Topic: Automotive sensors with a single connection (Read 2134 times) previous topic - next topic
Thruan
How do they work?
How do I get a reading from one?
I'm mainly looking at an oil pressure sensor at the moment.
I have temp sensors sorted by using a thermistor in a voltage divder circuit. Which is easy, I understand how this works.
But how do you get the reading from sensors with just one wire?
Obviously it grounds through the engine, and has the bias resistor inside the sensor.. But that leaves me with either voltage in, or voltage out of the single pin. Obviously I can't get voltage out without putting voltage in.
So how does it work? Seems like black magic to me..........
johnwasser
Most simple sensors work as a switch.  The signal wire is grounded when the switch is closed and floating when the switch is open.  Use a pull-up resistor to bias the signal wire to +5.  The signal will read HIGH when the switch is open and LOW when the switch is closed.  You can enable the built-n pull-up resistor on an input pin with:
     pinMode(pin, INPUT_PULLUP);
afremont
Just to add to what John said, some do act as variable resistors to ground (think potentiometer controlled by heat, pressure or vacuum).  If the vehicle has mechanical gauges, or can tell you the precise temperature then its probably an analog output sensor.  Most modern sensors are completely isolated from the engine block ground by using an extra wire or two.
Experience, it's what you get when you were expecting something else.
JimboZA
Back in the day, the "wire" from an oil pressure gauge wasn't a wire, it just looked like one.... it was a plastic pipe full oil under pressure which operated some mechanical gubbins in the gauge, and which sprayed boiling oil in the driver's compartment if something broke.
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
Thruan
Ok thanks guys. Seems like it's probably just a 'switch' sensor.
Once the pressure drops past a point, the circuit goes open and lights up the light on the dash.
Ill have to buy an aftermarket one that will give me an analog output.
Jimbo, no this one is certainly wire. As well as one of the coolent temp sensors. So I'd say its the same. Just a switch.
Thanks for the help guys.
