Topic: P macro (Read 2030 times) previous topic - next topic
BobW
The code below produces this for output:
This is some text . . .
This is some more text.
The "P Macro" seems to be an integral part of the Arduino "language".
Note that no libraries are included in this sketch.
I'm not exacly sure why this sketch works (i.e. the P part)
Where can I learn more about "P" ?
All I know came from studying the Webduino library.
A basic web seach has not produced any useful results for me.
As usual, sorry if this question is too basic.
Thanks,
Bob W
#define P(name)   static const prog_uchar name[] PROGMEM
P(signMessage) = "This is some text . . . ";
 printP(signMessage);
 printCRLF();
 P(signMessage) = "This is some more text.";
void printP(const prog_uchar *str)
 // copy data out of program memory into local storage, write out in
 // chunks of 32 bytes to avoid extra short TCP/IP packets
 uint8_t buffer[32];
 size_t bufferEnd = 0;
 while (buffer[bufferEnd++] = pgm_read_byte(str++))
   if (bufferEnd == 32)
     Serial.write(buffer, 32);
     bufferEnd = 0;
 // write out everything left but trailing NUL
 if (bufferEnd > 1)
   Serial.write(buffer, bufferEnd - 1);
void printCRLF()
 Serial.write((const uint8_t *)"\r\n", 2);
robtillaart
I do know the F macro e.g. - http://arduino.cc/forum/index.php?topic=110307.0 -
Rob Tillaart
majenko
P is a macro, defined at the top of your sketch
P gets replaced by whatever it is defined as, so
gets changed to
static const prog_uchar signMessage[] PROGMEM = "This is some text . . . ";
lloyddean
Please be ware that the IDE will automatically, depending upon the version, add an include of "WProgram.h" or "Arduino.h" if you don not.
BobW
I just inferred that the P was something special because the IDE makes the "P" in the define line of the sketch RED in color, as if it were a keyword.
I got suckered by this.
This does not happen if I change name of macro to "Q", or "R".
Why would this be ?
Bob
PS:  What I am trying to accomplish is to send a big block of HTML to my Arduino Web Server, without using many individual client.print("html code") lines.
gets changed to
majenko
Why would this be ?
Because P will be defined in one of the many keywords.txt files?
