Topic: Problem with lcd.setCursor command starting text in wrong column (Read 1 time) previous topic - next topic
ScottMurchison
I wired up a new 16x4 LCD panel to my ITEADUINO and ran a simple program. The problem is that in rows 2 and 3, the text starts at position 4 instead of position 0.
The display looks like this;
Row 0
Row 1
       Row 2
       Row 3
The program is simple and looks like this;
LiquidCrystal lcd(12, 11, 10, 5, 4, 3, 2);
int backLight = 13;
  pinMode(backLight, OUTPUT);
  digitalWrite(backLight, HIGH);
  lcd.begin(16,4);
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Row 0");
  lcd.setCursor(0,1);
  lcd.print("Row 1");
  lcd.setCursor(0,2);
  lcd.print("Row 2");
  lcd.setCursor(0,3);
  lcd.print("Row 3");
I can change the commands to lcd.setCursor(-4,3);  but this makes no sense to me as to why I should have to.
Has anyone seen this problem and is there a fix?
Scott
ScottMurchison
I am using this LCD display.
http://imall.iteadstudio.com/eone-high-cost-effective-1604-characters-lcd-blue.html
bperrybap
Use a better library:
https://bitbucket.org/fmalpartida/new-liquidcrystal/wiki/Home
The liquidcrystal library that comes with the IDE doesn't properly handle all the different LCD geometries.
fm's library uses the proper addresses for that geometry.
It is a drop in replacement for the library that ships with the IDE.
It is also much faster.
--- bill
floresta
#3
Mar 29, 2013, 04:26 am Last Edit: Mar 29, 2013, 04:30 am by floresta Reason: 1
Quote
Specifically it doesn't handle cursor positioning on rows 3 and 4* of the 16x4 displays correctly.
Don
* I guess I should have said "on the lower two rows"
