Topic: Inverse trig functions (Read 5843 times) previous topic - next topic
Jetfire
They locked this topic away in the arcives, so I'll just do this:
http://arduino.cc/forum/index.php?PHPSESSID=99fdf9fb9ed775fd5c50e3e70f03aec8&topic=41402.0
I need the <math.h> library and I can't find the .h and .ccp files.
Or if you could just tell me how to get the arc functions that would work too.
Thanks.
Jsut210
This may help http://arduino.cc/forum/index.php/topic,44229.0.html
What happens if you just try something like:
Code: [Select]
float invsin = asin(num);
codlink
#2
Apr 05, 2013, 12:37 am Last Edit: Apr 05, 2013, 12:44 am by codlink Reason: 1
He's trying to tell you that the math library is already including in the IDE.  And actually, you don't have to use a header to include it either. [ref]http://arduino.cc/en/Math/H
Here's another library if you need more complexity.
http://playground.arduino.cc/Main/ComplexMath
//LiNK
robtillaart
note that the asin() return radians
- http://www.nongnu.org/avr-libc/user-manual/group__avr__math.html -
The returned value is in the range [-pi/2, pi/2] radians. A domain error occurs for arguments not in the range [-1, +1].
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Jetfire
#4
Apr 05, 2013, 09:54 pm Last Edit: Apr 05, 2013, 10:21 pm by Jetfire Reason: 1
Ok cool
Rewrote my arcsin() as asin and that compiled fine.
Including the conversion formula for radians to degrees didn't work so well.
The value pi is apparently not included in the package.
Should I just use "3.14159265358979323846" or is there some other way?
Thanks
Jsut210
The value of Pi isn't included with math.h.  You should just do something like:
Code: [Select]
#define PI 3.14.....
Then you can just use the "PI" definition where needed.
WizenedEE
Code: [Select]
Arduino.h already defines PI
Jsut210
Code: [Select]
Even Better
robtillaart
math.h does define: - http://www.nongnu.org/avr-libc/user-manual/group__avr__math.html -
#define    M_PI   3.14159265358979323846   /* pi */
#define    M_PI_2   1.57079632679489661923   /* pi/2 */
#define    M_PI_4   0.78539816339744830962   /* pi/4 */
#define    M_1_PI   0.31830988618379067154   /* 1/pi */
#define    M_2_PI   0.63661977236758134308   /* 2/pi */
#define    M_2_SQRTPI   1.12837916709551257390   /* 2/sqrt(pi) */
unfortunately math.h does not define 180/PI and PI/180  for radians <> degrees conversion
(windows calc)
#define     M_180_PI  57,295779513082320876798154814105   /*180/pi */
#define     M_PI_180  0,01745329251994329576923690768489    /* pi/180 */
// the arduino does only support about 7 digits of float precision so the above numbers are overkill  (unless the arbitrary precision lib is used )
Rob Tillaart
Jetfire
Code: [Select]
OK
I changed pi to PI and it compiled OK
I'm waiting for hardware to test it out.
Anyone know where I can get 20-25 servos for under $100?
PaulS
Quote
20 minus 25 is -5. You could send me 5 servos and $100, and you'd have -5 servos for $100.
Jsut210
These are about the cheapest servos you can get:
http://www.ebay.com/itm/Micro-9g-Mini-RC-Servo-for-Trex-450-Futaba-Hitec-HS-55-Align-GWS-JR-Walkera-Heli-/140922521530?pt=LH_DefaultDomain_0&hash=item20cfa307ba
Yep, straight from china.  Keep in mind that you get what you pay for.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
