Topic: ~Text Weather Notifier?! - I need help... (Read 2948 times) previous topic - next topic
tristonli
Mar 30, 2013, 05:10 am Last Edit: Mar 30, 2013, 05:12 am by tristonli Reason: 1
Hi!
I came up with an idea of an Arduino Board that is connected to the internet through Ethernet, and sends text with the GSM shield.
Concept:
Quote
Text your zip code, City, or State to get a text with all the statistics for weather. Text "add" and your zip code, city, or state to be  added onto a list that texts you when a major storm, or any warning in general has been issued. Using weather.com, the information is ripped directly from there and updated. Locally, the LCD screen connected to the Arduino Board will display requests for weather, time, date, how many people using the service, when a new phone number is added, etc.
I only have the Arduino Uno, SD card shield, Ethernet Shield, 20x16 LCD screen, and I am going to purchase the GSM shield.
Thing is, is that I have no experience with programming or Arduino designing, since I just purchased the board and components on 3/28/13. :smiley-sad-blue:
Please post, personal message, or email me with help. I have no idea what I'm doing, and would like guidance. It's why I posted this, anyways.  :smiley-sweat:
Edit: Using this type of Service - http://www.weather.com/weather/rss/subscription/
Erdin
The Ethernet Shield already contains the microSD card socket.
http://arduino.cc/en/Main/ArduinoEthernetShield
Click on the "Getting started" link in that page, and try a few examples for the Ethernet and SD card.
The examples for that are also included in the Arduino IDE (the Arduino software).
tristonli
I got the SD card shield because my MicroSD card didn't have enough storage.
The phone numbers will be stored on the SD card.
Unfortunately, the Getting Started page doesn't really help me that much, because I have no experience with programming the Arduino.  :~
Erdin
In the Arduino IDE (the Arduino software) are example sketches.
Start with Basics/Blink.
tristonli
For the easy "LED Blink" projects and such, I can understand most of it.
To specify, I have the Seeed Versions of the shields.
Here is the layout of the project (how it may look).
What do you think?
zoomkat
Quote
I use the microSD card slot on my w5100 based ethernet shield with a 4 GB microSD card I got at Walmart. Just how many phone numbers do you need to store?
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
Erdin
The is no (absolutely no) difference between the microSD card socket on the ethernet shield and the SD card shield. They both can be 16GB (or 32GB, I'm not sure).
tristonli
I have a bunch of SD cards. x5 16BG and x1 32GB.
I can store a lot of phone numbers. From 100-1000. If I can use the SD cards, I can hold a lot of phone numbers.
I just need to know if my setup will work and how to program it all.
And how to provide RSS feed from Weather.com. And have all the zip codes, citys and states update, for about every 10min.
zoomkat
Quote
Have you actually stored or read anything on your SD cards? If not, then work on that piece first.
Quote
It appears that you wnat to retrieve weather information from Weather.com, so have you been able to do that yet? You may want to search the forum for "weather" to see previous similar projects.
Quote
Maybe, maybe not. A lot depends on your knowledge and level of effort.
Erdin
#9
Mar 30, 2013, 06:30 pm Last Edit: Mar 30, 2013, 06:33 pm by Erdin Reason: 1
It will work.
Set the Arduino as a Webclient, and do a request.
The request is for example this, http://rss.weather.com/weather/rss/local/USNY0996
You have to get the wanted string from the weather channel RSS feed creator.
Read the returned data and extract what you want.
It will not be easy, but it can be done.
tristonli
Time to get programming.
I'll try to use the "Web Client" tutorial, SD card formatting, etc.
How do I connect the SD card reader tot he breadboard? It seems to be the one that plugs directly into the Arduino...
And the LCD screen... It has an attached speaker. Make it beep when ever weather is requested?
zoomkat
The below has some code for downloading weather data.
http://arduino.cc/forum/index.php/topic,156007.0.html
tristonli
Thank you! I'll get to coding right now...
