay              : 4500 us
         PAGEL                         : P00
         BS2                           : P00
         RESET disposition             : possible i/o
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65     6     4    0 no        512    4      0  4000  4500 0xff 0xff
           flash         65     6    32    0 yes      8192   64    128  4500  4500 0xff 0xff
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Send: u [75]   [20]
avrdude: Recv: . [14] . [ff] . [ff] . [ff] . [10]
################################################## | 100% 0.02s
         Double check connections and try again, or use -F to override
         this check.
avrdude: Send: Q [51]   [20]
avrdude: Recv: . [10]
I'm still hoping for anyone how is able to solve this problem!
Thanks, Flips
spcomputing
How about trying the Tiny core library?  It could save you the headache of reinventing the wheel:
https://code.google.com/p/arduino-tiny/
Then you can use the Arduino IDE ;)
Flips
Thanks for your reply!
Does that solve my problem? Because at the moment my main problem is that my tiny is kind of "dead", isn't it? (
I'm a little bit confused at all, because of the log message: "avrdude: AVR device initialized and ready to accept instructions"...)
Do you mean I should use this core for my next tries with a "fresh" tiny?
spcomputing
It is probably locked out, but the HV programmer should be able to unlock it and return it back to Factory 1 MHz.  Only 4 data lines, 5VDC, 12VDC and GND.  Just put the 1Ks between the ATtiny and your Micro.
Coding Badly
The target just needs a clock signal on the XTAL1 pin.  There are variations of the ArduinoISP sketch that provide the necessary signal.
http://arduino.cc/forum/index.php/topic,116227.msg875170.html#msg875170
http://arduino.cc/forum/index.php/topic,116227.msg875423.html#msg875423
Flips
After uploading the posted ISP sketch and connecting SCK, MISO, MOSI, RESET, GND, VCC and XTAL1 (with Pin 9), I tried to upload the blink sketch to the tiny.
First try -> Same result (Invalid device signature).
Second try:
Code: [Select]
avrdude: stk500_program_enable(): protocol error, expect=0x14, resp=0x50
avrdude: initialization failed, rc=-1
         this check.
avrdude: Recv:
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
And that's always, only the second try gives me the "new" error. Searching for this error brings no "new" things.
I also checked every wire again.
I red that this seems not to be a problem of the tiny itself, but a problem of Arduino as ISP...
Coding Badly
Quote
...and XTAL1 (with Pin 9)...
It is very likely a different pin from the Arduino Micro.  Which means the sketch will have to be changed and your wiring will have to be changed.  If I have time, I'll try to get it working tonight.
In the meantime, an LED (plus series resistor) connected to pin 9 then to GND should be dimly lit.  If not then it is definitely the wrong pin.
Quote
The ArduinoISP sketch gets a bit flaky when a problem occurs.  Try resetting the programmer (your Arduino Micro) between attempts.
Flips
Quote
Quote
It is very likely a different pin from the Arduino Micro. [...]
According to the sketch pin 9 seems to be the right pin:
Code: [Select]
pinMode(9, OUTPUT);
// setup high freq PWM on pin 9 (timer 1)
An LED on pin 9 works, so there must be an output. I don't think that this is the problem because by connecting this pin to XTAL1 the error changed.
And resetting the arduino does nothing, I did it now 3 or 4 times: After every reset of the arduino, the first flash gives me the first error (Invalid device sig.) and a following second (or thirth or ...) flash gives me the second error...isn't that very strange at all?
Btw many thanks for your efforts!
Coding Badly
When you say flashed the tiny with board = atTiny84 @ 20 MHz EXTERNAL do you mean you tried changing the fuses?
If you did try changing the fuses, are you certain that was successful?
Flips
#12
Mar 29, 2013, 11:00 pm Last Edit: Mar 29, 2013, 11:03 pm by Flips Reason: 1
No, I just wanted to flash a tiny using my arduino micro as ISP. But unfortunately I checked atTiny 84 @ 20 MHz External during the very first try.
So I thought my problem is that this first flash was successfull which implicates that the flashed tiny needs an external clock (doesn't it?). But now that seems not to be the problem because even with the ISP sketch that creates the necessary clock, I'm not able to flash a sketch to the tiny.
Edit: To answer your question, I didn't want to set any fuse, but I think I did it implicitly by flashing the tiny with the 20 MHz setting.
Coding Badly
No.  The fuses are never set implicitly.  They are set when you do it explicitly using avrdude from the command-line or when you execute Tools / Burn Bootloader from the Arduino IDE.
Did you do either successfully?
Flips
Ok that's nice to know.
No, I've done many tutorials and guides to "reset" the tiny. Yes, there have been instructions to burn the bootloader to the tiny via the arduino IDE...
But I can surely say that there wasn't any operation which was successful! Neither flashing a sketch to the tiny nor burning the bootloader has ever been successful.
For me, that's a little bit confusing because I'm not even able to read the fuse bits (avrdude says extended = high = low = 0xFF...).
