Topic: nRF24L01 Basic Problem (Read 938 times) previous topic - next topic
CyberBob
Hi
I posted this elsewhere on the Forum and realised it should have been here.
I need help please. I have just bought a couple of nRF24L01 (compatable) transceivers and have installed all the various libraries that are suggested on various sites. I have tried the usual tests (Poor Mans' Scanner, amongst many others) but I still get meaningless data on the serial monitor.
I followed the pinout at http://arduino-info.wikispaces.com/Nrf24L01-Poor+Man%27s+2.4+GHz+Scanner but all I get is output like this -
K°¾*ø0p
I'm using an Uno so the wiring shouldn't be a problem, though I suspect the problem might be with the modules themselves.
Any pointers would be appreciated
Thanks
gerg
#1
Apr 05, 2013, 03:42 pm Last Edit: Apr 05, 2013, 04:20 pm by gerg Reason: 1
Sounds like your baud rate is not set correctly on the serial monitor. Look at the source. Find the line which has, "Serial.being(xxxx)". Set the monitor's baud rate to match the 'xxxx' number. According to the link you provided, its 57600.
If you want a scanner which is a little easier to read, check out my RF24 github fork and use the scanner there.
The fork can be found here: https://github.com/gcopeland/RF24
Example output:
Scanning all available frequencies...Scan completed.
055 (2455Mhz): 04 - ****
056 (2456Mhz): 08 - ********
057 (2457Mhz): 04 - ****
058 (2458Mhz): 07 - *******
059 (2459Mhz): 10 - **********
060 (2460Mhz): 05 - *****
061 (2461Mhz): 03 - ***
062 (2462Mhz): 06 - ******
063 (2463Mhz): 05 - *****
064 (2464Mhz): 06 - ******
065 (2465Mhz): 13 - *************
066 (2466Mhz): 08 - ********
067 (2467Mhz): 05 - *****
068 (2468Mhz): 05 - *****
069 (2469Mhz): 06 - ******
The WIFI channels break out as described http://en.wikipedia.org/wiki/List_of_WLAN_channels. My WIFI AP is on channel 11. So that should use 2457Mhz to 2467Mhz. The scanner says is seeing frequencies 2455Mhz to 2469Mhz. That's pretty dang close.
http://maniacalbits.blogspot.com
CyberBob
Hi gerg
Thanks for getting back to me. Sorry it's taken a while to respond. I'll definitely give that a try and let you know how I get on
Thanks again
SurferTim
#3
Apr 09, 2013, 11:56 am Last Edit: Apr 09, 2013, 12:10 pm by SurferTim Reason: 1
When there is only garbage on the serial port, check the baud rate.
Code: [Select]
 Serial.begin(57600);
Is this what you have set in the serial monitor?
edit: My bad. I see gerg already covered that. The coffee is just kicking in.  :)
CyberBob
Hi gerg
Yep, it was just down to the baud rate
Thanks again
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
