Topic: Mega 2560 r3 and polyphonic tones (Read 814 times) previous topic - next topic
baelthazoar
Hi, I've been working on this project on and off for a few years give or take, and finally have some hardware together:
mega 2560
serLCD
SPI pots
2 analog inputs, 2 digital inputs
I want to make a device that allows user entry of parameters for a polyphonic tone player. Musical mode, key, scale, etc; then 'play' to hear polyphony. I enable my tone player array as follows:
   NotePlayer[0].begin(9);
   NotePlayer[1].begin(2);
//   NotePlayer[2].begin(6);
//   NotePlayer[3].begin(45);
(serLCD is connected to TX pin 18)
if I enable the last two, the whole thing goes dead. No LCD, no nothing. If I leave them off, it works, and I get some response from the two enabled pins. Is this the limit? I keep reading about 6 available voices and how to avoid timer conflicts; am I just hitting a wall? I ultimately want to route the audio signals to analog filters controlled by SPI potentiometers, and wonder what pitfalls await me should I ever get that far.
Code includes much kludge, I just want the voices out so I can work on the analog electronics and polish it once it sings.
TONETOY_0000
#include <SoftwareSerial.h>
#include <serLCD.h>
#include <SPI.h>
#include <Tone.h>
//spi slave select
const int slaveSelectPin = 53;
//Declare scale
//number of voices
//pin 31 is select button
int selectButton = 31;
int playButton = 30;
int PlayNote;
int numVoices = 4;
//declare tone array!
Tone NotePlayer[4];
int menuUpdate = 100;
long menuRefresh = millis();
#define scaleC 0
#define scaleC# 1
#define scaleD 2
#define scaleD# 3
#define scaleE 4
#define scaleF 5
#define scaleF# 6
#define scaleG 7
#define scaleG# 8
#define scaleA 9
#define scaleA# 10
#define scaleB 11
// Set pin to the LCD's rxPin
int pin = 18;
serLCD lcd(pin);
// main menu string 10 options
int menuOptions = 10;
int Mode = 0;
int Key = 1;
int Top = 2;
int Bottom = 3;
int Length = 4;
int Odds = 5;
int Attack = 6;
int Decay = 7;
int Sustain = 8;
int Release = 9;
char* menuString[]={"Mode ", "Key     ", "Top     ", "Bottom  ", "Length  ",
"Odds    ", "Attack  ","Decay   ","Sustain ","Release "};
//mode menu 33 modes
char* modeString[]={
   "Major       ",
   "Minor       ",
   "Adonai      ",
   "Algerian    ",
   "Altered     ",
   "Augmented   ",
   "Blues       ",
   "Chromatic   ",
   "Arabic      ",
   "Enigmatic   ",
   "HalfDim     ",
   "Bebop       ",
   "HarmMaj     ",
   "HarmMin     ",
   "Hirajoshi   ",
   "HuGypsy     ",
   "HuMinor     ",
   "Insen       ",
   "Iwato       ",
   "Locrian     ",
   "Lydian      ",
   "Hemitonic   ",
   "Mixolydian  ",
   "NeaMajor    ",
   "NeaMinor    ",
   "Octatonic   ",
   "Persian     ",
   "Phrygian    ",
   "Prometheus  ",
   "Slendro     ",
   "Tritone     ",
   "UkrDorian   ",
   "WholeTone   "
   //Keys submenu 12 keys
   char* keyString[]={"C       ", "CS       ", "D       ", "DS      ", "E      ", "F      ", "FS     ", "G      ", "GS      ", "A       ", "AS       ", "B        " };
   //main parameter holder array
   int settingsGrid[4][10] = {
     {random(33), random(12), (random(4)+4), random(4), random(1023),random(256), random(256),random(256),random(256),random(256)},
   //mode codes
   int modeCode[] = {
    2773,
    2906,
    3670,
    2937,
    3498,
    2457,
    2418,
    4095,
    3289,
    3243,
    2922,
    3449,
    2777,
    2905,
    3170,
    2875,
    2873,
    3162,
    2840,
    3434,
    2742,
    3352,
    2774,
    3413,
    3417,
    3510,
    3305,
    3290,
    2726,
    2642,
    3250,
    2869,
    2730
   //key offsets
   int keyOffset[]={0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11 };
   //NOTES
   int Notes[] = {
NOTE_B0,
NOTE_C1,
NOTE_CS1,
NOTE_D1,
NOTE_DS1,
NOTE_E1,
NOTE_F1,
NOTE_FS1,
NOTE_G1,
NOTE_GS1,
NOTE_A1,
NOTE_AS1,
NOTE_B1,
NOTE_C2,
NOTE_CS2,
NOTE_D2,
NOTE_DS2,
NOTE_E2,
NOTE_F2,
NOTE_FS2,
NOTE_G2,
NOTE_GS2,
NOTE_A2,
NOTE_AS2,
NOTE_B2,
NOTE_C3,
NOTE_CS3,
NOTE_D3,
NOTE_DS3,
NOTE_E3,
NOTE_F3,
NOTE_FS3,
NOTE_G3,
NOTE_GS3,
NOTE_A3,
NOTE_AS3,
NOTE_B3,
NOTE_C4,
NOTE_CS4,
NOTE_D4,
NOTE_DS4,
NOTE_E4,
NOTE_F4,
NOTE_FS4,
NOTE_G4,
NOTE_GS4,
NOTE_A4,
NOTE_AS4,
NOTE_B4,
NOTE_C5,
NOTE_CS5,
NOTE_D5,
NOTE_DS5,
NOTE_E5,
NOTE_F5,
NOTE_FS5,
NOTE_G5,
NOTE_GS5,
NOTE_A5,
NOTE_AS5,
NOTE_B5,
NOTE_C6,
NOTE_CS6,
NOTE_D6,
NOTE_DS6,
NOTE_E6,
NOTE_F6,
NOTE_FS6,
NOTE_G6,
NOTE_GS6,
NOTE_A6,
NOTE_AS6,
NOTE_B6,
NOTE_C7,
NOTE_CS7,
NOTE_D7,
NOTE_DS7,
NOTE_E7,
NOTE_F7,
NOTE_FS7,
NOTE_G7,
NOTE_GS7,
NOTE_A7,
NOTE_AS7,
NOTE_B7,
NOTE_C8,
NOTE_CS8,
NOTE_D8,
NOTE_DS8
   //timing stuff
   long lastTime[4] = {0,0,0,0};
  pinMode(playButton, INPUT);
  pinMode(selectButton, INPUT);
lcd.clear();
//slave select spi
  pinMode (slaveSelectPin, OUTPUT);
  // initialize SPI:
  SPI.begin();
   if( (long)( millis() - (menuRefresh)+menuUpdate ) >= 0)
lcd.setCursor(1, 1);
lcd.print("Voice");
lcd.setCursor(1, 8);
int voice = (analogRead(1)/256);
  lcd.print((voice+1));
  lcd.setCursor(2,1);
  int pointer = (analogRead(2)/103);
  lcd.print(menuString[pointer]);
if (pointer == 0)
   lcd.print(modeString[settingsGrid[voice][pointer]]);
if (pointer == 1)
   lcd.print(keyString[settingsGrid[voice][pointer]]);
if (pointer >= 2)
  lcd.print(settingsGrid[voice][pointer]);
lcd.print("      ");
//ENTER DATA
while (digitalRead(selectButton) == HIGH)
switch (pointer)
case 0:
   settingsGrid[voice][pointer] = (analogRead(2)/31.5);
     lcd.setCursor(2,6);
   break;
case 1:
settingsGrid[voice][pointer] = (analogRead(2)/86);
      lcd.setCursor(2,9);
   break;
case 2:
  settingsGrid[voice][pointer] = (analogRead(2)/128);
        lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 3:
        lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 4:
  settingsGrid[voice][pointer] = (((analogRead(2)/8)*10)+50);
        lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 5:
settingsGrid[voice][pointer] = (analogRead(2)/4);
       lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 6:
      lcd.setCursor(2,9);
      lcd.print("   ");
break;
case 7:
       lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 8:
       lcd.setCursor(2,9);
  lcd.print("   ");
  case 9:
       lcd.setCursor(2,9);
  lcd.print("   ");
//NOTE SELECT, PLAY, ADSR LOOP?
while (digitalRead(playButton) == HIGH)
{for (int CurrentVoice = 0; CurrentVoice <= numVoices; CurrentVoice++)
if( (long)( millis() - (lastTime[CurrentVoice])+settingsGrid[CurrentVoice][Length] ) >= 0)
if (random(256) > settingsGrid[CurrentVoice][Length])
int ModeSig = settingsGrid[CurrentVoice][Mode];
  int SelectNote = random ((((settingsGrid[CurrentVoice][Top])-(settingsGrid[CurrentVoice][Bottom]))*12));
  if ((bitRead(settingsGrid[CurrentVoice][Mode], SelectNote)) ==1)
   PlayNote = (SelectNote + settingsGrid[CurrentVoice][Key] + settingsGrid[CurrentVoice][Bottom]);
  if (PlayNote > (((settingsGrid[CurrentVoice][Top])-(settingsGrid[CurrentVoice][Bottom]))*12))
    PlayNote = PlayNote - (((settingsGrid[CurrentVoice][Top])-(settingsGrid[CurrentVoice][Bottom]))*12);
//   lcd.setCursor(1,1);
//   lcd.print(PlayNote);
//NotePlayer[CurrentVoice].stop();
NotePlayer[CurrentVoice].play(Notes[PlayNote], settingsGrid[CurrentVoice][Length] );
baelthazoar
Hokay,
I moved the initialization of the noteplayers into the main loop and now it doesn't lock up with all of them enabled,
...but I get no tone. Maybe I need to make an LED pin to show me how far it's getting in the loop.
//INITIALIZE VOX
if (active == false)
   active = true;
TONETOY_0000
#include <serLCD.h>
#include <SPI.h>
#include <Tone.h>
//spi slave select
//Declare scale
//number of voices
int PlayNote;
int numVoices = 4;
Tone NotePlayer[4];
//noteplayers on/off
boolean active = false;
#define scaleC 0
#define scaleC# 1
#define scaleD 2
#define scaleD# 3
#define scaleE 4
#define scaleF 5
#define scaleF# 6
#define scaleG 7
#define scaleG# 8
#define scaleA 9
#define scaleA# 10
#define scaleB 11
int pin = 18;
serLCD lcd(pin);
int Mode = 0;
int Key = 1;
int Top = 2;
int Bottom = 3;
int Length = 4;
int Odds = 5;
int Attack = 6;
int Decay = 7;
int Sustain = 8;
int Release = 9;
   "Major       ",
   "Minor       ",
   "Adonai      ",
   "Algerian    ",
   "Altered     ",
   "Augmented   ",
   "Blues       ",
   "Chromatic   ",
   "Arabic      ",
   "Enigmatic   ",
   "HalfDim     ",
   "Bebop       ",
   "HarmMaj     ",
   "HarmMin     ",
   "Hirajoshi   ",
   "HuGypsy     ",
   "HuMinor     ",
   "Insen       ",
   "Iwato       ",
   "Locrian     ",
   "Lydian      ",
   "Hemitonic   ",
   "Mixolydian  ",
   "NeaMajor    ",
   "NeaMinor    ",
   "Octatonic   ",
   "Persian     ",
   "Phrygian    ",
   "Prometheus  ",
   "Slendro     ",
   "Tritone     ",
   "UkrDorian   ",
   "WholeTone   "
   //mode codes
   int modeCode[] = {
    2773,
    2906,
    3670,
    2937,
    3498,
    2457,
    2418,
    4095,
    3289,
    3243,
    2922,
    3449,
    2777,
    2905,
    3170,
    2875,
    2873,
    3162,
    2840,
    3434,
    2742,
    3352,
    2774,
    3413,
    3417,
    3510,
    3305,
    3290,
    2726,
    2642,
    3250,
    2869,
    2730
   //key offsets
   //NOTES
   int Notes[] = {
NOTE_B0,
NOTE_C1,
NOTE_CS1,
NOTE_D1,
NOTE_DS1,
NOTE_E1,
NOTE_F1,
NOTE_FS1,
NOTE_G1,
NOTE_GS1,
NOTE_A1,
NOTE_AS1,
NOTE_B1,
NOTE_C2,
NOTE_CS2,
NOTE_D2,
NOTE_DS2,
NOTE_E2,
NOTE_F2,
NOTE_FS2,
NOTE_G2,
NOTE_GS2,
NOTE_A2,
NOTE_AS2,
NOTE_B2,
NOTE_C3,
NOTE_CS3,
NOTE_D3,
NOTE_DS3,
NOTE_E3,
NOTE_F3,
NOTE_FS3,
NOTE_G3,
NOTE_GS3,
NOTE_A3,
NOTE_AS3,
NOTE_B3,
NOTE_C4,
NOTE_CS4,
NOTE_D4,
NOTE_DS4,
NOTE_E4,
NOTE_F4,
NOTE_FS4,
NOTE_G4,
NOTE_GS4,
NOTE_A4,
NOTE_AS4,
NOTE_B4,
NOTE_C5,
NOTE_CS5,
NOTE_D5,
NOTE_DS5,
NOTE_E5,
NOTE_F5,
NOTE_FS5,
NOTE_G5,
NOTE_GS5,
NOTE_A5,
NOTE_AS5,
NOTE_B5,
NOTE_C6,
NOTE_CS6,
NOTE_D6,
NOTE_DS6,
NOTE_E6,
NOTE_F6,
NOTE_FS6,
NOTE_G6,
NOTE_GS6,
NOTE_A6,
NOTE_AS6,
NOTE_B6,
NOTE_C7,
NOTE_CS7,
NOTE_D7,
NOTE_DS7,
NOTE_E7,
NOTE_F7,
NOTE_FS7,
NOTE_G7,
NOTE_GS7,
NOTE_A7,
NOTE_AS7,
NOTE_B7,
NOTE_C8,
NOTE_CS8,
NOTE_D8,
NOTE_DS8
   //timing stuff
lcd.clear();
//slave select spi
  // initialize SPI:
  SPI.begin();
lcd.print("Voice");
  lcd.setCursor(2,1);
if (pointer == 0)
if (pointer == 1)
if (pointer >= 2)
lcd.print("      ");
//ENTER DATA
switch (pointer)
case 0:
     lcd.setCursor(2,6);
   break;
case 1:
      lcd.setCursor(2,9);
   break;
case 2:
        lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 3:
        lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 4:
        lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 5:
       lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 6:
      lcd.setCursor(2,9);
      lcd.print("   ");
break;
case 7:
       lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 8:
       lcd.setCursor(2,9);
  lcd.print("   ");
  case 9:
       lcd.setCursor(2,9);
  lcd.print("   ");
//NOTE SELECT, INITIALIZE PLAY, ADSR LOOP?
//INITIALIZE VOX
   active = true;
if( (long)( millis() - (lastTime[CurrentVoice])+settingsGrid[CurrentVoice][Length] ) <= 0)
baelthazoar
Got it working (at least a buzzer buzzes in the output pins and the debugging LED says all good) after I cleaned up the dogpile of code:
there's still a debugging LED in there as I have not fired up the SPI pots yet.
//tonetoy r0001
#include <serLCD.h>
#include <SPI.h>
#include <Tone.h>
//________________________________________________pins!
  //spi slave select
const int selectButton = 31;
const int playButton = 30;
int pin = 18;
serLCD lcd(pin);
int blinker = 40;
//_________________________________________________timing stuff
//last time note played
//__________________________________________________noteplayer stuff
int voice;
int numVoices = 4;
Tone NotePlayer[4];
int PlayNote;
#define scaleC 0
#define scaleC# 1
#define scaleD 2
#define scaleD# 3
#define scaleE 4
#define scaleF 5
#define scaleF# 6
#define scaleG 7
#define scaleG# 8
#define scaleA 9
#define scaleA# 10
#define scaleB 11
//Scale bitmasks
   int modeCode[] = {
    2773, 2906, 3670, 2937, 3498, 2457, 2418, 4095, 3289, 3243, 2922, 3449, 2777, 2905, 3170, 2875,
    2873, 3162, 2840, 3434, 2742, 3352, 2774, 3413, 3417, 3510, 3305, 3290, 2726, 2642, 3250, 2869, 2730
      //key offsets
   //notes
    //NOTES
   int Notes[] = {
NOTE_B0, NOTE_C1, NOTE_CS1, NOTE_D1, NOTE_DS1, NOTE_E1, NOTE_F1, NOTE_FS1,
NOTE_G1, NOTE_GS1, NOTE_A1, NOTE_AS1, NOTE_B1, NOTE_C2, NOTE_CS2, NOTE_D2, NOTE_DS2,
NOTE_E2, NOTE_F2, NOTE_FS2, NOTE_G2, NOTE_GS2, NOTE_A2, NOTE_AS2, NOTE_B2, NOTE_C3,
NOTE_CS3, NOTE_D3, NOTE_DS3, NOTE_E3, NOTE_F3, NOTE_FS3, NOTE_G3, NOTE_GS3, NOTE_A3,
NOTE_AS3, NOTE_B3, NOTE_C4, NOTE_CS4, NOTE_D4, NOTE_DS4, NOTE_E4, NOTE_F4, NOTE_FS4,
NOTE_G4, NOTE_GS4, NOTE_A4, NOTE_AS4, NOTE_B4, NOTE_C5, NOTE_CS5, NOTE_D5, NOTE_DS5,
NOTE_E5, NOTE_F5, NOTE_FS5, NOTE_G5, NOTE_GS5, NOTE_A5, NOTE_AS5, NOTE_B5, NOTE_C6,
NOTE_CS6, NOTE_D6, NOTE_DS6, NOTE_E6, NOTE_F6, NOTE_FS6, NOTE_G6, NOTE_GS6, NOTE_A6,
NOTE_AS6, NOTE_B6, NOTE_C7, NOTE_CS7, NOTE_D7, NOTE_DS7, NOTE_E7, NOTE_F7, NOTE_FS7,
NOTE_G7, NOTE_GS7, NOTE_A7, NOTE_AS7, NOTE_B7, NOTE_C8, NOTE_CS8, NOTE_D8, NOTE_DS8
//______________________________________________________________menus and parameters
int pointer;
int Mode = 0;
int Key = 1;
int Top = 2;
int Bottom = 3;
int Length = 4;
int Odds = 5;
int Attack = 6;
int Decay = 7;
int Sustain = 8;
int Release = 9;
//main menu
char* modeString[]={"Major       ", "Minor       ", "Adonai      ", "Algerian    ",
"Altered     ", "Augmented   ", "Blues       ", "Chromatic   ", "Arabic      ", "Enigmatic   ",
"HalfDim     ", "Bebop       ", "HarmMaj     ", "HarmMin     ", "Hirajoshi   ", "HuGypsy     ",
"HuMinor     ", "Insen       ", "Iwato       ", "Locrian     ", "Lydian      ", "Hemitonic   ",
"Mixolydian  ", "NeaMajor    ", "NeaMinor    ", "Octatonic   ", "Persian     ", "Phrygian    ",
"Prometheus  ", "Slendro     ", "Tritone     ", "UkrDorian   ", "WholeTone   "};
   char* keyString[]={
    //random start values
   //_________________________________________________________SETUP
  //signal LED
pinMode(40, OUTPUT);
lcd.clear();
//slave select spi
  // initialize SPI:
  SPI.begin();
//__________________________________________________________LOOP
digitalWrite(blinker, LOW);
   //menu refresh delay timer
   //LCD commands
lcd.print("Voice");
  //Line 2 of display
lcd.setCursor(2,1);
// Menu scrolling
if (pointer == 0)
if (pointer == 1)
if (pointer >= 2)
lcd.print("      ");
//ENTER DATA
switch (pointer)
case 0:
     lcd.setCursor(2,6);
   break;
  case 1:
      lcd.setCursor(2,9);
   break;
case 2:
        lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 3:
        lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 4:
        lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 5:
       lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 6:
      lcd.setCursor(2,9);
      lcd.print("   ");
break;
case 7:
       lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 8:
       lcd.setCursor(2,9);
  lcd.print("   ");
  case 9:
       lcd.setCursor(2,9);
  lcd.print("   ");
// digitalWrite(blinker, HIGH);
//INITIALIZE VOX
   active = true;
      //digitalWrite(blinker, HIGH);
      lastTime[CurrentVoice] = millis();
if (random(256) > settingsGrid[CurrentVoice][Odds])
baelthazoar
although it only seems to make farting noise sounds, nothing I would call a tone.
baelthazoar
FWIW this I think works insofar as tones on all 4 channels... need to figure out how to do the 'rests' based on odds.
etoy r0001
#include <serLCD.h>
#include <SPI.h>
#include <Tone.h>
  //spi slave select
int pin = 18;
serLCD lcd(pin);
int blinker = 40;
int voice;
int numVoices = 4;
Tone NotePlayer[4];
int PlayNote;
#define scaleC 0
#define scaleC# 1
#define scaleD 2
#define scaleD# 3
#define scaleE 4
#define scaleF 5
#define scaleF# 6
#define scaleG 7
#define scaleG# 8
#define scaleA 9
#define scaleA# 10
#define scaleB 11
//Scale bitmasks
   int modeCode[] = {
      //key offsets
   //notes
    //NOTES
   int Notes[] = {
int pointer;
int Mode = 0;
int Key = 1;
int Top = 2;
int Bottom = 3;
int Length = 4;
int Odds = 5;
int Attack = 6;
int Decay = 7;
int Sustain = 8;
int Release = 9;
//main menu
   char* keyString[]={
randomSeed(analogRead(0));
  //signal LED
lcd.clear();
//slave select spi
  // initialize SPI:
  SPI.begin();
   //LCD commands
lcd.print("Voice");
  //Line 2 of display
lcd.setCursor(2,1);
// Menu scrolling
if (pointer == 0)
if (pointer == 1)
if (pointer >= 2)
lcd.print("      ");
//ENTER DATA
switch (pointer)
case 0:
     lcd.setCursor(2,6);
   break;
  case 1:
      lcd.setCursor(2,9);
   break;
case 2:
        lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 3:
        lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 4:
        lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 5:
       lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 6:
      lcd.setCursor(2,9);
      lcd.print("   ");
break;
case 7:
       lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 8:
       lcd.setCursor(2,9);
  lcd.print("   ");
  case 9:
       lcd.setCursor(2,9);
  lcd.print("   ");
//INITIALIZE VOX
   NotePlayer[0].begin(7);
   NotePlayer[1].begin(6);
   NotePlayer[2].begin(5);
   NotePlayer[3].begin(4);
   active = true;
    if (NotePlayer[CurrentVoice].isPlaying() == false)
  if ((bitRead(modeCode[ModeSig], SelectNote)) ==1)
  NotePlayer[CurrentVoice].play(Notes[PlayNote], settingsGrid[CurrentVoice][Length]);
baelthazoar
No Love, huh?
Anyway, still chasing my tail trying to do polyphony on this thing. Been mashing around trying to get it two work when I should have realized I can only get 2 of the claimed 6 tone functions to work. I stripped the notepicking part and subbed in an LED for troubleshooting, and that's when I realized how dead my loop was.
   //NotePlayer[2].begin(5);
   //NotePlayer[3].begin(4);
This works (in setup()),
this kills it dead:
Any suggestions on getting this to work? I thought by using 4 tones I'd be avoiding timer functions.
//tonetoy r0001
#include <serLCD.h>
#include <SPI.h>
#include <Tone.h>
  //spi slave select
int pin = 18;
serLCD lcd(pin);
int blinker = 40;
   unsigned long lastTime[4] = {0,0,0,0};
   int blinkerState = LOW;
int voice;
int numVoices = 4;
Tone NotePlayer[4];
int PlayNote;
#define scaleC 0
#define scaleC# 1
#define scaleD 2
#define scaleD# 3
#define scaleE 4
#define scaleF 5
#define scaleF# 6
#define scaleG 7
#define scaleG# 8
#define scaleA 9
#define scaleA# 10
#define scaleB 11
//Scale bitmasks
   int modeCode[] = {
      //key offsets
   //notes
    //NOTES
   int Notes[] = {
int pointer;
int Mode = 0;
int Key = 1;
int Top = 2;
int Bottom = 3;
int Length = 4;
int Odds = 5;
int Attack = 6;
int Decay = 7;
int Sustain = 8;
int Release = 9;
//main menu
   char* keyString[]={
   long settingsGrid[4][10] = {
  //signal LED
lcd.clear();
//slave select spi
  // initialize SPI:
  SPI.begin();
   //LCD commands
lcd.print("Voice");
  //Line 2 of display
lcd.setCursor(2,1);
// Menu scrolling
if (pointer == 0)
if (pointer == 1)
if (pointer >= 2)
lcd.print("      ");
//ENTER DATA
switch (pointer)
case 0:
     lcd.setCursor(2,6);
   break;
  case 1:
      lcd.setCursor(2,9);
   break;
case 2:
        lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 3:
        lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 4:
        lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 5:
       lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 6:
      lcd.setCursor(2,9);
      lcd.print("   ");
break;
case 7:
       lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 8:
       lcd.setCursor(2,9);
  lcd.print("   ");
  case 9:
       lcd.setCursor(2,9);
  lcd.print("   ");
if (active == true)
unsigned long currentMillis=millis();
if ((currentMillis - lastTime[3]) >=  (settingsGrid[3][Length]))
lastTime[3]=currentMillis;
//if ((millis() >=  long (lastTime[CurrentVoice] + settingsGrid[CurrentVoice][Length])))
   if (blinkerState == LOW)
      blinkerState = HIGH;
      blinkerState = LOW;
    digitalWrite(blinker, blinkerState);
baelthazoar
This one finally works on all 4 channels, but for the life of me I can't get past using this is a trigger:
    //if (millis()>=(lastTime[CurrentVoice]+(settingsGrid[CurrentVoice][Length])))
I'd like to is the bottom line so I can work blank spaces based on settingsGrid[CurrentVoice][Length]
//tonetoy r0001
#include <serLCD.h>
#include <SPI.h>
#include <Tone.h>
  //spi slave select
int pin = 18;
serLCD lcd(pin);
int blinker = 40;
int voice;
int numVoices = 4;
Tone NotePlayer[4];
int PlayNote;
#define scaleC 0
#define scaleC# 1
#define scaleD 2
#define scaleD# 3
#define scaleE 4
#define scaleF 5
#define scaleF# 6
#define scaleG 7
#define scaleG# 8
#define scaleA 9
#define scaleA# 10
#define scaleB 11
//Scale bitmasks
   int modeCode[] = {
      //key offsets
   //notes
    //NOTES
   int Notes[] = {
int pointer;
int Mode = 0;
int Key = 1;
int Top = 2;
int Bottom = 3;
int Length = 4;
int Odds = 5;
int Attack = 6;
int Decay = 7;
int Sustain = 8;
int Release = 9;
//main menu
   char* keyString[]={
  //signal LED
lcd.clear();
//slave select spi
  // initialize SPI:
  SPI.begin();
   //LCD commands
lcd.print("Voice");
  //Line 2 of display
lcd.setCursor(2,1);
// Menu scrolling
if (pointer == 0)
if (pointer == 1)
if (pointer >= 2)
lcd.print("      ");
//ENTER DATA
switch (pointer)
case 0:
     lcd.setCursor(2,6);
   break;
  case 1:
      lcd.setCursor(2,9);
   break;
case 2:
        lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 3:
        lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 4:
        lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 5:
       lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 6:
      lcd.setCursor(2,9);
      lcd.print("   ");
break;
case 7:
       lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 8:
       lcd.setCursor(2,9);
  lcd.print("   ");
  case 9:
       lcd.setCursor(2,9);
  lcd.print("   ");
{ //INITIALIZE VOX
active = true;
//lastTime[CurrentVoice] = millis();
   PlayNote = (SelectNote + settingsGrid[CurrentVoice][Key] + (settingsGrid[CurrentVoice][Bottom]*12));
baelthazoar
I got it. It works just fine if I only enable 2 voices.
If anyone can help me get the 4 I was hoping for out of this project I would be grateful and would certainly share all the filter specs once I get it going.
code, fwiw
//tonetoy r0001
#include <serLCD.h>
#include <SPI.h>
#include <Tone.h>
  //spi slave select
int pin = 18;
serLCD lcd(pin);
int blinker = 40;
int voice;
int numVoices = 4;
Tone NotePlayer[4];
int PlayNote;
#define scaleC 0
#define scaleC# 1
#define scaleD 2
#define scaleD# 3
#define scaleE 4
#define scaleF 5
#define scaleF# 6
#define scaleG 7
#define scaleG# 8
#define scaleA 9
#define scaleA# 10
#define scaleB 11
//Scale bitmasks
   int modeCode[] = {
      //key offsets
   //notes
    //NOTES
   int Notes[] = {
int pointer;
int Mode = 0;
int Key = 1;
int Top = 2;
int Bottom = 3;
int Length = 4;
int Odds = 5;
int Attack = 6;
int Decay = 7;
int Sustain = 8;
int Release = 9;
//main menu
   char* keyString[]={
  //signal LED
lcd.clear();
//slave select spi
  // initialize SPI:
  SPI.begin();
   //LCD commands
lcd.print("Voice");
  //Line 2 of display
lcd.setCursor(2,1);
// Menu scrolling
if (pointer == 0)
if (pointer == 1)
if (pointer >= 2)
lcd.print("      ");
//ENTER DATA
switch (pointer)
case 0:
     lcd.setCursor(2,6);
   break;
  case 1:
      lcd.setCursor(2,9);
   break;
case 2:
        lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 3:
        lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 4:
        lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 5:
       lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 6:
      lcd.setCursor(2,9);
      lcd.print("   ");
break;
case 7:
       lcd.setCursor(2,9);
  lcd.print("   ");
break;
case 8:
       lcd.setCursor(2,9);
  lcd.print("   ");
  case 9:
       lcd.setCursor(2,9);
  lcd.print("   ");
{ //INITIALIZE VOX
active = true;
    //if (NotePlayer[CurrentVoice].isPlaying() == false)
if (random(256)<=settingsGrid[CurrentVoice][Odds])
  NotePlayer[CurrentVoice].play(Notes[PlayNote]);
  lastTime[CurrentVoice]=millis();
