Topic: Sending serial commands to arduino with existing shield using the RX line (Read 4742 times) previous topic - next topic
sjocorpe
Hi guys/girls
For the last few days Ive been trying to interface my Arduino with attached barcode reader shield to my computer. I'm trying to get it to activate the barcode reader remotely via the vb.net program that i have written.
I can receive the data scanned from the barcode reader plus any extra info that i want to send using Serial.write() but when i try to send data to the arduino either using my program or the serial monitor it does not receive it. It does how ever receive the data if the shield is disconnected.
Is there something that disconnects the RX line from the computer when the shield is plugged in and is there some was i can get around this in code?
Or will i have to come up with a physical system which is not a problem to do but I dont want to do this if it is not necessary.
Code waits for a Serial.available() i.e. input from the PC before starting.
Erdin
I can't find the barcode reader shield. Can you post a link to it ?
PaulS
Quote
What code does?
sjocorpe
This is a recreation of my code im currently unable to access my actual code.
Barcode Reader shield     http://arduino.com.au/Arduino-Shields-store.html
Code: [Select]
const int BeeperPin = 11;      // piezo beeper pin
byte serialin; // Serial data read in
byte linefeed=0; // for appending a linfeed so each barcode is on a new line
int Activate = 8;
void setup() // standard arduino setup initializing loop
  pinMode(BeeperPin, OUTPUT);   // initialize Beeper output
  Serial.begin(9600); // initialize the serial communication to 9600 baud
  Serial.println("Barcode Shield for Arduino v1.01"); // startup title
  Serial.println("www.arduino.com.au"); // website address
// Note that the barcode is aimed and triggered by a hardware switch
// this hardware switch has been connected to digital pin 8 to activate via code
void loop() // standard arduino loop
  if (Serial.available()) //signal from PC, problem is it does not register this due to the barcode shield. Works when the shield is disconnected
    Serial.print("No Signal");
  Serial.print("\n\r");
  Serial.flush;
  digitalWrite(Activate, LOW);  //activates the barcode scanner
  while (Serial.available()) {   // check for data from barcode scanner
    serialin = Serial.read(); // read in barcode character at 9600 baud
    Serial.write(serialin);
    delay(1); // allow 1ms delay for next barcode character to be scanned in
    linefeed = 1; // set so that whole barcode has a linefeed appended
  if (linefeed>0) { // barcode has been full received
    linefeed = 0;
    tone(BeeperPin,2500,20); // beep at 2.5kHz for 20ms
    Serial.print("\n\r"); // send out a linefeed to separate barcodes
Erdin
The RX and TX of the barcode shield are connected to the RX and TX of the board (pin 0 and 1).
In you sketch you have a mix of reading and writing to and from both the barcode shield and the serial monitor.
I think that mix is not going right.
You activate the barcode shield with pin 8, but is never deactivated.
There is also no pinMode() for pin 8, and it should be deactivated at start.
The received character is echoed back into the barcode scanner, I think you want it only to go to the serial monitor.
This would be too confusing for me. I would change the hardware.
  • You can rewire the RX and TX to other pins, and create a serial port on those pins with SoftwareSerial.
  • You can use an Arduino Leonardo. That board uses a software serial port for the USB bus (for the serial monitor on the PC) and has a normal hardware serial port on pin 0 and 1 that is not in use.
The delay of 1ms to wait for the next character is a little low.
After the Serial.flush(), you need to wait. I suggest 10ms wait.
The order for a new line is CarriageReturn-LineFeed, so it is "\r\n" and not "\n\r".
The code is going wrong.
Suppose it waits for the barcode scanner, if nothing is received, the loop() function is run from the start and that prints "No signal" to the barcode scanner.
If you want to continue with this code (please don't), make good indents and a good layout. You have already good comments. Seperate the blocks for the serial monitor and the barcode scanner very well.
Code: [Select]
// Example code, just a few pieces of code.
char buffer[40];
// --------------- RX, TX to Serial Monitor ------------------
digitalWrite(Activate, HIGH);  //activates the serial monitor
Serial.flush();
delay(10);
// --------------- RX, TX to Barcode Scanner ------------------
if( Serial.available() > 0)
  delay( 100);    // wait for all the characters to receive
  int i;
    buffer[i++] = Serial.read();
  buffer[i] = '\0';           // terminate string for safety.
Serial.print("Code : ");
Serail.println(buffer);
PaulS
Code: [Select]
Serial.flush();
Why? The Serial.print() and Serial.write() functions will automatically block until there is room in the buffer for the data that they want to add. Why wait until the buffer is empty?
There are VERY few cases where flush() does anything useful.
sjocorpe
This is the actual code that im using for this the previous was just a quick recreation i made as i did not have the code on hand.
This code has been adapted from code provided by the suppliers of the barcode scanner shield
Code: [Select]
int Activate = 8;  //Used to activate scanner programically, Active LOW
int pos = 0;
int Trigger = 10;
int ManTrig = 12;
byte Run = 0;
 pinMode(Activate,OUTPUT);
 pinMode(Trigger,INPUT);
 pinMode(ManTrig,INPUT);
 tone(BeeperPin,2500,50); // beep at 2.5kHz for 20ms
 delay(100);
 Serial.println("Barcode Shield for Arduino v1.02"); // startup title
 if (Serial.available())    // checking for input from PC
   Run = 1;
   Serial.write("Serial Signal");  //sent to PC
   serialin = Serial.read(); //clears the PC input
 else if (digitalRead(Trigger) == HIGH)
   Run = 1;
   Serial.write("Trigger Signal");  //sent to PC
 else if (digitalRead(ManTrig) == HIGH)
   Run = 1;
   Serial.write("Manual Signal");  //sent to PC
   tone(BeeperPin,2000,20); // beep at 2.5kHz for 20ms
   Run = 0;
 if (Run == 1)
   digitalWrite(Activate, LOW);   //activate scanner
   delay(2000);
   digitalWrite(Activate, HIGH);   //deactivate scanner
     Serial.write(serialin);  //sent to PC
     delay(10); // allow 1ms delay for next barcode character to be scanned in
     linefeed = 0;
Serial.write("No Signal");
PaulS
Code: [Select]
Why?
Code: [Select]
    Serial.println(F("Serial Signal"));  //sent to PC
Code: [Select]
Which is it? Is the hardware serial port being used to talk to the PC OR to talk to the barcode scanner? Both is the wrong answer.
sjocorpe
It was doing it for both, which is why I was asking if it was possible, and if there is a in code method that can be implemented to do receive from both the barcode reader and the PC.
Erdin
Yes, I wrote this:
I think you will not get out of troubles, if you share the RX and TX pins. Or you could add a multiplexer chip.
