Topic: Motor shaft sizes - do standard sizes exist? (Read 4713 times) previous topic - next topic
digimate
Just starting out using a few DC motors, and some servos, stepper motors etc.,  and I was wondering if there is any standard sizes for the motor shafts so that standard size gears/pulleys etc can be purchased off the shelf to fit.
For example, I have 3 very nice 12VDC Pittman motors from an old computer data storage device.  Their shafts measure about 4.1 or 4.2mm.  Am I going to be able to find any pulleys/gears, etc to fit them?
Related question, how do you couple mechanics to your motors usually - a flexible coupling, belt/pulley drive, direct? Do you make them yourself?   I had a suggestion from a guy who sells Lego gears and stuff, that people often use a piece of tubing, such as used for air hose in  the aquarium trade.
kf2qd
Those Pitman motors are probably 1/8inch.
There are standard motor shaft sizes, There problem is, there are many standards... Metric sizes will probably be either a whole or half millimeter and under 1/8 inch they will probably be in 1/32 inch increments (or 1/64) over 1/8 they will  generally go by 1/8ths with a couple 1/6ths thrown in (we seem to like 7/16 and 9/16)
digimate
Ah, sounds messy :) .  Sounds like you just have to adapt where you can't get the exact right size.   Thanks for the help.
MarkT
You can get gears/pulleys for a smaller shaft and drill/ream them out.   4.1mm sounds unlikely - micrometer or calliper guage is
the way to measure.
digimate
the way to measure.
They measure 4.18 to 4.2 with a digital calliper (depending on where on the shaft I put it).  Must be a weird size.
Good idea on drilling/reaming smaller sizes - thanks.
jeffmorris
Are there shaft adapters for DC motors usually used in toys so that I can use rods that are larger than motor shafts?
keeper63@cox.net
Whether you are looking for adaptors or couplers, when it comes to small sized parts in this area, you are likely to find that you will be spending a lot of money for one basic part. For instance, I just did some googling around for you for "miniature shaft couplers" and found more than a few suppliers, but all were either "call for a quote" (ie - meaning you can't afford what they want - or they want to sell you 1000 pieces), or for single units were around $25-35.00 USD.
A couple of things to look into would be shaft couplers for toys like Erector Set, Meccano, and VEX robotics - there is probably something in those you could use. You could also try to fabricate your own; you just need a small drill press, some thick-walled aluminium tubing, and a small tap/die set (plus small enough set screws). It isn't as hard as you think (but it does take patience and time).
You could also look and see what the R/C hobby world has to offer - plenty of parts and such there; maybe there are some shaft couplers or such you could use?
Another way you could adapt a motor shaft would be to take the motor shaft, measure it, and use a die to thread it; then take your larger shaft, drill it out, and take a tap to fit the threading you created on your shaft, then tap out the threads on the end of the larger shaft. Once you have that done, apply a bit of thread lock, and thread the motor shaft and the larger shaft together.
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
