Topic: 2 motors controlled by one joystick (Read 35700 times) previous topic - next topic
GBissell
i could really use some help with my arduino project it is 2 motors controlled in tandem by a joystick, or it would be if i could get it to work. i have a code for the motors to run separately it is this:
#include <Servo.h>
const int servo1 = 3;       // first servo
const int servo2 = 10;       // second servo
const int joyH = 3;        // L/R Parallax Thumbstick
const int joyV = 4;        // U/D Parallax Thumbstick
int servoVal;           // variable to read the value from the analog pin
Servo myservo1;
Servo myservo2;
  myservo1.attach(servo1);
  myservo2.attach(servo2);
void loop(){
    outputJoystick();
    servoVal = analogRead(joyH);
    servoVal = map(servoVal, 0, 1023,1000, 1750);
    myservo2.write(servoVal);
    servoVal = analogRead(joyV);
    servoVal = map(servoVal, 0, 1023, 1250, 1750);
    myservo1.write(servoVal);
    delay(15);
* Display joystick values
void outputJoystick(){
    Serial.print(analogRead(joyH));
    Serial.print ("---");
    Serial.print(analogRead(joyV));
    Serial.println ("----------------");
but what i need it to do is run both of the DC motors in tandem and the bot needs to be able to make zero point turns. any help at all would be extremely helpful, thank you for your time
AWOL
Quote
"Tandem" implies, to me, one behind the other, so I don't see how you could make a zero turn.
Please use code tags when posting code.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
GBissell
sorry i meant i need them both to run parallel to each other at the same time, any advice?
zoomkat
Does this mean you want the servos to turn in opposite directions to make the zero point turns? If so, does your joystick have a trigger or button?
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
GBissell
yes i want them to go opposite directions when making the turns and, no it does not have a trigger or switch. is it possible to make them both go the same way when the joystick is in the forward or backwards positions and go opposite directions when in the left or right positions? if so please help, any advice for coding this would be appreciated.
zoomkat
The problem you may have with your setup is that a joystick is capable of having both your forward/reverse and turn commands at the same time (like joystick pushed forward and to the left at the same time). You might put the stick shaft in a + cutout such that the joystick can't be put in a diagonal position. A code fix might be possible by making exclusive loops for forward/reverse and turning.
dotrar
im not actually sure about this because im new and i havent tried it. but you can try and add the Horizontal and Vertical values together to produce a factor which the motors move.
Code: [Select]
RightMotorValue = Vertical - Horizontal;
LeftMotorValue = Vertical + Horizontal;
so when the joystick is all the way to the left, R = 0 - (-joyval), L = 0 + (-joyval) making it turn left.
the only problem with this method is when the joystick is on one of the corners you get double the joyval.
GBissell
this might seem like an odd question but regardless, is it possible to use the style of code that i have been using to run the motors parallel at all times? if so does anyone have any advice how? Ive become stuck.
zoomkat
If you mean have the opposite side continuous rotation servos move forward and reverse together, then the below is a usual way where the pot value is mapped to 0-180 deg.
Code: [Select]
myservo1.write(n);
myservo2.write(180-n);
GBissell
it worked...kinda, the code made the 1 run continually in reverse, what i need is for when the joystick value is above the center value heading forward on the joystick to have both motors run forward (same idea in reverse), and when the joystick is headed left the two values are one half of the value forward for one motor and the other motors value is half the value going backwards. sorry if i seem clueless as i kinda am towards complex programming. once again any help would be appreciated.
PaulS
Quote
You go first. Post the code you have.
The change you propose was what I considered when I first read your topic. They should be easy to implement.
The only issue with your proposal is that you won't be able to spin on a dime.
If, instead, you use the left and right amount as a differential to be applied to both motors (one positive, one negative), then when the stick is centered fore and aft (at the midpoint of the throw), then you can still have a positive and negative wheel speed, and can spin in place. The speed at which you spin is related to how far left or right you move the stick. Which way you move the stick controls the direction of spin.
GBissell
Code: [Select]
#include <Servo.h>
int servoVal1;           // variable to read the value from the analog pin
int servoVal2;
int servoVal3;           // variable to read the value from the analog pin
int servoVal4;
Servo myservo1;  // create servo object to control a servo
Servo myservo2;  // create servo object to control a servo
  // Servo
  myservo1.attach(servo1);  // attaches the servo
  myservo2.attach(servo2);  // attaches the servo
  // Inizialize Serial
void loop(){
    // Display Joystick values using the serial monitor
    outputJoystick();
    servoVal3 = analogRead(joyV);
    servoVal4 = analogRead(joyV);
    servoVal3 = map(servoVal3, 0, 1023,1000, 1750);     // scale it to use it with the servo (result  between 0 and 180)
    servoVal4 = map(servoVal4, 0, 1023, 1250, 1750);     // scale it to use it with the servo (result between 70 and 180)
    // Read the horizontal joystick value  (value between 0 and 1023)
    servoVal1 = analogRead(joyH);
    servoVal2 = analogRead(joyH);
    servoVal1 = map(servoVal1, 0, 1023,1000, 1750);     // scale it to use it with the servo (result  between 0 and 180)
    servoVal2 = map(servoVal2, 0, 1023, 1250, 1750);     // scale it to use it with the servo (result between 70 and 180)
    myservo2.write(servoVal1);                         // sets the servo position according to the scaled value
    myservo1.write(servoVal2);
delay(15);                                       // waits for the servo to get there
this is the new code i came up with to run the robot to make zero point turns, the issue is now that i cant figure out how to make the bot run in parallel when moving forwards and backwards, any ideas?
zoomkat
Below is some pot test code. You might make something similar using "while" loops to trap the input of one of the pots while it is not centered, excluding any control input from the other pot. That should prevent control conflicts between forward/reverse and clockwise/counterclockwise servo operation.
Code: [Select]
//zoomkat dual pot/servo test 12-29-12
//view output using the serial monitor
#include <Servo.h>
Servo myservo1;
Servo myservo2;
int potpin1 = 0;  //analog input pin A0
int potpin2 = 1;
int newval1, oldval1;
int newval2, oldval2;
  myservo1.attach(2);
  myservo2.attach(3);
  Serial.println("testing dual pot servo");
  newval1 = analogRead(potpin1);
  newval1 = map(newval1, 0, 1023, 0, 1;
  if (newval1 < (oldval1-2) || newval1 > (oldval1+2)){
    myservo1.write(newval1);
    Serial.print("1- ");
    Serial.println(newval1);
    oldval1=newval1;
  newval2 = analogRead(potpin2);
  newval2 = map(newval2, 0, 1023, 0, 179);
  if (newval2 < (oldval2-2) || newval2 > (oldval2+2)){
    myservo2.write(newval2);
    Serial.print("2- ");
    Serial.println(newval2);
    oldval2=newval2;
  delay(50);
HazardsMind
I did something simular with DC motors. It uses 2 variable "z" -forward movement and "y" - left and right movement.
Note this is only a snip of the full code, the rest is just receiving the data and sending it to here. You may also be able to alter it to use servos instead of DC motors.
Hope this gives you some ideas.
Code: [Select]
int DRV2 = map(z, -15, 0, 255, 0);
  int DRV1 = map(z, 0, 15, 0, 255);
  int STRL = map(y, -10, 0, 255, 0);
  int STRR = map(y, 0, 10, 0, 255);
  //constrain((DRV1,DRV2,STRL,STRR),0,255);
/*Serial.print(DRV1);
Serial.print(",");
Serial.print(DRV2);
Serial.print(",");
Serial.print(STRL);
Serial.print(",");
Serial.print(STRR);
//Serial.print(",");
//Serial.print(y);
Serial.println();*/
  if(z > 0)//forwards with skew left or right
    //Serial.println("Driving");
    analogWrite(M1L, constrain(abs(DRV1 - STRL),0,255)); analogWrite(M1R, constrain(abs(DRV1 - STRR),0,255));
    digitalWrite(M2L, LOW);                                             digitalWrite(M2R, LOW);
  else if(z < 0)//backwards with skew left or right
    digitalWrite(M1L, LOW);                                             digitalWrite(M1R, LOW);
    analogWrite(M2L, constrain(abs(DRV2 - STRL),0,255)); analogWrite(M2R, constrain(abs(DRV2 - STRR),0,255));
   else if(z < 4 && z > -4 && y > 0)//Right   (+-4 = limits before movement)
    digitalWrite(M2L, LOW); analogWrite(M2R, STRR);
    analogWrite(M1L, STRR); digitalWrite(M1R, LOW);
  else if(z < 4 && z > -4 && y < 0)//Left
    analogWrite(M2L, STRL); digitalWrite(M2R, LOW);
    digitalWrite(M1L, LOW); analogWrite(M1R, STRL);
  else //full stop
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
GBissell
Code: [Select]
#include <Servo.h>
int servoVal2;
int servoVal4;
  // Servo
void loop(){
    outputJoystick();
i managed to get the 2 motors to make zero point turns, however i now cant get any headway into running at the same time to go forwards and backwards. any ideas/ help would be massively appreciated.
