Topic: eagle libraries with led matrix (Read 2628 times) previous topic - next topic
kyrpav
I have a led matrix 2088AB-1 it is 6.0mm and i can not find a library for eagle does anyone know where can i find.I have  found one for 3mm but i need a bigger.
CrossRoads
carbine000
If you end up not being able to find one, you could always create your own part.
I've found this tutorial to be extremely helpful.
http://myhome.spu.edu/bolding/EE4211/EagleTutorial4.htm
baselsw
I've used a 8x8 LED matrix (20mm).. Didn't find any library so I made my own.. Here is the library and the datasheet.. I hope it's useful for someone!
CrossRoads
I think having the common cathode/common anode part clear is really needed.
kyrpav
thank you guys, the led matrix pdf was corrupted, it has some problem i can not use it. i will check the first propably to make a device
