Topic: Can't get nRF24L01 working (Read 16727 times) previous topic - next topic
CyberBob
Hi
I need help please. I have just bought a couple of nRF24L01 (compatable) transceivers and have installed all the various libraries that are suggested on various sites. I have tried the usual tests (Poor Mans' Scanner, amongst many others) but I still get meaningless data on the serial monitor.
I followed the pinout at http://arduino-info.wikispaces.com/Nrf24L01-Poor+Man%27s+2.4+GHz+Scanner but all I get is output like this -
K°¾*ø0p
I'm using an Uno so the wiring shouldn't be a problem, though I suspect the problem might be with the modules themselves.
Any pointers would be appreciated
Thanks
CyberBob
Sorry for putting this in the Storage section, it should have gone into Networking
Simpson_Jr
Do you, at least, get these lines on your monitor ?
"Starting Poor Man's Wireless 2.4GHz Scanner ..." and
">      1 2  3 4  5  6 7 8  9 10 11 12 13  14                     <"
If not, check the baud-rate you're using, it should be 57600 baud.
The wiring of the pins did cause some problems over here by the way.
I don't remember whether it was this scanner-sketch or another, every
channel checked showed  intensive transmissions while only a few people in my
neighbourhood use WIFI.
Some of the sketches of different nRF24L01-programmers also use
different arduino-pins for the signals CE and SS, you may have to adjust those
on your arduino or in the sketches used.
matchy
Try the library:
http://maniacbug.wordpress.com/2011/11/02/getting-started-rf24/
// nRF24L01+ Active Test
#include <SPI.h>
#include <RF24.h>
#include "printf.h"
#define RF_CS 9
#define RF_CSN 7
RF24 radio(RF_CS, RF_CSN);
printf_begin();
radio.begin();
radio.printDetails();
Positive sample output:
STATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
RX_ADDR_P0-1 = 0xe7e7e7e7e7 0xc2c2c2c2c2
RX_ADDR_P2-5 = 0xc3 0xc4 0xc5 0xc6
TX_ADDR = 0xe7e7e7e7e7
RX_PW_P0-6 = 0x00 0x00 0x00 0x00 0x00 0x00
EN_AA = 0x3f
EN_RXADDR = 0x03
RF_CH = 0x4c
RF_SETUP = 0x07
CONFIG = 0x0c
DYNPD/FEATURE = 0x00 0x00
Data Rate = 1MBPS
Model = nRF24L01+
CRC Length = 16 bits
PA Power = PA_HIGH
Negative sample output:
STATUS = 0x00 RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=0 TX_FULL=0
RX_ADDR_P0-1 = 0xe7e7e7e7e7 0xffffffffff
RX_ADDR_P2-5 = 0xc3 0xff 0xff 0xc6
EN_AA = 0x00
EN_RXADDR = 0x00
RF_CH = 0x00
RF_SETUP = 0x00
CONFIG = 0x0c
Data Rate = 1MBPS
Model = nRF24L01
CRC Length = Disabled
PA Power = PA_MIN
JohnHoward
I hope you observed the fact the nRF24L01 is a 3.3v device and powered it off the 3v3  pin!
The pingpair example is a good one to start with.  Easy to set up and get it going.
I second the other poster that the serial port speed would seem to be set wrong.  If the nRF24L01 is not working right, you'll still typically see all zeros or all ones from the .printDetails() when it is called.
The first one I ever tried to wire up, I got mixed up about which way the pins were designated vis a vis the diagram I was referring to.  Be sure you recheck that carefully.
On the plus side, I actually applied power to the wrong pins a couple times at the outset and the little buggers survived.
Maks
I dont know if you still have that problem, but when i tried the NRF modules for the first time that happened, the solution it to check the baud on serial monitor
rclymer
I'm getting a positive response but I can't get the two communicating. I am using the RF24 library and running the GettingStarted sketch. I never have a successful transfer.
My best guess is that the pipe address could be wrong, but I just dont know.
Here is the info for each sensor
RF24/examples/GettingStarted/
ROLE: Pong back
*** PRESS 'T' to begin transmitting to the other node
RX_ADDR_P0-1 = 0xf0f0f0f0e1 0xf0f0f0f0d2
TX_ADDR = 0xf0f0f0f0e1
RX_PW_P0-6 = 0x20 0x20 0x00 0x00 0x00 0x00
EN_AA = 0x3f
EN_RXADDR = 0x03
RF_CH = 0x4c
RF_SETUP = 0x07
CONFIG = 0x0f
Data Rate = 1MBPS
Model = nRF24L01+
PA Power = PA_HIGH
ROLE: Pong back
RX_ADDR_P0-1 = 0xe7e7e7e7e7 0xf0f0f0f0d2
RX_PW_P0-6 = 0x00 0x20 0x00 0x00 0x00 0x00
EN_AA = 0x3f
EN_RXADDR = 0x03
RF_CH = 0x4c
RF_SETUP = 0x07
CONFIG = 0x0f
Data Rate = 1MBPS
Model = nRF24L01+
PA Power = PA_HIGH
Any suggestions?
Nman120
hello, I seem to be having the same trouble as stated above . I recently bought 6 nrf24l01+ and have been experimenting with communication between my arduino Uno board and and Uno equivalent on a bread board. heres the transmiters information when I run the gettingStarted code
on the Uno
ROLE: Pong back
RX_ADDR_P0-1 = 0xf0f0f0f0d2 0xf0f0f0f0d2
TX_ADDR = 0xf0f0f0f0d2
EN_AA = 0x00
EN_RXADDR = 0x03
RF_CH = 0x4c
RF_SETUP = 0x07
CONFIG = 0x0f
Data Rate = 1MBPS
Model = nRF24L01+
PA Power = PA_HIGH
*** CHANGING TO TRANSMIT ROLE -- PRESS 'R' TO SWITCH BACK
Now sending 1922...ok...Failed, response timed out.
Now sending 3126...ok...Failed, response timed out.
Now sending 4328...ok...Failed, response timed out.
*** CHANGING TO RECEIVE ROLE -- PRESS 'T' TO SWITCH BACK
on the bread board
ROLE: Pong back
EN_AA = 0x3f
EN_RXADDR = 0x03
RF_CH = 0x4c
RF_SETUP = 0x07
CONFIG = 0x0f
Data Rate = 1MBPS
Model = nRF24L01+
PA Power = PA_HIGH
Now sending 3778...failed.
Now sending 5054...failed.
Now sending 6329...failed.
I don't know if this is the problem but I've noticed that the RX_ADDR_P0-1 addresses tend to change randomly without reason without changing code and when you do change the address in the code the printDeetails doesn't show any change. the weird thing is that I know they work because I had them transmitting and getting back a response so I have a fealling that I haven't fixed my wiring yet.
any input is greatly appreciated thanks.
AcmeUK
#8
Nov 23, 2013, 08:23 pm Last Edit: Nov 30, 2013, 05:34 pm by AcmeUK Reason: 1
Hi
I have the GettingStarted sketch running on 2 Nanos.
The problem I have is that the receiving node (pong node) will not work unless I first put it into TRANSMIT mode and then switch it back to receive mode.
Does this work for anyone else?
Anyone know how to fix this so that the pong node works correctly on startup?
Further Info: The pingpair sketch works fine, so why the problem with the GettingStarted sketch I know not!
erni-berni
I had the same problem and searched hours to find the reason. I was sure that the electrical connection was correct, because I got the modules running with the Mirf library.
Finally with this
I got the modules running with the RF24 library.
Who knows why ?
Thanks
Reinhard
erni-berni
you have to uncomment this section
  //if ( role == role_ping_out )
    //radio.openWritingPipe(pipes[0]);
    radio.openReadingPipe(1,pipes[1]);
  //else
    //radio.openWritingPipe(pipes[1]);
    //radio.openReadingPipe(1,pipes[0]);
to
Fujikatoma
#11
Aug 12, 2014, 08:13 am Last Edit: Aug 13, 2014, 08:53 am by Fujikatoma Reason: 1
  //else
to
I've tried this but it didn't worked.
Somone else have an idea ?
Both Arduinos gave me the positiv log
leon77
#12
Sep 04, 2014, 09:06 pm Last Edit: Sep 04, 2014, 10:02 pm by leon77 Reason: 1
 //else
to
This worked for me, thanx!  :)
And also: use a separate 3.3V power supply! I've tried to connect the nRF24L01 directly to the 3.3v outputs of my Nano's but that did not work. It's also good to add a 3.3uF capacitor from gnd to 3.3v on the module.
Leonardonline
Try the library:
#include <SPI.h>
#include <RF24.h>
#include "printf.h"
#define RF_CS 9
#define RF_CSN 7
 printf_begin();
 radio.begin();
EN_AA = 0x3f
EN_RXADDR = 0x03
RF_CH = 0x4c
RF_SETUP = 0x07
CONFIG = 0x0c
Data Rate = 1MBPS
Model = nRF24L01+
PA Power = PA_HIGH
EN_AA = 0x00
EN_RXADDR = 0x00
RF_CH = 0x00
RF_SETUP = 0x00
CONFIG = 0x0c
Data Rate = 1MBPS
Model = nRF24L01
PA Power = PA_MIN
What if I receive a negative sample output?
I know I should re-check the connection, but I re-checked so many times and looks to be correct.
Here my output
STATUS = 0xff RX_DR=1 TX_DS=1 MAX_RT=1 RX_P_NO=7 TX_FULL=1
RX_ADDR_P0-1 = 0x0000000000 0xffffffffff
RX_ADDR_P2-5 = 0xff 0xff 0x00 0x00
TX_ADDR = 0x0000000000
RX_PW_P0-6 = 0xff 0x00 0x00 0xff 0xff 0x00
EN_AA = 0xff
EN_RXADDR = 0x00
RF_CH = 0xff
RF_SETUP = 0xff
CONFIG = 0xff
DYNPD/FEATURE = 0xff 0x00
Data Rate = 1MBPS
Model = nRF24L01
PA Power = PA_MAX
(It's also difficult to copy&paste)
Any suggestions?
