Topic: print from flash memory broken on DUE? (Read 4978 times) previous topic - next topic
zachtos
error: 'PSTR' was not declared in this scope
example:
  Serial.print(F("FAIL"));  //print the word 'FAIL' from flash memory, not RAM
vs.
  Serial.print("FAIL"); //print the word 'FAIL' from RAM, but this uses RAM very fast
Why am I getting this compile error in Aruino 1.52?  Do I need to add another library to be able to simply print from flash on the serial ports or using the LCD library?
IR Combat laser tag developer/inventor
zachtos
#1
Apr 04, 2013, 02:54 am Last Edit: Apr 04, 2013, 03:02 am by zachtos Reason: 1
http://arduino.cc/forum/index.php/topic,153761.0.html
I can't tell, but is the above thread a solution, or work in progress?
copying this into my header fixed it for me for now.
Code: [Select]
#if defined(__SAM3X8E__)
   #define PROGMEM
   #define pgm_read_byte(x)        (*((char *)x))
//  #define pgm_read_word(x)        (*((short *)(x & 0xfffffffe)))
   #define pgm_read_word(x)        ( ((*((unsigned char *)x + 1)) << 8) + (*((unsigned char *)x)))
   #define pgm_read_byte_near(x)   (*((char *)x))
   #define pgm_read_byte_far(x)    (*((char *)x))
//  #define pgm_read_word_near(x)   (*((short *)(x & 0xfffffffe))
//  #define pgm_read_word_far(x)    (*((short *)(x & 0xfffffffe)))
   #define pgm_read_word_near(x)   ( ((*((unsigned char *)x + 1)) << 8) + (*((unsigned char *)x)))
   #define pgm_read_word_far(x)    ( ((*((unsigned char *)x + 1)) << 8) + (*((unsigned char *)x))))
   #define PSTR(x)  x
 #if defined F
   #undef F
 #endif
 #define F(X) (X)
#endif
OutOfLine
cmaglie has done this already:
see https://github.com/arduino/Arduino/issues/1317
If you manage to run the version from github it should work,
*IF* you manage...
  (as I still don't)
Markus_L811
*IF* you manage...
  (as I still don't)
A howto to build an IDE from the git files is there
http://code.google.com/p/arduino/wiki/BuildingArduino
graynomad
Are you sure
Uses RAM on the Due. I would have thought on the ARM architecture constants are kept in flash anyway and the P macro is redundant.
_____
Rob
Rob Gray aka the GRAYnomad www.robgray.com
zachtos
Are you sure
_____
Rob
I'm pretty sure, unless they changed it in the last few versions.  My game has a lot of text and the RAM function I run will show FREE RAM go up alot when converting to flash memory storage.
Code: [Select]
int freeRam(void)
  extern int  __bss_end;
  extern int  *__brkval;
  int free_memory;
  if((int)__brkval == 0) {
    free_memory = ((int)&free_memory) - ((int)&__bss_end);
  else {
    free_memory = ((int)&free_memory) - ((int)__brkval);
  return free_memory;
/////called in the upgrade code/regen function like this
void RAM()
  clearLCD();
  mySerial.print(F("Free RAM: ")); //debug code
  mySerial.print(freeRam());   //debug code
OutOfLine
... and the RAM function I run will show FREE RAM go up alot when converting to flash memory storage.
Code: [Select]
int freeRam(void)
  int free_memory;
  else {
  return free_memory;
Had tried that a while ago. I could not figure out how to get __bss_end and __brkval defined...
zachtos
I just used the RAM(); function in my main loop to print the FREE ram to screen, I did not change anything else, copy paste was it.  I think that came from the WaveHC library files.
stimmer
Well I guess one way of testing it is to try printing a string over 96K long...
Code: [Select]
Serial.begin(1200);
  Serial.print(
"\n"
"ACT I\n"
"SCENE I. A desert place.\n"
"\n"
"    Thunder and lightning. Enter three Witches \n"
"\n"
"First Witch\n"
"\n"
"    When shall we three meet again\n"
"    In thunder, lightning, or in rain?\n"
"\n"
"Second Witch\n"
"\n"
"    When the hurlyburly's done,\n"
"    When the battle's lost and won.\n"
"\n"
"Third Witch\n"
"\n"
"    That will be ere the set of sun.\n"
"\n"
... over 100K later....
"MALCOLM\n"
"\n"
"    We shall not spend a large expense of time\n"
"    Before we reckon with your several loves,\n"
"    And make us even with you. My thanes and kinsmen,\n"
"    Henceforth be earls, the first that ever Scotland\n"
"    In such an honour named. What's more to do,\n"
"    Which would be planted newly with the time,\n"
"    As calling home our exiled friends abroad\n"
"    That fled the snares of watchful tyranny;\n"
"    Producing forth the cruel ministers\n"
"    Of this dead butcher and his fiend-like queen,\n"
"    Who, as 'tis thought, by self and violent hands\n"
"    Took off her life; this, and what needful else\n"
"    That calls upon us, by the grace of Grace,\n"
"    We will perform in measure, time and place:\n"
"    So, thanks to all at once and to each one,\n"
"    Whom we invite to see us crown'd at Scone.\n"
"\n"
"    Flourish. Exeunt\n"
Believe it or not, it works  :smiley-mr-green:
Due VGA library - http://arduino.cc/forum/index.php/topic,150517.0.html
