Topic: anyone know sim plot? (Read 3366 times) previous topic - next topic
debrouillez40
I'm just starting to use it.  I'm doing the pentiometer to send a voltage test.  The text screen on the sim plot shows the voltages, but the graph doesn't have a line forming.  I did the plot setup to go from 0-5 v on the y axis, so the data should be in range.
debrouillez40
Correction.  There is a line at the bottom, which is the 0 value.  If I expand the minimum y value to -1, I can seethe line moving.  THe problem is that the line stays at a steady 0 v, even though the text box is showing appropriate voltages as I change the petentiometer.
robtillaart
can you post a schema how you connected things?
can you post your Arduino code?
If you connect 5V instead of the potentiometer does the graph change?
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
debrouillez40
It's pretty much the setup for "read analog voltage" where the 5k pot's prongs are connected to 5v, ground, and A0.  I"ve had no problem with it displaying the changing voltage on the text screen of Sim Plot, or the Arduino serial monitor. When I send 5v directly to A0, the text box acknowledges a constant reading of 5v, but the line generated still shows 0.
I'm a newbie to arduino, so I looked at the sine wave generator example sketch on the simplot download page, and tinkered around to figure out what code from there I needed to add/alter to combine it into the read analog voltage sample sketch. I'm sure there's something else that I need to change/add in the sketch, but I'm still learning the language.
My goal is to get it to generate the performance data of some homebrew solar panels that my kids are building.  I've gotten where the arduino logs the solar voltage perfecty, but for now I'm using the petentiometer test to put out a variable voltage until I've figured out how to use the simplot (saves me the trouble of hooking up the panel and voltage divider circuit). Here's the sketch:
{ Serial.begin(57600);
int buffer[20];
  int data1;
int sensorValue = analogRead(A0);
  // Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
  float voltage = sensorValue * (5.0 / 1023.0);
  // print out the value you read:
  Serial.println(voltage);
  //Generating data that will be plotted
  data1 = sensorValue * (5.0 / 1023.0);
  plot(data1);
  delay(100); //Need some delay else the program gets swamped with data
void plot(int data1)
  int pktSize;
  buffer[0] = 0xCDAB;             //SimPlot packet header. Indicates start of data packet
  buffer[1] = 4*sizeof(int);      //Size of data in bytes. Does not include the header and size fields
  pktSize = 2 + 2 + (4*sizeof(int)); //Header bytes + size field bytes + data
  //IMPORTANT: Change to serial port that is connected to PC
  Serial.write((uint8_t * )buffer, pktSize);
wergeld
It looks to me like your packet is not set up correctly.
Take a look at the single channel setup: http://www.negtronics.com/simplot/simplot-code-samples/plot-analog-input-data.
Your plot code should look like:
Code: [Select]
  int pktSize;
  buffer[1] = 1*sizeof(int);      //Size of data in bytes. Does not include the header and size fields
  buffer[2] = data1;
  pktSize = 2 + 2 + (1*sizeof(int)); //Header bytes + size field bytes + data
