Pages: [1]   Go Down
Author Topic: Arduino Ethernet Shield compatibility?  (Read 948 times)
Pasig City, Philippines
Offline Offline
Newbie
I enjoy doing Simple Things!
View Profile
WWW
Hello World!
Sometime today, I'll be receiving my Arduino Due and I have a question on using my Wiznet Ethernet Shield from Seeedstudio (clone of Arduino Ethernet Shield). I've read that the Arduino Ethernet Shield (W5100) uses 5VDC; will that be a problem for the Due? I do want to smoke my Due with overvoltage.
Also, will I be able to use the Ethernet library with the Due?
Thanks in Advance,
Marcos "Kuya Marc" Miranda
Logged
I run Xubuntu Linux as my only computer operating system!
Windows does not run here; Only
Offline Offline
Full Member
View Profile
It looks to me like the Ethernet Shield is NOT 3.3V compatible, I suggest don't connect it to Due.
There does seem to be an implementation of Ethernet library for Due, whether it works or not is a question. I can't see how it would have been tested with a Due/Ethernet shield, unless there is an unannounced 3.3V version in the works.
ETA: clarify wording
Logged
Please don't PM me asking for help. Ask questions in the forum.
nr Bundaberg, Australia
Online Online
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
Yes, the Ethernet shield is does not appear to be 3v3 compatible as is, at first glance because the SPI signals are down shifted for the SD card.
The W5100 however is a 3v3 chip with 5v tolerant inputs so it should work, if you don't need the SD card you might get away with it although there may be something else I didn't spot in the schematic.
_____
Rob
Logged
Rob Gray aka the GRAYnomad www.robgray.com
Offline Offline
Newbie
View Profile
WWW
Ok, thanks for the feedback.
Marcos
Logged
Pages: [1]   Go Up
Jump to:
