Topic: Switch case and software serial (Read 859 times) previous topic - next topic
beginit
Hi all,
I am trying to write a sketch that will allow me to control a few of the digital outputs on a Uno via the serial port (USB). No problem there, using single chancters and switch case for any characters after a serial event.
My issue is that one of the cases, for example if I send a ASCII g I want all the following serial characters received by the uno to be forwarded to pin 10 and 11 software serial wise. Then if I send a very specific character e.g. G it exits the loop and again allows for control of the digital pins.
I got something like this working already, and will try and post the code shortly.. (not on same computer now). The issue is I am loosing characters when I send data to the uno that do not get forwarded to the software serial port.... I think because of the while loop I have it in....
Any ideas?... thanks for the help :)
robtillaart
Many ideas, but I wait for your code ...
Rob Tillaart
beginit
Here is the code. Sorry its just cut and paste, computer is acting up so using tablet....
Thanks in advance... any help would be great :)
int SerialinByte = 0;
  // Software Serial Setup
  SoftwareSerial mySerial(10, 11); // RX, TX
  // initialize serial communication (control):
   // initialize Relay Pins:
  int Ignition = 4;
  int Battery = 5;
  mySerial.begin(38400);
  if (Serial.available() > 0) {
    int inByte = Serial.read();
    switch (inByte) {
    case 'a':
      digitalWrite(4, HIGH);
      break;
    case 'b':
      digitalWrite(5, HIGH);
      break;
    case 'A':
      digitalWrite(4, LOW);
      break;
    case 'B':
      digitalWrite(5, LOW);
      break;
   case 'c':
      VIPassing();
      break;
    default:
void VIPassing() // pass just data to the unit
   do
      SerialinByte = Serial.read();
          if (mySerial.available())
           Serial.write(mySerial.read());
         if (Serial.available())
           mySerial.write(Serial.read());
  while (SerialinByte != 33);
robtillaart
when there is only the c typed in the monitor it is read by this line first
then VIPassing()  is called
and the first thing it does is
while there is no byte in the buffer. This makes SerialInByte -1, which is not equal to 33
Rob Tillaart
PeterH
You're right that the problem is here:
   do
I suggest you get rid of the global, and do it something like this:
  char c = 0;
  while(true)
    // wait for a character to arrive
    while(Serial.available() == 0)
      // do nothing
    c = Serial.read();
    if(c == '!')
      break; // out of the enclosing while loop
      mySerial.write(c);
I only provide help via the forum - please do not contact me for private consultancy.
beginit
I am pretty sure I follow you code, my concern is that it does not address bi-directional communication, and simply forwards everything to the my serial unless its the exit clause...  am I understanding the code properly...
Thanks form the help guys :)
   do
  char c = 0;
  while(true)
      // do nothing
    c = Serial.read();
    if(c == '!')
      mySerial.write(c);
beginit
Totally understood, but my goal was to exit the main loop and enter the VIPassing loop... if only one character got lost in the transition that would be fine, but once in the loop I would expect everything to pass right ???
:)while there is no byte in the buffer. This makes SerialInByte -1, which is not equal to 33
