Topic: Interfacing Allegro ACS754 with Arduino (Read 1 time) previous topic - next topic
buu-gadgets
Jan 20, 2010, 01:37 am Last Edit: Jan 20, 2010, 01:38 am by buu-gadgets Reason: 1
I have this little code:
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
const int voltPin = 1;
const int ampPin = 3;
int A = 0;
   lcd.begin(16, 2);
  float volt = (analogRead(voltPin) + 1) * .00488;
  lcd.setCursor(1,0);
  lcd.print(volt);
  lcd.setCursor(8,0);
  lcd.print("Volt");
  A = (analogRead(ampPin)-512);
  lcd.setCursor(1,1);
  lcd.print(A);
  lcd.setCursor(8,1);
  lcd.print("mA");
  delay(200);
My goal is to read voltage and mA on a 16x2 LCD.
The part of the voltave is done, but I can't solve the part of interfacing with ACS754.
The main charateristics of the current sensor is:
Vcc =5.0v
Zero current = 2/Vcc = 2.5v (at output pin = analogRead 3)
Sensitivity = 13.3 mV/A = 0.0133v
Can some one help me and explain the math for this divider, and make this thing work  :)
Grumpy_Mike
The A/D gives you a reading of 1023 for 5V input
So for a given reading R you have a voltage of:-
V = R * (5/1023)
With the current sensor you have half way biased signal so a voltage reading of:-
V = (R-511) * (5/1023)
at 13.3 mV per Amp
you have
Amps = V / 0.0133
This gives you a resolution of 367mA per reading increment. Given that you always get plus or minus one on a digital to analogue converter your accuracy will approximately be to the nearest half an amp. (734mA)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
