Topic: Where I can find bootloader (.hex file) for microcontroler ATmega 32u4? (Read 10041 times) previous topic - next topic
fandrade
I did a board based on Arduino Leonardo with microcontroller 32u4. I want burn the bootloader by ISP, but I can not find the bootloader file.
Do you know where I can find this file?
Thanks a lot!
codlink
//LiNK
retrolefty
Thanks a lot!
Well in my windows XP system running IDE 1.0.4 the bootloader file named:
Caterina-Leonardo.hex
is located at:
C:\Documents and Settings\Primary Windows User\My Documents\My Programs\Arduino\arduino-1.0.4\hardware\arduino\bootloaders\caterina
Lefty
CrossRoads
Or just use the bootloader that comes with the part from Atmel?
"- Optional Boot Code Section with Independent Lock Bits
    In-System Programming by On-chip Boot Program
    True Read-While-Write Operation
    All supplied parts are preprogramed with a default USB bootloader"
BlackJester
Can the factory provided bootloader allow the ATmega32u4 to be programmed by the Arduino IDE over UBS out of the gate?  Or would I have to first put in the Leo .hex?
BlackJester
I'm trying to program over USB using FLIP (3.7.4)  I think I have the right .hex file, but I keep getting "Address out of range".  Help?
ShapeShifter
I'm not surprised - it's a difficult proposition for a bootloader to overwrite itself. You must take special care when overwriting the code that is currently running, like copying the code to RAM before running it. I'm not surprised that the bootloader takes the easy way out and simply doesn't allow it.
BlackJester
Well, I think I've got that worked out, now I've got Win7 to see it at a Leo board, but when I try to program it with the IDE, the virtual COM port is dropped.  I know this can happen with the regular Leos, but when I try to hold reset until the IDE says "uploading", the IDE just hangs.
BlackJester
FYI FLIP is an Atmel program that lets you upload .hex files over the DFU USB.  Is there a difference between the bootloader code and core?  Am I flashing the wrong one?
