Topic: sorting problem (Read 1 time) previous topic - next topic
tacet777
I can't think and search of a way how to sort my data "m:sec:mm".
Code: [Select]
int m[] = {9, 24, 25};
int sec[] = {19, 34, 27};
int mm[] = {39, 46, 50};
void loop(){
    char s1[10];
    char s2[10];
    char s3[10];
    sprintf(s1, "%02d:%02d:%02d", m[1], sec[1], mm[1]);      //put m,sec,mm value to s with formating of m:sec:mm
    sprintf(s2, "%02d:%02d:%02d", m[2], sec[2], mm[2]);      //put m,sec,mm value to s with formating of m:sec:mm
    sprintf(s3, "%02d:%02d:%02d", m[3], sec[3], mm[3]);      //put m,sec,mm value to s with formating of m:sec:mm
the code above produces:
s1 = 09:19:39
s2 = 24:34:46
s3 = 25:27:50
and i wanted to sort it from highest to lowest.
thanks in advance
PaulS
Code: [Select]
Array indices start at 0, not 1.
Quote
You want to sort what? The resulting strings?
What have you tried?
tacet777
i tried using atoi() to convert the string s1,s2,s3 but it returns 24,25,19. which doesn't make sense in my sorting.
here's what i've been working...it stores time for every player, and displays their time at the end of the program, but i wanted to sort the data "m:sec:mm" from highest to lowest then display who has the slowest time to the fastest time.
Code: [Select]
#include <LiquidCrystal.h>                  //LCD library
LiquidCrystal lcd(3, 5, 9, 10, 11, 12);     //LCD Pin initialization
int numPlayer = 0;                          //variable for number of player
int i = 0;                                  //incrementing variable for saving to array record
 lcd.begin(16,2);                          //sets the display to have 16x2 display
 pinMode(6, INPUT);                        //pin 6 input
 pinMode(7, INPUT);                        //pin 7 input
void loop(){
 while (digitalRead(7) == HIGH){           //while pin 7 is high ask for number of players
   lcd.setCursor(0, 0);                    //sets the cursor of the LCD display to 0,0
   lcd.print("# of Players");              //prints the "# of players" on the LCD display
   if (digitalRead(6) == LOW){             //when pin 6 is press do numplayer++
     numPlayer++;                          //increment the number of player
     delay(500);                           //set delay so that pressing 6 will ensure +1 increment
   lcd.setCursor(0, 1);                    //sets the cursor of the LCD display to 0,1
   lcd.print(numPlayer);                   //prints the value of numPlayer on the LCD display
 int mmRecord[numPlayer];                  //create array with size of numplayer
 int secRecord[numPlayer];                 //create array with size of numplayer
 int mRecord[numPlayer];                   //create array with size of numplayer
timeStart:                                  //label where the time starts
 lcd.clear();                              //clears the display
 lcd.setCursor(7, 0);                      //sets the cursor of the LCD display to 0,1
 lcd.print("Lap Time:");                   //prints the "Lap Time:" on the LCD display
 for (int m = 0; m < 60; ++m) {            //minute is initially 0 and increments until m is 60 or greater
   for (int sec = 0; sec < 60; ++sec) {    //second is initially 0 and increments until sec is 60 or greater
     for (int mm = 0; mm < 100; ++mm) {    //milli is initially 0 and increments until mm is 100 or greater
       display_LCD(m,sec,mm);              //call function display_LCD()
       delay(10);                          //set delay(10)
       if (digitalRead(6) == LOW){         //when pressed have to mm,sec,m arrays
         if ( i != numPlayer){             //condition when i is not equal to numplayer do commands below
           mmRecord[i] = mm;               //mm array
           secRecord[i] = sec;             //sec array
           mRecord[i] = m;                 //m array
           i++;                            //i increment
           lcd.clear();                    //clear LCD
           while (digitalRead(7) == HIGH){ //while pin 7 is high do commands below
             lcd.print("Click button 2");
             lcd.print("to Start Next");
             delay(100);
           goto timeStart;
       if ( i == numPlayer){
         lcd.clear();
         lcd.print("Game Finish");
         lcd.print("Time Recap");
         delay(2000);
         for (int j = 0 ; j < i ; j++) {
           lcd.clear();
           lcd.print("Player");
           lcd.print(j+1); //displays Player #
           display_LCD(mRecord[j],secRecord[j],mmRecord[j]);  //display time for Player #
           delay(3000);
void display_LCD(int m, int sec, int mm){        //create function for printing m:sec:mm format
 char s[10];                                    //array for character number for m:sec:mm
 sprintf(s, "%02d:%02d:%02d", m, sec, mm);      //put m,sec,mm value to s with formating of m:sec:mm
 lcd.setCursor(8, 1);                           //sets the cursor of the LCD display to 8,1
 lcd.print(s);                                  //prints the value of s on the LCD display
UKHeliBob
When dates and times need to be sorted they are usually held as YYYYMMDDHHmmSSms and converted to a readable format only when displayed or printed.  The format allows natural sorting either high to low or vice versa.
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
tacet777
can you explain further, sample codes would be nice...thank you..
PaulS
Quote
Of course, since the parsing stops at the first non-numeric character.
You can sort the data before creating the string(s) or after. Since this code appears to create just one string at a time, sorting afterwards won't work.
You'd then need to sort mRecord, secRecord, and mmRecord before creating the strings. You probably want to create another array to store player number, and sort all 4 arrays together. Sorting mRecord is pretty simple. What you need to remember to do, though, is change all 4 arrays when one pair of values is found to be out of order in mRecord.
Once the data in mRecord is in order (increasing or decreasing as you see fit), then look at records in secRecord that have the same value in mRecord, and sort them, swapping positions in mmRecord and player number, too.
Once the data in mRecord and secRecord are sorted, then look at records in mmRecord that have the same value in secRecord. Sort them, swapping positions in player number, too.
tacet777
Quote
yes i get the point of this, but the problem is i don't know how to implement it...i don't know how swapping works in C language.
PaulS
Quote
Think about what it means for records to be in order vs. out of order.
If you want largest to smallest, then records are out of order when a smaller value (in (n+1]) follows a larger value (in [n]):
Code: [Select]
if(mRecord[n+1] < mRecord[n])
   // swap the record(s)...
Quote
Swapping the values in mRecord only:
Code: [Select]
   int temp = mRecord[n+1];
   mRecord[n+1] = mRecord[n];
   mRecord[n] = temp;
AWOL
Quote
Bonus marks for avoiding the temporary variable, and using XOR.  :D
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
PaulS
Quote
Not for me. I like clear and obvious code.
tacet777
Quote
Code: [Select]
Quote
Code: [Select]
   mRecord[n] = temp;
thanks for the information, I think I know what to do now...
AWOL
The bonus marks weren't for you, Paul.   ;)
tacet777
Quote
what do you mean bonus marks, never heard of them
KeithRB
bonus marks are extra credit.
And the C library provides a sorting routine: qsort(). Since you provide the function that does the comparison, the dates can be in any format, and your comparison routine just has to figure it out.
UKHeliBob
Quote
What I had in mind was to hold the times in a single array rather than three with the values in the array to be in SSMMMS format, perhaps created by using sprintf and atol to turn the values into longs which would allow the array to be sorted easily.
When a time is required for display or printing it is converted back.  Depending on your requirements and how many time you are dealing with this method may or may not be applicable because of the overheads of conversion between the 2 formats.
