Hello everyone,
I have just received my first Arduino, and am very impressed with it. Hardware that's simple enough for a software guy like me! ;D
However, I've also run into my first problem. I'm trying to read an analog control voltage that I measured to be in the 0-5 V range. Couldn't be simpler as it is already in the perfect range for an Arduino, right? Well, what I discovered after trying it out was that the voltage is microprocessor controlled, and looks like this when I read it from the Arduino:
So, I am assuming this is some kind of
pulse-width modulation..? :-?
For the record, reading the analog input as such works ok, with the connection in the
AnalogInput tutorial. My connection is the same, except ground goes to ground and analog0 to the control voltage on the device.
So, my question is: how should I go about reading the voltage correctly (so that the value I get is unfluctuating, like the display on my voltmeter)?
Thanks in advance
