Topic: Getting 5V D/C from single live wire A/C light switch (Read 10096 times) previous topic - next topic
stan001
How do I tap 5V D/C from a single live wire A/C from a light switch without turning on the light ?
Something like the attached picture ...
fungus
Very carefully.
Seriously: If you don't know how, maybe you shouldn't be doing it.
Grumpy_Mike
It depends on what sort of current and if you need isolation. But if you have to ask about it then no you can't do it. Or at least you should not. Ever seen the Darwin awards?
nickgammon
Some guy attached a lot of helium balloons to his deck chair, and he floated up into the air with a shotgun in his hand to burst the balloons if they got too high.
Needless to say, the system did not work the way he planned.
JimboZA
the way he planned
Although "planned" might be too kind a word: "expected" maybe? Or even "hoped"....
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
billhowl
How current flow on only single wire?
CrossRoads
Connect a 5V DC wallwart in parallel with the light bulb.
http://www.dipmicro.com/store/DCA-0510
When the light bulb gets power, the wallwart gets power.
JimboZA
Zen-power
billhowl
But OP need 5V DC without turnung on the light
majenko
Zen-power
It's those pesky Zen diodes again, isn't it?
majenko
Take out the lightbulb?
retrolefty
Without access to both the AC line and neutral wires one cannot extract power for anything. It's like a bird sitting on a bare 2KV utility wire, nothing  dramatic happens to the bird because there in no current path.  ;)
Lefty
Riva
How do the 'no neutral wire' X10 modules like this do it?
Grumpy_Mike
There is a signal path through the load. But with not enough signal to actually do anything with the load.
billhowl
It get the return path through the lamp.
Incandescent (2-wire) switch can only control resistive load ?40W (incandescent lamp or halogen lamps, etc). It
cannot control inductive or capacitive Load (like: Fluorescent lamps?save-energy lamps etc).
