Topic: Scheduler and U8glib on DUE (Read 9943 times) previous topic - next topic
olikraus
Thanks for your feedback. I have created an issue: http://code.google.com/p/u8glib/issues/detail?id=155
Oliver
cmaglie
It would be better if the initialization code is placed into a begin() function.
Many arduino libraries does it this way, you know exactly when the initialization is done,
and avoids you to hit the "C++ static initialization order fiasco".
http://www.parashift.com/c++-faq/static-init-order.html
C.
olikraus
Well, yes, and indeed the modification of u8g_Delay() is more a workaround (or hack) instead of a good solution. To excause the current situation a little bit: I never read in the Arduino documentation that some of the procedures are not valid to be called during constructor time. And on the ATMEGA it was never a problem to call digitalWrite() or delay() in the constructor.
For the port to the Arduino Due i also had to deal with this problem because of some other conflicts. U8glib already has a begin() procedure. But u8glib has not been completly redesigned for it. So to say, i am on the half way of a complete redesign of the internal architecture without changing much of the existing API.
So to conclude this:
I was not aware of this problem in the past, but now i do my very best to update U8glib.
My suggestion to the Arduino Project: Please clearly state that delay() and digitalWrite() must not be used in any construtor calls.
Oliver
cmaglie
olikraus,
you don't need to justify, initializations (with digitalWrite and delays) in the constructors should be legal.
The issue here is that delay() didn't work until the Arduino initialization is done in main() and C++ starts constructors of static objects before the main! I got some problems with the LiquidCrystal library because of that:
https://github.com/arduino/Arduino/blob/master/libraries/LiquidCrystal/LiquidCrystal.cpp#L27
and the solution was:
https://github.com/arduino/Arduino/commit/d994e48c5565a0c7aea54384a1b15a19623fe209
but for some reason the scheduler has still some interactions I didn't considered that should be looked into.
So, in the end, consider my previous post just a hint to workaround these troubles... :)
C.
olikraus
Hi cmaglie
Regarding your link to the LiquidCrystal lib: I had a similar problem with init of the display within u8glib.
After constructor calls, the Arduino Due will reset all I/O pins. This problem still exists in 1.5.2.
Oliver
alvesjc
Hi.
I'm trying to implement the scheduler in my project, but the behaviour is not what I was expecting.
Due runs a lot of times the main loop, and sometimes the second loop.
But when it does, there isn't a consistent number of runs.
What I has expecting, was it to run main loop, then 2nd loop, then main loop, then 2nd loop, and so on.
What I get from the debug is this: ( number is the corresponding runtime in millis for the loop)
loop1   1
loop1   1
loop1   0
loop1   1
loop   135
loop   125
loop   125
loop   126
loop   125
loop   125
loop   126
loop   125
loop   125
loop   125
loop   125
loop   126
loop   125
loop   125
loop   126
loop   125
loop1   0
loop1   1
loop1   0
loop1   1
loop   130
loop   125
loop   125
loop   125
loop   125
loop   126
loop   125
loop   125
loop   126
loop   125
loop   125
loop   125
loop   125
loop   126
loop   125
loop   125
loop1   1
loop1   0
loop1   1
loop1   1
loop   135
loop   126
loop   125
loop   125
loop   167
loop   125
loop   125
loop   125
loop   126
loop   125
loop   125
loop   126
loop   125
loop   125
loop   125
loop   125
loop1   1
loop1   0
loop1   1
loop   130
loop   125
loop   125
loop   125
loop   125
loop   126
loop   125
loop   125
loop   126
loop   125
loop   126
loop   125
loop   125
loop   126
loop   125
loop   125
loop1   1
loop1   1
loop1   0
loop1   1
loop   135
loop   125
loop   125
loop   167
loop   125
loop   126
loop   125
loop   125
loop   125
loop   125
loop   126
loop   125
loop   125
loop   126
loop   125
loop   125
loop1   1
loop1   1
Am I missing something here?
www.aqualedsource.com
pylon
Quote
The Scheduler is used for cooperative multitasking and not a preemptive one as you was expecting. Read here about the differences: http://en.wikipedia.org/wiki/Computer_multitasking
alvesjc
Thank you Pylon for pointing me in right direction. I think its clear now, but I'll read it again.
To solve my problem, I've built a scheduler with a switch. With this I run only one time consuming function per loop.
I've dropped the loop time from 120millis to 10 millis average.
Regards
Joao
