Topic: Arduino duemilanove se resetea (Read 968 times) previous topic - next topic
juanvivo
Pues estoy probando codigo para un lcd 16x2 para implementarlo en otro proyecto mayor. He hecho unas pruebas con el codigo de ejemplo de liquid crystal:
Code: [Select]
  LiquidCrystal Library - Hello World
Demonstrates the use a 16x2 LCD display.  The LiquidCrystal
library works with all LCD displays that are compatible with the
Hitachi HD44780 driver. There are many of them out there, and you
can usually tell them by the 16-pin interface.
This sketch prints "Hello World!" to the LCD
and shows the time.
  The circuit:
* LCD RS pin to digital pin 12
* LCD Enable pin to digital pin 11
* LCD D4 pin to digital pin 5
* LCD D5 pin to digital pin 4
* LCD D6 pin to digital pin 3
* LCD D7 pin to digital pin 2
* LCD R/W pin to ground
* 10K resistor:
* ends to +5V and ground
* wiper to LCD VO pin (pin 3)
Library originally added 18 Apr 2008
by David A. Mellis
library modified 5 Jul 2009
by Limor Fried (http://www.ladyada.net)
example added 9 Jul 2009
by Tom Igoe
modified 22 Nov 2010
by Tom Igoe
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/LiquidCrystal
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print("hello, world!");
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  lcd.setCursor(0, 1);
  // print the number of seconds since reset:
  lcd.print(millis()/1000);
El caso es que cada pocos segundos el arduino se resetea. He probado a imprimir algunas cosas y resultas que si entro al monitor serie para ver laslineas que va imprimiendo no se resetea. Pero en el momento en que salgo del monitor serie, vuelve a reiniciar cada pocos segundos...
He probado con otro duemilanove que tengo y le pasa lo mismo...
Podeis decirme a que se debe?
Un saludo y gracias por vuestro tiempo...
curro92
Hola,
cada vez que abres el monitor serie, el Arduino que esté conectado se resetea. ¿No será eso lo que ocurre?
Lisergio
Prueba a inicializar el puerto serie a 9600...
No se porque, pero a mi algún sketch me ha dado guerra aun sin utilizarlo, pero al inicializarlo a funcionado bien...
  lcd.begin(16, 2);
  lcd.print("hello, world!");// Print a message to the LCD.
Se que no es lógico... pero podría ser
juanvivo
Se resetea si no esta el monitor serie abierto... estando alimentado por usb.
Si lo alimento de forma externa parece que no se reinicia.
LO de iniciar el serie ya lo he hecho y se reinicia igual...
