Topic: Mouse.click() does not work (Read 2312 times) previous topic - next topic
a4rashid
I am running the following code to move the mouse and click it using input from the keyboard:
  // initialize serial communications at 9600 bps:
  Mouse.begin();
  // use serial input to control the mouse:
  if (Serial.available() > 0) {
    char inChar = Serial.read();
    Mouse.begin();
    switch (inChar) {
    case 'u':
      // move mouse up
      Serial.println("u received");
      Mouse.move(0, -40);
      break;
    case 'd':
      // move mouse down
      Mouse.move(0, 40);
      break;
    case 'l':
      // move mouse left
      Mouse.move(-40, 0);
      break;
    case 'r':
      // move mouse right
      Mouse.move(40, 0);
      break;
    case 'm':
      // perform mouse left click
      Mouse.click(MOUSE_LEFT);
      break;
When I run my code on the Arduino Due, and send 'u' on the serial port for example, which should move my mouse cursor up, nothing at all happens. Same goes for Mouse.click(). I have no idea what I'm doing incorrectly.
nickgammon
Once you have configured the Leonardo to be a mouse, it cannot also communicate via serial comms at the same time. It is either a serial port or a mouse (or a keyboard, etc.).
More info:
a4rashid
OK, so does that mean I have to have a "Serial.end()" segment before I do a "Mouse.begin()" every time?
a4rashid
Also, this example on the Arduino website seems to be doing exactly this:
http://arduino.cc/en/Tutorial/KeyboardAndMouseControl
nickgammon
Oh, OK. Looks like I was wrong. Well, not the first time, eh?
I just tested that on my Leonardo (the example you linked to). So you are right, it can do both.
But I don't know about the Due. I'll move this thread to the Due part of the forum.
More info:
cmaglie
a4rashid,
with the Arduino Due the Serial class communicate with the Programming Port.
If you have connected your PC on the Due's Native Port you shoud use the SerialUSB object
(this means that you must replace all the Serial with SerialUSB in your sketch).
C.
