Loading...
Pages: 1 ... 13 14 [15] 16 17 18   Go Down
Author Topic: Your last purchase?  (Read 5414 times)
Phoenix, Arizona USA
Offline Offline
Faraday Member
Where's the beer?
View Profile
WWW
Quote
The 2.4 should have none of those problems, and should also have a better range with better picture, but I haven't tested those yet, but when my new wifitank is running, that will be the next thing I replace on it.
Some of those camera kits look similar to what I bought (though, once again, I don't recall if mine was a 900 MHz or 2.4 GHz; it might be that the 900/2.4 are frequencies for the US, while 1.2 GHz is for other countries?).
Something I recently bought with the intent of using it on my UGV project in the future was this:
http://www.geeks.com/details.asp?invtid=BLK-9100A-PLUS-N&cat=VID
It allows you to plug in four regular cameras (composite video) and view them via a built-in webserver over wired ethernet. Its powered off of a 5V 1A DC wall-wart (cameras are powered separately). Since my UGV has an 802.11g router/hub, I can easily plug it in (and power won't be an issue, since I'll have some fairly large 12 volt SLAs on-board).
Something to play with, anyhow!
 smiley
Logged
Vejen, Denmark
Offline Offline
Edison Member
RAWR! ^,..,^
View Profile
WWW
Quote
I got one of those (just in metal chasing), but the original firmware on them sux, so instead I uploaded the yoics 9100a firmware instead.
The camera on my wifitank is also running through that. smiley
Blue box smiley-wink
All my cameras are powered through the wire (only the one on the tank is wireless), and the switchmode power supply in the upper left corner is powering all of them.
« Last Edit: December 28, 2010, 02:25:19 pm by bld » Logged
captain-slow.dk | non contagious!
Offline Offline
Faraday Member
Where's the beer?
View Profile
WWW
Quote
Interesting - do you have a link or such describing the process (and/or why the original firmware stinks)? If it is really bad (I haven't even tried mine yet), updating it would be worth it...
 smiley
Logged
Vejen, Denmark
Offline Offline
Edison Member
RAWR! ^,..,^
View Profile
WWW
First problem was that it was impossible to get a single image out, all images was handled by the same cgi file (which is still an option with the new firmware too), next problem for me was very unstable, it could sometimes stop responding for like a minute, then run fine again for a random amount of time.
And to update to the other firmware, simply go to their website, see what version they recommend, then go to the cameraserver's gui, and upload the firmware just like if it was the original firmware... job done smiley
I am using all cameras I got through php http://bld.is-a-geek.com/webcam/ the reason I am doing it like this is that there are issues with the security. Because in the original there are no option for password protection... With the new firmware there are password protection, but only way to see the images is then to log in.
So by having php process it, there are no direct connection from the device to the internet.
And doing that with most things I do smiley-wink Running it through php makes it much harder to abuse, because if someone wants to "hack" it, they actually needs to hack linux and the apache webserver, not the thing I made which might be potentially more vulnerable to such attacks.
« Last Edit: December 28, 2010, 03:53:33 pm by bld » Logged
Holland
Offline Offline
Sr. Member
Arduino likes cookies too
View Profile
Out of curiosity, bld, how did you get the video output from one of those camera's on the web?
Dealextreme does have several wifi camera's, but it appears they have several issues (browser support being one of em?)?
Mostly looking to see whether it is affordable to splurge even more on my bot  smiley-razz
If this derails this topic a bit too much, I wouldn't mind discussing it through pm's either (though I'm sure there are others that would be interested). Perhaps a dedicated topic is in order?
Logged
Offline Offline
Faraday Member
Where's the beer?
View Profile
WWW
Quote
Do they leave a way to bypass this with the new firmware, so that you get the better stability of the new firmware, with the ability to run it "wide open"? I need to basically have it wide open to stream the data from the cameras to (ultimately) OpenCV for processing it (I imagine I could use curl or something to log in for me, but that's just an extra step that isn't needed - I don't need the security like you do, since the box will be behind the router, with WEP, MAC locking, and ultimately SSL encryption to the external browser).
Thanks for the info!
 smiley
Logged
SE USA
Offline Offline
Faraday Member
@ssh0le
View Profile
I got my printer today, and yea its big (but it does have a flatbed in it) but overall I am impressed by it (for an inkjet) its a little slow with color, but faster than most inkjets I have delt with, and pretty darn fast with text
both have excelent quality from what I can tell (rather not burn up 50 bucks worth of ink doing extensive test) and its built pretty well for a modern printer
wifi is idiot proof, and I am off to install it in linux  smiley
Logged
Vejen, Denmark
Offline Offline
Edison Member
RAWR! ^,..,^
View Profile
WWW
Quote
Just made a post on my blog about it smiley
http://bld.is-a-geek.com/2010/12/29/having-an-live-webcam-stream-from-an-arduino-controlled-robot/
Logged
California
Offline Offline
Full Member
That's me, the boy with the broken halo.
View Profile
Not Arduino/electronics but thought most would like this anyway.  Last thing I bought was a clear disc golf disc that I dyed Boba Fett onto.
Not sure if I can bring myself to throw it...
Logged
North Yorkshire, UK
Offline Offline
Faraday Member
View Profile
Quote
That like a frizbee? smiley-wink
Logged
SE USA
Offline Offline
Faraday Member
@ssh0le
View Profile
doesn't look like a pie to me
Logged
California
Offline Offline
Full Member
View Profile
Yeah, it's like a frizbee, but they've been built to fly 400/500 feet (pros get them out to 800-ish feet!).  They make them out of a bunch of different plastics and some take Rit dye well so people like to put art on them.
Logged
North Yorkshire, UK
Offline Offline
Faraday Member
View Profile
Quote
Pie?
Don't make me hungry after midnight...
Logged
SE USA
Offline Offline
Faraday Member
@ssh0le
View Profile
http://en.wikipedia.org/wiki/Frisbie_Pie_Company  smiley-wink
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Just got these 2 albums.
Have listened to the Live in Japan album, very nice. Have not opened the 2nd yet.  Both came with DVDs as well.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Pages: 1 ... 13 14 [15] 16 17 18   Go Up
Print
Jump to:
