Topic: sending DS18B20 data over NRF24L01 using RF24 library from Uno to Mega2560 (Read 16447 times) previous topic - next topic
dominator99
Hi all
I've searched the web for any sketches than can help with the above but all I've found is the RF24Network by maniacbug which doesn't seem to have any recent development.
I currently have a Mega2560 reading 7 wired DS18B20 temp sensors & it works fine.
I want to add an additional 6 to 8 DS18B20's but it will be difficult to cable them into the existing arrangement hence the interest in reading the additional sensors over a wireless connection.
I want to use a Uno for this task but don't know how to go about it.  I've run the 'Getting Started' sketch by Maniacbug between my Mega2560 & Uno & this works fine but I'm at a loss as to how to proceed with reading data from DS18B20 temp sensors.
Can anyone help with this project please? (my programming skills are very basic)
PaulS
There seem to be two parts to what you want to do. First, you want to read sensors on the remote Arduino. This is no different from reading them on the existing Arduino.
Second, you want to send some data from the remote Arduino to the existing Arduino. You say that you know how to do this, and that it is working.
So, what IS the problem?
dominator99
Hi PaulS
Perhaps I didn't explain myself clearly.
I can read the sensor data on the Uno but don't know how to send it to the Mega over a wireless connection - the Mega is where all calculations & subsequent actions base on that data are performed.
The 'Getting Started' sketch by Maniacbug is a simple Tx & Rx sketch sending a small packet that tests the 2-way link between my Mega & Uno.
I understand the packet size is very limited (32 byte?) but my major problem is that I don't know how to 'wrap up' my digital sensor data (12bit) from 6 DS18B20 sensors on the Uno into a packet for transmission across the wireless link to the Mega.
I hope I've made this clearer?
PaulS
Each sensor returns 2 bytes of data. 6 * 2 = 12. 12 < 32.
You can create a union containing 6 ints and 12 bytes. Create an instance of the union, and set the 6 ints. Then, send the 12 bytes. Receive 12 bytes, storing them in the byte portion of the same union, and use the 6 ints from that union.
Nick_Pyner
I want to do the same as you. I have not had a chance to use my NRF24s but I have been sending data to the internet via cosm. I didn't realise you had to "wrap up" data packets, but it sounds similar to the procedure for cosm. Here is a snippet of my cosm code.
Code: [Select]
LiquidCrystal lcd(8,9,56,5,6,7);
// Define the strings for our datastream IDs
char sensorId0[] = "InThermo";
char sensorId1[] = "OutThermo";
char sensorId2[] = "DrainThermo";
char calcId1[] = "diff";
const int bufferSize = 140;
char bufferValue[bufferSize]; // enough space to store the string we're going to send
CosmDatastream datastreams[] = {
  CosmDatastream(sensorId0, strlen(sensorId0), DATASTREAM_FLOAT),
  CosmDatastream(sensorId1, strlen(sensorId1), DATASTREAM_FLOAT),
  CosmDatastream(sensorId2, strlen(sensorId2), DATASTREAM_FLOAT),
  CosmDatastream(calcId1, strlen(calcId1), DATASTREAM_FLOAT),
// Finally, wrap the datastreams into a feed
CosmFeed feed(83153, datastreams, 4 );
  int ret=0;
  //get the values from the DS8B20's
  sensors.requestTemperatures();
  float InTemp = (sensorValue(InThermo));
  float OutTemp = (sensorValue(OutThermo));
  float DrainTemp = (sensorValue(DrainThermo));
  float diff = OutTemp - InTemp;
  datastreams[0].setFloat(InTemp);
  datastreams[1].setFloat(OutTemp);
  datastreams[2].setFloat(DrainTemp);
  datastreams[3].setFloat(diff);
  k=k+1;
  if (k>9 )
// ++++++++++++++++++++++++++++++++  feed section
  ret = cosmclient.put(feed, cosmKey);    // SEND FEED TO COSM
dominator99
Quote
Sorry PaulS, this is as clear as mud - my programming skilss are VERY limited.  Could you explain using a sketch?
Thanks
PaulS
The union:
Code: [Select]
union stuff
   int temps[6];
   byte data[12];
An instance:
Code: [Select]
stuff myStuff;
Get the temperatures, and store them:
Code: [Select]
  myStuff.temps[0] = temp0;
  // do the others, too.
  myStuff.temps[5] = temp5;
The payload to send, then, is myStuff.data, with a size of 12 bytes.
On the other end, you'd use myStuff.data as the receive buffer, and read the values using myStuff.temps[n] to get the nth temperature.
dominator99
dominator99
Hi PaulS
Still having problems with wireless comms between Uno (Tx) & Mega2560 (Rx); can you help please?
Tx from Uno seems OK but Rx on Mega doesn't report same temps as Tx'd
I'm running 8 DS18B20 sensors but hope to run more
Tx part (Rx to follow)
Thanks
Code: [Select]
//ONLY RUNS UNDER ARDUINO 1.0
//Arduino Uno as transmitter
/* YourDuino Multiple DS18B20 Temperature Sensors on 1 wire
 Connections:
 DS18B20 Pinout (Left to Right, pins down, flat side toward you)
 - Left   = Ground
 - Center = Signal (Pin 2):  (with 3.3K to 4.7K resistor to +5 or 3.3 )
 - Right  = +5 or +3.3 V
  Questions: terry@yourduino.com
  V1.01  01/17/2013 ...based on examples from Rik Kretzinger
/*-----( Import needed libraries )-----*/
// Get 1-wire Library here: http://www.pjrc.com/teensy/td_libs_OneWire.html
#include <OneWire.h>
//Get DallasTemperature Library here:  http://milesburton.com/Main_Page?title=Dallas_Temperature_Control_Library
#include <DallasTemperature.h>
/*-----( Declare Constants and Pin Numbers )-----*/
#define ONE_WIRE_BUS_PIN 7
/*-----( Declare objects )-----*/
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS_PIN);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
/*-----( Declare Variables )-----*/
// Assign the addresses of your 1-Wire temp sensors.
// See the tutorial on how to obtain these addresses:
// http://www.hacktronics.com/Tutorials/arduino-1-wire-address-finder.html
DeviceAddress Probe00 = { 0x28, 0x18, 0x64, 0xAA, 0x04, 0x00, 0x00, 0xC6 };
DeviceAddress Probe01 = { 0x28, 0xE6, 0x4F, 0x08, 0x03, 0x00, 0x00, 0xFB };
DeviceAddress Probe02 = { 0x28, 0x7A, 0x60, 0x08, 0x03, 0x00, 0x00, 0xA0 };
DeviceAddress Probe03 = { 0x28, 0x9A, 0x47, 0xAA, 0x04, 0x00, 0x00, 0xF4 };
DeviceAddress Probe04 = { 0x28, 0x55, 0x52, 0xAA, 0x04, 0x00, 0x00, 0xE1 };
DeviceAddress Probe05 = { 0x28, 0xD8, 0x34, 0xAB, 0x04, 0x00, 0x00, 0x43 };
DeviceAddress Probe06 = { 0x28, 0x53, 0x44, 0xAA, 0x04, 0x00, 0x00, 0xB3 };
DeviceAddress Probe07 = { 0x28, 0x5B, 0x70, 0xAA, 0x04, 0x00, 0x00, 0x89 };
DeviceAddress Probe08 = { 0x28, 0x18, 0x76, 0xAB, 0x04, 0x00, 0x00, 0xB6 };
DeviceAddress Probe09 = { 0x28, 0xA3, 0x75, 0xAB, 0x04, 0x00, 0x00, 0x07 };
DeviceAddress Probe10 = { 0x28, 0xA3, 0xE6, 0xAA, 0x04, 0x00, 0x00, 0x71 };
//End of 1-wire initialisation
* Simplest possible example of using RF24Network
* TRANSMITTER NODE
* Every 2 seconds, send a payload to the receiver node.
 #include <RF24Network.h>
 #include <RF24.h>
 #include <SPI.h>
// nRF24L01(+) radio attached using Getting Started board
 RF24 radio(9,10);            //CE, CSN connections on NRF24L01 board for Uno
// Network uses that radio
 RF24Network network(radio);
// Address of our node
 const uint16_t this_node = 1;
// Address of the other node
 const uint16_t other_node = 0;
// How often to send 'hello world to the other unit
 const unsigned long interval = 1000; //ms
// When did we last send?
 unsigned long last_sent;
// How many have we sent already
 unsigned long packets_sent;
// Structure of our payload
 struct payload_t
  byte data;
//End of nRF24L01 initialisation
void setup()   /****** SETUP: RUNS ONCE ******/
 // start serial port to show results
 Serial.print("Initializing Temperature Control Library Version ");
 Serial.println(DALLASTEMPLIBVERSION);
 // Initialize the Temperature measurement library
 sensors.begin();
 // set the resolution to 10 bit (Can be 9 to 12 bits .. lower is faster)
 //9>>0.5C steps, 10>>0.25C steps, 11>>0.125C steps, 12>>0.06C steps
 sensors.setResolution(Probe00, 10);
 sensors.setResolution(Probe01, 10);
 sensors.setResolution(Probe02, 10);
 sensors.setResolution(Probe03, 10);
 sensors.setResolution(Probe04, 10);
 sensors.setResolution(Probe05, 10);
 sensors.setResolution(Probe06, 10);
 sensors.setResolution(Probe07, 10);
 sensors.setResolution(Probe08, 10);
 sensors.setResolution(Probe09, 10);
 sensors.setResolution(Probe10, 10);
  Serial.println("RF24Network/examples/helloworld_tx/");
 SPI.begin();
 radio.begin();
 network.begin(/*channel*/ 90, /*node address*/ this_node);
}//--(end setup )---
void loop()   /****** LOOP: RUNS CONSTANTLY ******/
 delay(2000);
 Serial.print("Number of Devices found on bus = ");
 Serial.println(sensors.getDeviceCount());
 Serial.print("Getting temperatures... ");
 // Command all devices on bus to read temperature
 Serial.print("Probe 00 temperature is:   ");
 printTemperature(Probe00);
 Serial.print("Probe 01 temperature is:   ");
 printTemperature(Probe01);
 Serial.print("Probe 02 temperature is:   ");
 printTemperature(Probe02);
 Serial.print("Probe 03 temperature is:   ");
 printTemperature(Probe03);
 Serial.print("Probe 04 temperature is:   ");
 printTemperature(Probe04);
 Serial.print("Probe 05 temperature is:   ");
 printTemperature(Probe05);
 Serial.print("Probe 06 temperature is:   ");
 printTemperature(Probe06);
 Serial.print("Probe 07 temperature is:   ");
 printTemperature(Probe07);
// Pump the network regularly
 network.update();
// If it's time to send a message, send it!
 unsigned long now = millis();
 if ( now - last_sent >= interval  )
   last_sent = now;
//The union
 union stuff
  int temps[8];
  byte data[16];
//An instance
int temp0 = (sensors.getTempCByIndex(00));     //used for testing
int temp1 = (sensors.getTempCByIndex(01));    //used for testing
int temp2 = (sensors.getTempCByIndex(02));     //used for testing
int temp3 = (sensors.getTempCByIndex(03));     //used for testing
int temp4 = (sensors.getTempCByIndex(04));     //used for testing
int temp5 = (sensors.getTempCByIndex(05));     //used for testing
int temp6 = (sensors.getTempCByIndex(06));     //used for testing
int temp7 = (sensors.getTempCByIndex(07));     //used for testing
stuff myStuff;
//Get the temperatures, and store them
myStuff.temps[1] = temp1;
myStuff.temps[2] = temp2;
myStuff.temps[3] = temp3;
myStuff.temps[4] = temp4;
myStuff.temps[6] = temp6;
myStuff.temps[7] = temp7;
 Serial.print("Sending...");
 Serial.print(myStuff.temps[0]);
 payload_t payload = { /*millis(), packets_sent++,*/myStuff.data[16]};
 RF24NetworkHeader header(/*to node*/ other_node);
 bool ok = network.write(header,&payload,sizeof(payload));
if (ok)
     Serial.println("ok.");
     Serial.println("failed.");
// vim:ai:cin:sts=2 sw=2 ft=cpp
//The payload to send, then, is myStuff.data, with a size of 12 bytes.
//On the other end, you'd use myStuff.data as the receive buffer and read the values using myStuff.temps[n] to get the nth temperature.
}//--(end main loop )---
/*-----( Declare User-written Functions )-----*/
void printTemperature(DeviceAddress deviceAddress)
int tempC = sensors.getTempC(deviceAddress);
  if (tempC == -127.00)
  Serial.print("Error getting temperature  ");
  Serial.print("C: ");
  Serial.print(tempC);
  Serial.print(" F: ");
  Serial.print(DallasTemperature::toFahrenheit(tempC));
}// End printTemperature
//*********( THE END )***********
dominator99
Hi PaulS
Here's the Rx part
Code: [Select]
//Arduino Meaga2560 as receiver
Copyright (C) 2012 James Coliz, Jr. <maniacbug@ymail.com>
This program is free software; you can redistribute it and/or
modify it under the terms of the GNU General Public License
version 2 as published by the Free Software Foundation.
* Simplest possible example of using RF24Network,
* RECEIVER NODE
* Listens for messages from the transmitter and prints them out.
  #include <RF24.h>
  #include <SPI.h>
  RF24 radio(9,53);            //CE, CSN connections on NRF24L01 board for Mega2560
  const uint16_t this_node = 0;
  const uint16_t other_node = 1;
  struct payload_t
  int temps;
  byte data;
void setup(void)
  Serial.println("RF24_Network_Rx");
  SPI.begin();
  radio.begin();
void loop(void)
  network.update();
//The union
  union stuff
   int temps[8];
   byte data[16];
//An instance
  stuff myStuff;
// Is there anything ready for us?
  while ( network.available() )
// If so, grab it and print it out
    RF24NetworkHeader header;
    payload_t payload;
    network.read(header,&payload,sizeof(payload));
    Serial.println("Received packets ");
  int temp0 = myStuff.temps[0];
  int temp1 = myStuff.temps[1];
  int temp2 = myStuff.temps[2];
  int temp3 = myStuff.temps[3];
  int temp4 = myStuff.temps[4];
  int temp5 = myStuff.temps[5];
  int temp6 = myStuff.temps[6];
  int temp7 = myStuff.temps[7];
  Serial.println(temp0);
  Serial.println(temp1);
  Serial.println(temp2);
  Serial.println(temp3);
  Serial.println(temp4);
  Serial.println(temp5);
  Serial.println(temp6);
  Serial.println(temp7);
PaulS
payload_t is defined to be a struct of one byte. You are then creating an instance of that struct, called payload, and assigning it the value in the 17th position of a 16 element array.
The structure payload_t needs to be 16 bytes long. The 16 bytes in the myStuff.data array need to be COPIED to the 16 byte array in the payload_t instance.
dominator99
Hi PaulS
sorry for being a bit 'thick' but I don't understand your reply :(
PaulS
Look at the definition of payload_t:
Code: [Select]
  struct payload_t
   byte data;
The size of the payload is one byte. That is NOT the size that you want, is it?
Make data an array of the needed size.
Quote
here:
Code: [Select]
Quote
Here:
Code: [Select]
myStuff.data[16]
The data member of the stuff union is an array that can hold 16 elements. The indexes into that array run from 0 to 15. [16] is the 17th element of the array, and is out of bounds.
The payload instance will contain an array, when you define payload_t correctly. The data you want to send is in an array, myStuff.data. To get data from one array to another, you have to copy it. You could use memcpy() or a for loop. The for loop is more intuitive, in my opinion, although memcpy() will be faster. Only marginally, though, since it uses a for loop, too.
dominator99
Hi PaulS
I can't get the last copy routine to work.
I've set structure payload_t to:-
Code: [Select]
  struct payload_t
  byte data[16];
I've set payload_t payload to:-
Code: [Select]
payload_t payload = {myStuff.data[16]};
I've set the array myStuff.data[16]
As I understand it, the array myStuff.data holds 16 bytes (0-15) of temp data (2 bytes per temp reading) so how do I get 8 temp readings out from these 16 bytes?
I've tried to read data using:-
Code: [Select]
byte temps[16];
int i = 0;
for (i; i < 16; i=i+1)
  temps[i] = myStuff.data[i];
  Serial.println(temps[i]);
But this doesn't print out the correct temps
I seem to be going nowhere with this :(
PaulS
Quote
Good.
Quote
Bad.
Go back and read what I have written, again. You are still referring to a SINGLE element that is not in the range of valid elements.
Quote
What, specifically, does this mean? One doesn't "set an array". One values the elements in an array or populates an array.
Quote
Yes.
Quote
Exactly the same as you put them in.
The code that reads from the radio is populating the byte part of the union instance. Then, you copy the int part to other place(s).
Quote
Of course not. You need the same union on the receiver, too. You copy the data received into the byte part of the union instance, and read the int part as the temperatures.
