Topic: Wiimote Extension Library Problem (Read 728 times) previous topic - next topic
gudenau
First of all, my code:
Code: [Select]
#include <wiimote.h>
int nl = 0;
byte whammy = 0;
boolean whammyUp = true;
unsigned char data[6];
unsigned char id[6] = {0x00, 0x00, 0xA4, 0x20, 0x01, 0x03};
unsigned char cal[32]={
0x00, 0x00, 0x00, 0x00,
void timer(){
void setup(){
Serial.println("Hello world!");
data[0] = 0b00000000;
data[1] = 0b00000000;
data[2] = 0b00000000;
data[3] = 0b00000000;
data[4] = 0b00000000;
data[5] = 0b00000000;
wm_init(id, data, cal, timer);
void updateWhammy(){
if(whammyUp){
whammy++;
if(whammy >= 31){
whammyUp = false;
}else{
whammy--;
if(whammy <= 0){
whammyUp = true;
void loop(){
if(Serial.available() > 0){
updateWhammy();
Second I put the wiimote.c, wiimote.h and wm_crypto.h; from here, in Arduino\libraries\wimmote.
Third this is the error at compile:
Code: [Select]
AutoGiutar.cpp.o: In function `setup':
C:\Users\(censor)\Desktop\arduino-1.0.4/AutoGiutar.ino:38: undefined reference to `wm_init(unsigned char*, unsigned char*, unsigned char*, void (*)())'
So, the function does not seem to want to be passed as an argument, I am new to this part and I have spent a while on Google looking for the solution.
KellieFins
I'm pretty new too...
Look at AutoGiutar.cpp. Look for the setup function and see what it wants.
K
PaulS
Well, where is wm_init() defined? I see where it is called, but I don't see it defined.
michinyon
I don't understand what you mean when you say,  it doesn't like the function being passed as an argument.
I can see where you try to call the function.    I don't see anywhere that you try to pass it as an argument.
gudenau
Have you looked in the sources for the files I have included? The timer function needs to be an argument for the wm_init. I want to say it gets called when the wiimote gets new data.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
