Topic: Force a sealed device to restart - Ideas? (Read 2362 times) previous topic - next topic
skyjumper
Hi All...
I have a device with an ARM Cortex M3 processor sealed in plastic, and its firmware is stuck in an infinite loop. There is no way to reset it without breaking it open, which will destroy it. Any ideas on how to stop it so when it comes back on it can restart? Maybe freeze spray? The battery will eventually run dead, but tis going to be a while...
tocpcs
Just thinking of the obvious - remove the power (Battery..)..?
jackrae
Place in freezer for 24 hours then rewarm to room temperature.  May work, may not.
fungus
Hi All...
Put a cellphone right next to it and dial somebody.
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
cmiyc
Is it a Sphero?
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
kf2qd
Build the next one with a magnetic reed switch.
majenko
Create a small EMP device.  Camera flash, coil of wire ;)
vdaghan
Only if the seal is not metal. Faraday cage :)
majenko
Quote
GoForSmoke
Cycle power. Give it couple seconds between off and on.
1) http://gammon.com.au/blink  <-- tasking Arduino 1-2-3
2) http://gammon.com.au/serial <-- techniques howto
3) http://gammon.com.au/interrupts
Tasking: techniques make the trees, the sketch is the woods.
See the woods and the trees, comment both.
