Topic: SoftwareSerial problem , but only on 1284p (Read 6868 times) previous topic - next topic
skyjumper
Hi All...
I am playing with the Seed Studio Bluetooth shield, bought up the road at Radio Shack. I am testing it on two different boards, an Uno and my own 1284P board.
On the Uno, the code below works well, letting me exchange text with my Android phone.
On the 1284P board, I can send text to the phone, but data sent from the phone is not displayed on the terminal, leading me to believe that it is not actually being received.
I have checked the schematic and verified that the pins are correct. I even reversed which were the TX and RX pins, and of course rejumpered the shield, and the problem remained the same, indicating that there is not a hardware problem. I have also tried it with and without the internal pullup enabled.
Any ideas?
Thanks...
#include <SoftwareSerial.h>   //Software Serial Port
// Use these for 1284P board
#define RxD 14
#define TxD 15
// Use these for Uno
//#define RxD 6
//#define TxD 7
#define DEBUG_ENABLED  1
SoftwareSerial blueToothSerial(RxD,TxD);
  pinMode(RxD, INPUT);
  digitalWrite(RxD, HIGH); // enable pullup
  pinMode(TxD, OUTPUT);
  setupBlueToothConnection();
  char recvChar;
  while(1){
    if(blueToothSerial.available()){//check if there's any data sent from the remote bluetooth shield
      recvChar = blueToothSerial.read();
      Serial.print(recvChar);
    if(Serial.available()){//check if there's any data sent from the local serial terminal, you can add the other applications here
      recvChar  = Serial.read();
      blueToothSerial.print(recvChar);
void setupBlueToothConnection()
  blueToothSerial.begin(38400); //Set BluetoothBee BaudRate to default baud rate 38400
  blueToothSerial.print("\r\n+STWMOD=0\r\n"); //set the bluetooth work in slave mode
  blueToothSerial.print("\r\n+STNA=SeeedBTSlave\r\n"); //set the bluetooth name as "SeeedBTSlave"
  blueToothSerial.print("\r\n+STOAUT=1\r\n"); // Permit Paired device to connect me
  blueToothSerial.print("\r\n+STAUTO=0\r\n"); // Auto-connection should be forbidden here
  delay(2000); // This delay is required.
  blueToothSerial.print("\r\n+INQ=1\r\n"); //make the slave bluetooth inquirable
  Serial.println("The slave bluetooth is inquirable!");
  blueToothSerial.flush();
skyjumper
I suspect this related to pin change interrupts. I now recall that I had to modify the original SoftwareSerial library to support the 1284P, so I'm now chasing this in the new library :-(
skyjumper
I made a lot of progress...
As I mentioned, I had modified the SoftwareSerial library under Arduino v0.22 to work with what at the time we called the Sanguino which was based on the 644P, and has the same pin out as the 1284P.
maniacBug had released his 1284P support, and I had asked him to do a version that matched the pin out nomenclature of the AVR Developers 1284P support, which he did. So i don;t know if the issue I had related to the Maniacbug 1284P or the AVR Dvelopers 1284P, but I'll get to the bottom of it.
In case anyone is interested, the changes I made are in pins_arduino.h. I have not checked yet to make sure i didn't break anything else. I suspect I probably did, but we'll see.
Here is the original:
#define digitalPinToPCICR(p)    (((p) >= 0 && (p) < NUM_DIGITAL_PINS) ? (&PCICR) : ((uint8_t *)0))
#define digitalPinToPCICRbit(p) (((p) <= 7) ? 1 : (((p) <= 15) ? 3 : (((p) <= 23) ? 2 : 0)))
#define digitalPinToPCMSK(p)    (((p) <= 7) ? (&PCMSK2) : (((p) <= 13) ? (&PCMSK0) : (((p) <= 21) ? (&PCMSK1) : ((uint8_t *)0))))
#define digitalPinToPCMSKbit(p) ((p) % 8)
Here are my changes:
#define digitalPinToPCICR(p)    (((p) >= 0 && (p) <= 31) ? (&PCICR) : ((uint8_t *)0))
#define digitalPinToPCMSK(p)    (((p) <= 7) ? (&PCMSK1) : (((p) <= 15) ? (&PCMSK3) : (((p) <= 23) ? (&PCMSK2) : (((p) <= 31) ? (&PCMSK0) : ((uint8_t *)0)))))
#define digitalPinToPCMSKbit(p) (((p) <= 7) ? (p) : (((p) <= 15) ? ((p) - 8) : (((p) <= 23) ? ((p) - 16) : ((p) - 24))))
CrossRoads
That last part, I never understood what was going on there.
skyjumper
I'll have som time this weekend to write a detailed explanation. I also need to compare these macros to ManiacBug's standard 1284P distribution and see if these are a bug or if there is something going on I am missing.
But on the plus side, the off the shelf Seeed Studios card works killer well on my board! I have to use SoftwareSerial but, the shield has a UART on it so I believe that I should not have a problem. The thing has been blasting data via bluetooth to my phone all night.
Of course, its BT 2.1, not BLE. Android needs BT 2.1 and Apple iOS needs BLE. What a pain!
CrossRoads
Bainesbunch
Is there any chance that you could send me the modified library you got working wit the 1284P please
Cheers Pete.
EmbeddedAT .. From Concept to Prototype to Production
Electronics and firmware design and project mentoring
I do answer personal requests for help when accompanied with a PayPal receipt ;)
stewie
Hi Skyjumper,
you mentioned....
Did you get any further with that? or the explanation?
I have been trying to figure out whats going on with the modification you suggested for the pin-change interrupts but cant figure it out.
I'm definitely a novice at this so any simplification you can pass along would be much appreciated.
Thanks...
Stewie
bvernham
I am having a different issue.  I am trying to use the softserial library with a 1284P using the mighty1284 core.  The sketch I have works with the UNO but as soon as I try to compile it with the "Bobduino" I get the following:
C:\Program Files (x86)\Arduino\libraries\SoftwareSerial\SoftwareSerial.cpp: In member function 'void SoftwareSerial::begin(long int)':
C:\Program Files (x86)\Arduino\libraries\SoftwareSerial\SoftwareSerial.cpp:401: error: operands to ?: have different types 'int' and 'uint8_t*'
C:\Program Files (x86)\Arduino\libraries\SoftwareSerial\SoftwareSerial.cpp:402: error: expected primary-expression before ']' token
C:\Program Files (x86)\Arduino\libraries\SoftwareSerial\SoftwareSerial.cpp:402: error: operands to ?: have different types 'int' and 'uint8_t*'
C:\Program Files (x86)\Arduino\libraries\SoftwareSerial\SoftwareSerial.cpp: In member function 'void SoftwareSerial::end()':
C:\Program Files (x86)\Arduino\libraries\SoftwareSerial\SoftwareSerial.cpp:417: error: expected primary-expression before ']' token
C:\Program Files (x86)\Arduino\libraries\SoftwareSerial\SoftwareSerial.cpp:418: error: expected primary-expression before ']' token
C:\Program Files (x86)\Arduino\libraries\SoftwareSerial\SoftwareSerial.cpp:418: error: operands to ?: have different types 'int' and 'uint8_t*'
Any ideas?
Thanks
Bruce
skyjumper
These errors are caused by a type mismatch. The type int is not the same as uint8_t*.   int is, well, an int, while uint8_t* is a pointer to an 8 bit unsigned int (which really means something like unsigned char * - I would have to look in the header but I have to go out the door soon).
What is odd is that it works with the Uno.
I can attest that SoftwareSerial works with Mighty 1284P as well as Software Serial can work (which is to say, not very well). There is either an error in your version of SoftwareSerial or your Mighty1284 distro. In fact, are you using the very same code in the Uno and the Mighty1284P?  If you have two different versions of Software Serial (one for Uno and one for Mighty 1284P) then the fact that you can build for Uno is irrelevant.
I see I made a promise a while ago I failed to keep. I still have the modified header files for SoftwareSerial on 1284P, and I can share. But I need to run now :-(
bvernham
Yep, I know about the difference in the data types.
I could not find any references to "int" in soft serail.
serLCD library uses soft serial:
header snipet:
serLCD::serLCD(uint8_t pin) : SoftwareSerial(pin, pin)
   pinMode(pin, OUTPUT);
CPP snipet:
class serLCD : public SoftwareSerial
public:
   serLCD (uint8_t pin);
Originally pin was "int" but I change to uint8_t like softserial expects but still no luck compiling.
Uno and Goldilocs can compile with no issue even though the types were wrong in the original serLCD library.
Also I am the INPUT_PULLUP issue.  I tried new updated files I was sent but that blow up my "fastpinMode" library I am using.
Other ideas would be helpful.
bvernham
This issue has something to do with the pins_arduino.h file.
The attached file is for the Goldilock-20.  If I substitute this into the bobuino variant folder then the sketch compiles with no problem.
Obviously this pins file can not be used for the Bobuino but it gives a good clue as far as what this issue is.
Any attention to this issue is appreciated.
CrossRoads
Okay, I've annotated the Goldilocks file with the differences from Bobuino file.
If we could get a real programmer to review the # define differences and if they should impact software serial, that would be great.
I personally would have just done a few lists with the pins, I find the C/C++ shorthand hard to follow.
tack
I'm hitting the same problem now. I am already using both hardware serial ports and need to use Software Serial and I have the same errors due to issues with the Bobuino pin map. If I try compiling with the AVR Developers pin map it works fine.
I found a reference to the Calunium board and a fix , but it doesn't cure my issue with Bobuino map.
I've tried comparing pin maps for different 1284 versions and against the standard Uno but it's out of my league to understand all the clever jiggery pokery.
It would be great if one of the more talented programmers could take a look and try and fix this to get Software Serial working on 644/1284.
I'm willing to donate a 644 if there is someone that needs the hardware to test on.
retrolefty
#14
Dec 23, 2013, 07:39 pm Last Edit: Dec 23, 2013, 07:41 pm by retrolefty Reason: 1
These lines might be typos?
XTAL2      12|        |29 - D29     PC7 (D23) TOSC2/PCINT23
 XTAL1      13|        |28 - D29    PC6 (D22) TOSC1/PCINT22
And as for the basic posted problem, might the root cause be in the software serial library code not accessing it's serial input and output pins per standard arduino methods?
Lefty
