Topic: How to generically pass parameters to a function. General C++ question (Read 5427 times) previous topic - next topic
vactirio
Hello,
I would like some help writing a function. The need is the following:
I have an arduino and an LCD display attached on it.
I use lcd.print function to write things on the LCD.
I need to write a function that enables or disables all writes on the LCD replacing the lcd.print depending on a "condition".
Something like that:
void my_lcd_print (?????????  txt)
 if (condition)
 lcd.print (txt);
"condition" will be a globally defined variable.
I need to pass to this function (my_lcd_print) all kind of types of arguments lcd.print accepts (int, strings etc) without casting compilation problems.
Thanks for the help!
jzuidema
Not familiar with the LCD screen, but as far as my (limited) knowledge of Arduino programming goes, its rather impossible to define an argument for a method that can take multiple or all forms. I would suggest to either store the to-be-printed material in global variables, and handle the different formats with different methods, or use an identifier in the argument to tell the method what kind of data is being printed. Perhaps with a switch case or something.
int a
string b
byte c
int identifier
void print(identifier){
   switch(identifier)
     case 1:  print a
     case 2:  print b
     case 3:  print c
I have no clue exactly what the extend of the expected data formats is, but this is a general solution which should be easily implementable
EDIT: perhaps you can set up 'condition' as to take care of selecting the correct method to handle the data. Some actual code would be useful, primarily the part which fills/selects the data for the final printing. How do you decide which variables are printed? The casting question I cannot answer, but would be useful if the method would simply print what you feed it...
AWOL
vactirio
Turn the problem inside-out, and just use a macro.
Can U please give me a hint on macros?
nickgammon
AWOL
#define MY_LCD_PRINT(x) do {if (condition) lcd.print (x);  } while (0)
vactirio
Thx AWOL.
will try that.....
Is there a "non compiler" way to do that? (pass arguments)?
AWOL
Macros are non-compiler - they use the preprocessor.
For a compiled, type-safe method, do as Nick suggests and use templates.
jzuidema
This seems a lot like what OP already gave, so I guess the difference is is that this macro can take any argument? (string byte int)
AWOL
A macro is simply a text-replacement mechanism, so yes, it can take any type as argument.
jzuidema
Ok thanks....Im now at a level that I can program virtually anything I want on Arduino, but it is things like this I still have to read up about. My JAVA-only background doesnt help.... ;)
nickgammon
This is how you would do it with templates:
boolean condition = true;
template <typename T> void my_lcd_print (T arg);
 if (condition)
   Serial.println (arg);
void setup ()
 Serial.begin (115200);
 my_lcd_print (42);
 my_lcd_print ("Hi there");
 my_lcd_print (12.34);
 }  // end of setup
void loop () { }
Output:
42
Hi there
12.34
I'm passing three different types there, to a single function. The "template" part makes the compiler generate one function per type.
UKHeliBob
I have not needed to use templates but they sound rather neat.
Automatic generation of an overloaded function by the compiler.
nickgammon
Yes, they're neat.
That how the STL (standard template library) does things like make lists of any type. The actual code to do a list is a templated function (or functions) so it can handle any type.
