Topic: SerialUSB instability - Program stalls (Read 999 times) previous topic - next topic
Wilsonator
So I have been testing the stability of my SerialUSB stream for continuous output over long period of time and have been running into some problems.
Here is the Arduino code I am using to test:
Code: [Select]
  SerialUSB.begin(115200);
  double t_start=micros();
  SerialUSB.write(0x99);
  double t_end=micros();
  //Limit program to 200Hz speed
  while((t_end-t_start)<5000) {
    t_end=micros();
And on my computer side I am using the following python module:
Code: [Select]
import time
import serial
import getPort //Module returns available serial ports for selection
portname=getPort.get_serial_port()
ser=serial.Serial(portname,115200,timeout=0.1)
try:
    while(1):
        t_loopstart=time.clock()
        print ser.read(1)
        t_loopend=time.clock()
        print "Program Runspeed: %.1f\n" % (1/(t_loopend-t_loopstart))
finally:
    ser.close()
    print "Program Ended"
When I start these programs up at first communication is flawless. Then suddenly around 1 hour of runtime the arduino serial stream stops completely. No more data is transfered. If I stop the python program at this time then open the serial monitor in arduio there is still no serial data being transmitted. The only way to get the serial stream to begin again is to reupload the code to the arduino.
I really don't understand what is happening here, can anybody give me a hint?
fiddler
#1
Mar 30, 2013, 09:20 am Last Edit: Mar 30, 2013, 10:34 am by fiddler Reason: 1
I think your timer may have a hickup when rolling over to zero.
micros() should use a "unsigned long" and not a "double"
K
Wilsonator
K
Thanks, that was exactly the problem! Never would have guessed that.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
