Topic: How Do I Control This Display (Read 948 times) previous topic - next topic
adruinouno111
How Can I Control This Display Arduino Mega 2560.
Is There Any Libraries, What Hardware Do I Need?
Pictures Of LCD: http://sdrv.ms/17hLsiT
Thank You In Advance.
MAS3
You are posting a link to some obscure site where people have to login.
Not the best choice when seeking help.
Have a look at "blink without delay".
Did you connect the grounds ?
Je kunt hier ook in het Nederlands terecht: http://arduino.cc/forum/index.php/board,77.0.html
Tom Carpenter
#2
Apr 06, 2013, 01:01 am Last Edit: Apr 06, 2013, 01:08 am by Tom Carpenter Reason: 1
The answer is, you don't. An arduino is nowhere near fast enough to control such a display as the display has no controller built in - you have to generate the pixel clock, HSync, VSync, Data Enable, and data pins.
I tried such a thing before (different screen, but same principal) using an arduino and even with near perfect optimisation of code I could only get to 1/10th the required pixel clock frequency which is so far out of spec that the screen won't accept it.
EDIT:
Interestingly actually this is an Analog display not a digital one (FG020510A). But still, the clock rate required is far beyond the capability of an arduino.
~Tom~
