Topic: Voltage trippler? (Read 2441 times) previous topic - next topic
Bonz099
Is there a simple low cost IC that i can use to triple my input voltage? I need to feed an IC 15v and would love not to have to have another PS or buy a DC-DC converter, if not ill buy the converter, im just a bit reluctant to spend the 15 bucks on what seems like a simple task.
I figured ide ask since ive seen doublers like the ADM660.
Osgeld
why take a higher external voltage (the arduino supply) run it tru a 5 volt regulator then boost it back up?
Grumpy_Mike
It is called a boost converter but it will cost you much more than 15 bucks.
The price depends on the current. What current do you need?
Bonz099
Im doing this cause im using an ad595 in the same circuit, and it needs to be feed exactly 15v in order to read past a certain temp. I would imagine it needs a minimal amount of current.
jluciani
There is an application note for a voltage tripler at Maxim (AN297) It uses the MAX1683,  (3) 10uF caps and a dual schotty. It is probably in the $5-$7 range.
The topology may work with the xx660 chips but I am not sure.
A couple notes -- the switched capacitor boost converters have limited current and
are unregulated. Also the voltage is 3 * VIN minus two diode drops (and whatever
regulator you add).
(* jcl *)
pwillard
If you like to recyle old electronics (as I do) you can sometimes find a jem in the junk.  I found a few TL497's in my junk box and they work great at getting 15V from 5V.
Actually, these nice chips are still available New from Mouser electronics (so I guess other vendors have them as well)  Only $1.50 or so each.  The only tricky component needed is a power inductor of the right value.
BroHogan
Maybe a High-Side Power Supply - used for N-channel MOSFETs.
I've used the MAX1822.
http://datasheets.maxim-ic.com/en/ds/MAX1822.pdf
"Data is not information, information is not knowledge, knowledge is not understanding, understanding is not wisdom."
~ Clifford Stoll
Bonz099
Ive decided on buying a doubler. After more research ive found that i dont need to measure over 1800f. Im gonna use the ADM660 that jluciani suggested in an earlier post. Thanks again guys.
jluciani
I think you are better off with a doubler. A lot of people make the x660 series doublers
(and doublers in general). You only need two or three caps to get 50-100mA.
The ADM660 is reasonable priced especially considering it is coming from a quality
manufacturer like Analog Devices.
(* jcl *)
www: http://www.wiblocks.com
twitter: http://twitter.com/wiblocks
blog: http://luciani.org
