Topic: 2 motors controlled by one joystick (Read 33584 times) previous topic - next topic
HazardsMind
Why do this?
Quote
servoVal3 = map(servoVal3, 0, 1023,1000, 1750);    // scale it to use it with the servo (result  between 0 and 180)
servoVal4 = map(servoVal4, 0, 1023, 1250, 1750);     // scale it to use it with the servo (result between 70 and 180)
servoVal1 = map(servoVal1, 0, 1023,1000, 1750);     // scale it to use it with the servo (result  between 0 and 180)
servoVal2 = map(servoVal2, 0, 1023, 1250, 1750);     // scale it to use it with the servo (result between 70 and 180)
Don't you want to get values between 0 - 90, and 90 - 180? You need to use IF statements like how I have done. If you don't isolate the values, and use them when you need them, you have problems controlling the robot.
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
AWOL
Quote
No, the "write" method interprets values outside the normal range of "angles" as pulse lengths expressed in microseconds.
Those mapping ranges look OK to me.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
zoomkat
Quote
i managed to get the 2 motors to make zero point turns, however i now cant get any headway into running at the same time to go forwards and backwards. any ideas/ help would be massively appreciated.
I'd first make two separate pieces of code specific to each pot (forward/reverse pot and turn pot). Get each working to do its specific function, then work on ways to integrate the two working code sections into single code.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
PaulS
Code: [Select]
    // Display Joystick values using the serial monitor
    outputJoystick();
    servoVal3 = analogRead(joyV);
    servoVal4 = analogRead(joyV);
I still don't understand this code. Write some data to the serial port. Then, get the data to be written. Isn't the horse on the wrong end of the cart?
GBissell
This is the problem, I cannot find for the life of me a statement or a string of statements that would allow both Val 3 and Val 4 to equal analogRead(joyV) while keeping the map functions different, is there anything that I am missing? Or would it be better to go with tank controls instead of arcade (I only want to do this if it is impossible), again any help would be readily accepted and deeply appreciated.
HazardsMind
I showed you how to do it.
Quote
int DRV2 = map(z, -15, 0, 255, 0); range -15 to 0 => reverse
int DRV1 = map(z, 0, 15, 0, 255); range 0 to 15 => forward
int STRL = map(y, -10, 0, 255, 0); left
int STRR = map(y, 0, 10, 0, 255); right
Yours should be,
Code: [Select]
    servoDrive = analogRead(joyV);
    servoVal3 = map(servoDrive, 0, 1023,1000, 1750);     // scale it to use it with the servo (result  between 0 and 180) FORWARD
    servoVal4 = map(servoDrive, 0, 1023, 1250, 1750);     // scale it to use it with the servo (result between 70 and 180) REVERSE
// Read the horizontal joystick value  (value between 0 and 1023)
    servoTurn = analogRead(joyH);
    servoVal1 = map(servoTurn, 0, 1023,1000, 1750);     // scale it to use it with the servo (result  between 0 and 180) LEFT
    servoVal2 = map(servoTurn, 0, 1023, 1250, 1750);     // scale it to use it with the servo (result between 70 and 180) RIGHT
Again, your map values I dont think are correct. "(result between 70 and 180), (result  between 0 and 180)"
My GitHub:
zoomkat
I don't have any servos or pots setup for testing, but the below (modified knob code) might be a way to loop and trap the pot that leaves the centered position and read it in a sub loop until it returns to the centered position again, at which the main loop is reentered. Hopefully only one non centered pot at a time would be in control of the servos to prevent control conflicts. Not that familiar with looping operations.
Code: [Select]
#include <Servo.h>
Servo myservo1;  // create servo object to control a servo
int potpin1 = 0;  // analog pin used to connect the potentiometer
int val1;    // variable to read the value from the analog pin
Servo myservo2;  // create servo object to control a servo
int potpin2 = 0;  // analog pin used to connect the potentiometer
int val2;    // variable to read the value from the analog pin
  myservo1.attach(8);  // attaches the servo on pin 8 to the servo object
  myservo2.attach(9);  // attaches the servo on pin 9 to the servo object
  if ((500 < (analogRead(potpin1)) || (analogRead(potpin1)) > 523)){
    while ((500 < (analogRead(potpin1)) || (analogRead(potpin1)) > 523)){
      val1 = analogRead(potpin1);
      val1 = map(val1, 0, 1023, 0, 180);
      myservo1.write(val1);
      myservo2.write(val1);
      delay(15);
  if (500 < (analogRead(potpin2)) || (analogRead(potpin2)) > 523){
    while (500 < (analogRead(potpin2)) || (analogRead(potpin2)) > 523){
      val2 = analogRead(potpin2);
      val2 = map(val2, 0, 1023, 0, 180);
      myservo1.write(val2);
      myservo2.write(180-val2);
      delay(15);
GBissell
Code: [Select]
#include <Servo.h>
const int servo1 = 3;       // first servo
const int servo2 = 10;       // second servo
const int joyH = 3;        // L/R Parallax Thumbstick
const int joyV = 4;        // U/D Parallax Thumbstick
int servoDrive;
int servoTurn;
int servoVal1;           // variable to read the value from the analog pin
int servoVal2;
int servoVal3;
int servoVal4;
  // Servo
  myservo1.attach(servo1);  // attaches the servo
  myservo2.attach(servo2);  // attaches the servo
  // Inizialize Serial
void loop(){
    outputJoystick();
    servoVal3 = 435 + servoVal4 - servoDrive;
   myservo2.write(servoVal3);                         // sets the servo position according to the scaled value
   myservo1.write(servoVal4);
    //servoTurn = analogRead(joyH);
    //servoDrive = analogRead(joyV);
    myservo2.write(servoVal1);                         // sets the servo position according to the scaled value
    myservo1.write(servoVal2);
delay(15);                                       // waits for the servo to get there
* Display joystick values
void outputJoystick(){
    Serial.print(analogRead(joyV));
    Serial.print ("----------------");
    Serial.print(analogRead(joyH));
    Serial.println ("----------------");
this is the code i have now, it works when the two parts are separate. forwards and backwards:
Code: [Select]
#include <Servo.h>
int servoDrive;
int servoTurn;
int servoVal;
int servoVal2;
int servoVal3;
int servoVal4;
  // Servo
void loop(){
    outputJoystick();
    Serial.print ("---");
and zero point turns:
Code: [Select]
#include <Servo.h>
int servoDrive;
int servoTurn;
int servoVal2;
int servoVal3;
int servoVal4;
  // Servo
void loop(){
    outputJoystick();
for some reason (its one i cant find) whenever the 2 parts of the code are together like then one at the top, all of the code for the Forwards and backwards portion are ignored and the robot cannot move forward. is there anything in the code that makes this Occur? if not does anyone have any advice? as always any help would be appreciated and anyone that has posted so far has been of extreme help.
MrDalek
OK it took me a while to figure out how to do it for my own project and this is one of the top posts that come up when googling it, so here is how it is done.
First there is two aspects, motor distribution and speed. Normally distribution and speed is determined by x and y respectfully. However this doesn't work for us.
Instead speed is equal to the distance from the center. (which we will refer to as 0,0).
Next to get the distribution we need the angle of the point with respect to the X-axis.
Specifically: 0 degrees being X=MaxRight, Y=0; 90 degrees X=0, Y=MaxUp; 180 degrees y=0, X= maxleft; 270 degrees x=0, y=maxdown
Let +1=100% of power and -1=-100% power (ie reverse)
Then (* == degrees)
90* => +1, +1
180* => -1,+1
270* => -1,-1
360*/0* => +1,-1
Now as the points move around the circle there needs to be a transition between +1 and -1. Specifically in the first quadrant:
Quadrant one (angle <90*)
at 0* it is +1, -1
at 22.5* it is +1, -.5
at 45* it is +1,0
at 67.5 it is +1, +.5
at 90* it is +1, +1.
Now programmablly the code is
Code: [Select]
double right_dist;
double left_dist;
if(angle <= 90){
left_dist= +1;
if(angle<45.0){
right_dist= -1*((45.0-angle)/45.0);
else{
right_dist= 1*( (angle-45.0)/45.0);
else if(angle <= 180){
angle = angle - 90;
right_dist= +1;
if(angle<45.0){
left_dist= 1*((45.0-angle)/45.0);
else{
left_dist= -1*( (angle-45.0)/45.0);
else if(angle <= 270){
angle = angle - 180;
left_dist= -1;
if(angle<45.0){
right_dist= 1*((45.0-angle)/45.0);
else{
right_dist= -1*( (angle-45.0)/45.0);
else{ // if(angle <= 360){
angle = angle - 270;
right_dist= -1;
if(angle<45.0){
left_dist= -1 *((45.0-angle)/45.0);
else{
left_dist= 1*( (angle-45.0)/45.0);
                      motor_left_speed=left_dist*distance
                      motor_right_speed=right_dist*distance
RickyG86
I'm new to this but I want to achieve something similar but a little less complicated, well in my mind it is . I'm usig a single joystick and 2 motors for an underwater ROV project. Along the y axis its pretty straight foward. stick up both motors full speed fwd, stick down both motors full speed rev and everything in between. Lets call the motors M1 and M2. when i'm refering to the speed of the motors I will just say that full fwd speed is +127, 0 is off and full rev is -127.  If that should be different let me know, but for now thats burned into my mind. Ok fwd and rev are cake, turning isn't that hard either. if the joystick is all the way left then m1 is -127 and m2 is +127. if the joystick is half left then m1 is -63 and m2 is +63.
Programming this alone doesn't seem that difficult  but when i want to turn while moving forward... joystick all the way to the left and up M1 is 0 and m2 is +127
I have no Idea where to start with this but If it cant happen i can just use two sticks.
HazardsMind
It is possible to do with one stick and this post has a few solutions on it already. But if your still having trouble, post what you have already and we will see what we can do.
My GitHub:
TimCoyne
I solved this problem a few months ago with the help of a very clever member of the Arduino community...
Search for this thread:
Differential Steering using a joystick / programming question....
I hope that helps.
Tim
cr0sh
I hope that helps.
Tim
Here it is:
http://forum.arduino.cc/index.php?topic=172581.0
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
zoomkat
Quote
Quote
One potentiometer controls the left wheel, and the other controls the right.  There is currently no reverse, although by remapping the pots  to say, -10 to 245 and using an if statement that could easily be handled.
Did you actually provide for reverse?
cr0sh
Quote
I actually never understood what he was saying in that statement, either - my algorithm, IIRC, as written will automagically handle reverse (I think).
