Topic: Dumb Question - Global variable not holding value on change (Read 4522 times) previous topic - next topic
rgallant
I am trying to increase a value by 5 the value is an integer,  the intent is to increment the value if an invalid RFID card is read.
Card reading LCD display works fine, I have done or am not doing something right but I just can not see it.
Code Section that is failing
Notes:
eXtime is declared Global
It is only used in this area -searched the code to make sure
Serial output shows the value as zero everywhere but inside the if when is incremented.
This is not correct function as I understand it a global variable should maintain it's value until the loop restarts
portion that is failing
Code: [Select]
while (big_boom == 0)
  while (int_sys == 1)
  clr_scr();
  backlight_on();
  LCD_Message(message,10,1);
  LCD_Message(message2,15,2);
  delay(3000); //make em wait
  // debug only
  // I2c.scan();
  int_sys = 2;
Get_card();
check_arm();
Serial.print(eXtime);
Serial.println(" eXtime val");
if (armed ==2)
   clr_scr();
   LCD_Message(message4,14,1);
   eXtime = eXtime + 5;
   delay (10000);
if (armed==1)
   clr_scr();
   minut=minut + eXtime;
      Serial.println(" xtime val");
      Serial.print(minut);
      Serial.println(" minut val");
   itoa(minut,minu,10);
   LCD_Message(minu,3,1);
   itoa(second,sec,10);
   LCD_Message(sec,3,1);
marco_c
Post all the code. In these sorts of issues the problem is not generally where you see the failure but somewhere else.
Arduino Libraries https://github.com/MajicDesigns?tab=Repositories
Parola for Arduino https://github.com/MajicDesigns/Parola
Arduino++ blog https://arduinoplusplus.wordpress.com
Sembazuru
You didn't show us where you define eXtime... You didn't accidentally define it with "const int" setting it as a constant instead of a variable did you? Are you sure that armed ever equals 2?
That's all I got.
http://www.catb.org/jargon/html/I/I-didn-t-change-anything-.html
rgallant
Nope the declared as int eXtime no initial value set.
Yes arm is set to 2 when an incorrect card is swiped, I removed print statements from there as the value was being set correctly with in the if, it is not staying set however.
If I print the the value, at the point I add 5 on the 1st bad card eXtime is equal to 5
If i print the value of eXtime as soon as the if ends it prints as zero.
everything else works as expected
I can include all the code but it is fairly large.
Sembazuru
Sorry, I'll have to drop out of this. My first dumb answer was the best I could do for your dumb question.  ;)
rgallant
that is ok I found that I am getting corruption in that value, if i try to print after the if  it prints 5 and a garbage character,the second print statement does not print at all. so I have a bigger issue, I need to review my variable declarations may be I have too many for an UNO.
lost_and_confused
"Dumb question #2"
If eXtime is ONLY used here, WHY is it global?
Use it here, and return a value which the outside code can see and act on that rather than the actual value.
Just a thought.
UKHeliBob
Quote
It would be more accurate to say that it retains its value until something changes it.  loop() restarting has nothing to do with it.
To get more help you must post all of your code or attach it to a post.
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
Sembazuru
Oops... so much for me keeping out of this. If you find you are running out of variable space, why not look at all your "int"s. Decide which ones both never get a negative value and never contain a value over 255, and change them to "byte". That should save 1 byte for each one you convert... (int is 2 bytes on the UNO.)
Might be a red herring though....
rgallant
ukHelibob,
That is why I am confused, your explanation is exactly my understanding of how things should be working, but they are not.  I was hoping I had simply done something unusually dumb and missed it.   I will post or attach the whole section of code later.
PeterH
Unless you can post a complete sketch that demonstrates the problem, you're pretty much wasting your time trying to figure it out from code snippets. If you're able to produce a simpler sketch that demonstrates the problem, so much the better. But the code you post needs to compile, run and demonstrate the problem.
I only provide help via the forum - please do not contact me for private consultancy.
rgallant
#11
Mar 28, 2013, 10:33 pm Last Edit: Mar 28, 2013, 10:36 pm by rgallant Reason: 1
Everything as requested, this code compile and runs the problem as noted above is in the armed 2 if statement.
Output from serial :
the garbage characters are from the print right after the arm 2 check.
Code: [Select]
#include <I2C.h>
// FOR RFID Reader
#include <SoftwareSerial.h>
#define RFID_READ 0x01
#define txPin 6
#define rxPin 10
// define Devantech LCD address
#define DLCD 0x63
int int_sys = 1;
int y = 0;
int z = 0;
int err_c = 0;
int i;
int second=00;
int minut;
int hour=0; // declare time variables
int armed = 0;
int go_boom = 0;
int big_boom = 0;
int Arm_card[4];
int Test_val[4] = {1,248,124,0};
// canned messages
char message[10] = "Hello Hal";
char message2[15] ="Arm the System";
char message3[15] ="Verfiying Code";
char boom[2] ="b";
char message4[14] ="Arming Failed";
// For data from RFID tags
SoftwareSerial mySerial(rxPin, txPin);
int val;
int runs = 0;
char Set1[5];
char Set2[5];
char Set3[5];
char Set4[5];
char sec[3];
char minu[3];
char hou[3];
char zer[2] = "0";
 I2c.begin();
 mySerial.begin(9600);
 pinMode(txPin, OUTPUT);
 pinMode(rxPin, INPUT);
 minut = 5;
 int eXtime = 0;
       clr_scr();
       backlight_on();
       // debug only
       // I2c.scan();
       int_sys = 2;
      Get_card();
      check_arm();
      if (armed ==2)
         clr_scr();
         eXtime = eXtime + 6;
         Serial.println(" in loop xtime val");
         delay (5000);
       Serial.println(" after armed 2 if xtime val");
      if (armed==1)
          clr_scr();
          while (go_boom==0)
             countdown();
             if (minut == 0)
                if (second == 0)
                   go_boom = 1;
                   clr_scr();
                   LCD_Message(boom,16,1);
                   delay(2000);
                   big_boom = 1;
// LCD functions
// All tested and working as expected
void backlight_on()
 err_c = I2c.write(DLCD,0);  // set the register pointer
 if (err_c != 0)
    Serial.print(err_c);
    Serial.println("  Error setting pointer");
 err_c = I2c.write(DLCD,0,19);
 if (err_c != 0)
     Serial.println("  Error setting backlight on");
void backlight_off()
 if (err_c != 0)
err_c = I2c.write(DLCD,0,20);
 if (err_c != 0)
     Serial.println("  Error setting backlight off");
void LCD_Message(char mess[],int C_len, int M_line)
 if (M_line == 2)
   Line_2();
 if (err_c != 0)
for (i=0;i<C_len;i++)
err_c = I2c.write(DLCD,0,mess[i]);
 if (err_c != 0)
     Serial.println("  Error writing message");
void Line_2()
 if (err_c != 0)
 err_c = I2c.write(DLCD,0,13);
 if (err_c != 0)
     Serial.println("  Error writing message 2");
void clr_scr()
 if (err_c != 0)
 err_c = I2c.write(DLCD,0,12);
 if (err_c != 0)
     Serial.println("  Error clearing screen");
void check_arm ()
 int arm_good = 0;
 for(i=0;i<4;i++)
   if (Arm_card[i+1] == Test_val[i])
      arm_good = arm_good + 1;
  if (arm_good == 4)
    armed = 1;
    armed = 2;
// RFID read section note for new cards
void Get_card ()
 int val;
 int got_data = 0;
 while (got_data == 0)
   mySerial.write("!RW");
   mySerial.write(byte(RFID_READ));
   mySerial.write(byte(32));
   mySerial.available();
   if(mySerial.available() > 0)
     val = mySerial.read();                        //The mySerial.read() procedure is called, but the result is not printed because I don't want the "error message: 1" cluttering up the serial monitor
     if (val != 1)                                   //If the error code is anything other than 1, then the RFID tag was not read correctly and any data collected is meaningless. In this case since we don't care about the resultant values they can be suppressed
      {suppressAll();}
   clr_scr();
   LCD_Message(message3,15,1);
   delay(2000); // more waiting :)
   itoa(val,Set1,10);
   LCD_Message(Set1,4,2);
   delay(2000);
   Arm_card[1] = val;
   Serial.print("1st:");
   Serial.println(val);
  if(mySerial.available() > 0) {
   itoa(val,Set2,10);
   LCD_Message(Set2,4,1);
   delay(2000);
   Arm_card[2] = val;
   Serial.print("2nd:");
   itoa(val,Set3,10);
   LCD_Message(Set3,4,1);
   delay(2000);
   Arm_card[3] = val;
   Serial.print("3rd:");
   itoa(val,Set4,10);
   LCD_Message(Set4,4,1);
   delay(2000);
   Arm_card[4] = val;
   Serial.print("4th:");
   Serial.println("-----------------");
   got_data = 1;
  delay(750);
void suppressAll()                                //suppresses the "null result" from being printed if no RFID tag is present
   { mySerial.read();
     suppressAll();
* Main countdown timer                                     *
*                 countdown()                              *
void countdown()
 static unsigned long lastTick = 0; // set up a local variable to hold the last time we decremented one second
// (static variables are initialized once and keep their values between function calls)
// decrement one second every 1000 milliseconds
 if (second > 0) {
     if (millis() - lastTick >= 1000) {
         lastTick = millis();
         second--;
         clr_scr();
         if (second < 10)
          LCD_Message(zer,1,1);
// decrement one minute every 60 seconds
 if (minut > 0) {
     if (second <= 0) {
         minut--;
         second = 60; // reset seconds to 60
// decrement one hour every 60 minutes
 if (hour > 0) {
     if (minut <= 0) {
         hour--;
         minut = 60; // reset minutes to 60
     }//closes if
 }//closes if
AWOL
#12
Mar 28, 2013, 10:37 pm Last Edit: Mar 28, 2013, 10:39 pm by AWOL Reason: 1
Code: [Select]
char message3[15] ="Verfiying Code"; the compiler can't do much about your spelling, but it is quite capable of counting the number of characters in a string
Code: [Select]
char message3[] ="Verifying Code";
Code: [Select]
  int eXtime = 0;
Global?
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
lost_and_confused
(Hey AWOL).
Ok, question - not to you AWOL.
Line 65 is where you set exTime
That is inside the loop and so every time the loop loops, it will be wiped.
You do understand that don't you?    :D
PeterH
Code: [Select]
int eXtime = 0;
Not in your example, it isn't. Since it's declared as a local variable in loop(), it will be reinitialised to zero at the start of each call to loop().
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
