Topic: U & L formatters (Read 1 time) previous topic - next topic
bhuvaneshnick
Quote
By default, an integer constant is treated as an int with the attendant limitations in values. To specify an integer constant with another data type, follow it with:
a 'u' or 'U' to force the constant into an unsigned data format. Example: 33u
int a=33u
is that mean mean unsigned integer
PaulS
Quote
int a=33u
Yes. The value 33u will be treated as an unsigned int. Silly to store that in a signed int, then.
bhuvaneshnick
is byte data type only for binary representation
which of the following is correct
byte a=B1001;
or
byte a=65;
PaulS
Quote
The Arduino (and all other computers) only knows how to store data in binary. The compiler is responsible for converting decimal, octal, binary, hexadecimal, etc. representations to binary. So, the answer to your question is no.
Quote
Both are correct.
AWOL
Quote
byte a=B1001;
or
byte a=65;
In Arduino-world, both are correct (though obviously not equivalent), but only the latter is portable.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
MarkT
Code: [Select]
byte a=B1001;
is best avoided, since you can use
Code: [Select]
byte a=0b1001;
which isn't Arduino-specific and allows modifiers like
Code: [Select]
byte a=0b1001U;
Don't write a long modifier as 'l', always use 'L' since it otherwise is
readily confused with a one.  Consider 1111l and 1111L
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
