Topic: Port change from 80 to something else (Read 9465 times) previous topic - next topic
SurferTim
So you mean these ports would work in place of port 80 ?
Yes. Some ISPs block port 80 requests to residential ip addresses. Mine does. To get around that block, one of those ips will normally work. Insure you allow that port through your firewall.
Nishant_Sood
I used port 8080 still the browser can;t link to it
"Real Men can Accomplish  Anything"
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
Nishant_Sood
#17
Apr 05, 2013, 03:46 pm Last Edit: Apr 05, 2013, 03:48 pm by NI$HANT Reason: 1
internal network however works fine!
ANd! I just disabled by routers firewall
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
SurferTim
..and you port forwarded that port to your private localnet ip? If it still doesn't work, it may be your DSL router doing the block.
Nishant_Sood
But that what could be possible issue here? Can you outline which elements to check, I tried disabling the Firewall and restarting the router to no avail!
Should I provide you with the screenshot of my routers option/functions it supports so you may try to underline some options?
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
zoomkat
if you are trying to reach your arduino from outside your dlink router, you will need to use your wan ip address (or a service like no-ip.com), and have the dlink port forward the outside request to the lan ip address of your arduino.
Nishant_Sood
I know this already and im doing it/trying it but IM not able to access using the WAN IP, however at the same time the internal IP communication works smooth
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
zoomkat
Have you posted your code for evaluation?
zoomkat
What are your setting on the below page?
http://support.dlink.com/emulators/di524_revc/adv_virtual.html
Nishant_Sood
My code is the very same no changes WEBSERVER ethernet example that comes with the Arduino 1.0 IDE ONLY the IP address that is 192.168.0.104 + the MAC address is changed and the Server port rest is the same.
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
Nishant_Sood
Here are the settings done regarding PORT forwarding on my router "uC"  is arduino here:
http://www.flickr.com/photos/93413530@N06/8624125280/
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
Nishant_Sood
Got time to check the screenshot zoomkat?
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
zoomkat
#27
Apr 08, 2013, 06:04 am Last Edit: Apr 08, 2013, 06:11 am by zoomkat Reason: 1
I looked at the screen shot, and looks fairly straight forward to enter the lan ip address used by the arduino server.
edit: if you want to use a port other than 80, then set the public port start to something 81 and the public port end to something like 91. This should allow any outside request that are wanting to access ports 81 thru 91 to be forwarded to the arduino.
Nishant_Sood
#28
Apr 08, 2013, 08:33 am Last Edit: Apr 08, 2013, 08:42 am by NI$HANT Reason: 1
I think my DSL is screwed and I dnt know how to go about fixing that!
I used 81 start and 91 end port and used 8080 it doesn't work still
EDIT: tried an in between port namely 85 still the same
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
Nishant_Sood
Utilised the Dynamic DNS still the same problem , can;t make out what is the possible problem?
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
