Topic: Need the void loop to run just once... (Read 9447 times) previous topic - next topic
jompaohh
Where in the sketch should i place
set case1Run = false
set case2Run = false
and how?
wildbill
// want the loop to end here and go back to listening for commands from the phone
It does.
Humour me and put this in as the first line in loop:
serialA =0;
jompaohh
in this? if (Serial.available() > 0) {serialA = Serial.read();Serial.println(serialA);}
wildbill
UKHeliBob
Or even better above
to make it easier to read
jompaohh
like this?
  serialA = 0();
  switch (serialA) {
    case 1:
      digitalWrite(unlock, HIGH);
      delay(1000);               // wait for a second
      digitalWrite(unlock, LOW);
      digitalWrite(innebelysning, HIGH);
      delay(10000);
      digitalWrite(innebelysning, LOW);
PaulS
Look at the code you had, and the code in UKHeliBob's last reply. Then get a clue-by-four and give yourself a good whack. As a newbie, you should get into the habit of putting each { on a line BY ITSELF and of putting each } on a line BY ITSELF.
You should also get into the habit of using Tools + Auto Format to fix your indenting.
Finally, while you have the clue-by-four handy. go read the sticky (again, if needed) at the top of the forum, and learn to post your code properly.
