Topic: Working with Case & Switches (Read 3285 times) previous topic - next topic
chipthomas
Well I changed the orginal loop to a function and then created a new loop and added the switches and case numbers to it.  Everything complies just find with no errors.  But when I upload load, the arduino gets to the end of the void setup and then stops.  It doesn't seem to get into the void loop.
I even tried adding a "default" thinking it might would use that, but it doesn't.
Any suggestions?
Chipper
I have attached the new code.
michinyon
Your program looks ridiculously complicated.
How do you actually "know"  that it never makes it into the loop() function ?
chipthomas
Well, it would get to a certin point and then stop.  I knew exactly where it was stopping at.
I later discovered that I had a "void" in the case section and that was what was making it stop.  After removing the void, it worked great!!
Now on to do the rest of the code.
