Topic: how to read analog value continuous with Serial.read() (Read 6357 times) previous topic - next topic
mickeleckorn
i'm not ignoring it but this not work ,program still monitoring single value same the old.
wildbill
I'm not sure what you're trying to do, but is it: read a character from serial and then keep sending the analog reading it selected?
If so, you need to shorten the first if statement so that all it does is check for serial.available and read a character if one is there.
All the rest of your code needs to run every time loop runs. As you have it, all your code is controlled by serial.avaialble. If there's no serial input, nothing else happens.
mickeleckorn
Thanks,  but after i remove the first if statement serial monitor displayed single analogvalue same the old.
const int ledPin = 13;
  pinMode(ledPin, OUTPUT);
  pinMode(9, OUTPUT);
  int sensorValue1 = analogRead(A0);
  int sensorValue2 = analogRead(A1);
  int sensorValue3 = analogRead(A2);
  int light_sensitivity = 500;
  int incomingByte;
    // read the oldest byte in the serial buffer:
    incomingByte = Serial.read();
  switch (incomingByte) {
    case 'a':
       Serial.println(sensorValue1);
       break;
    case 'b':
       Serial.println(sensorValue2);
       break;
    case 'c':
       Serial.println(sensorValue3);
       break;
    case 'H':
       digitalWrite(ledPin, HIGH);
       break;
    case 'L':
       digitalWrite(ledPin, LOW);
       break;
    if (sensorValue3 < light_sensitivity)
        digitalWrite(9, HIGH);
        digitalWrite(9, LOW);
      delay(300);
wildbill
if(Serial.available())
mickeleckorn
thanks again , but this monitoring single value same the old.
  pinMode(9, OUTPUT);
  int incomingByte;
    if(Serial.available()){
    case 'a':
       break;
    case 'b':
       break;
    case 'c':
       break;
    case 'H':
       break;
    case 'L':
       break;
      delay(300);
wildbill
Can you have another go at explaining what you want it to do?
That looks like it will keep reporting one sensor value (which may vary) until you tell it to report another by sending another character.
mickeleckorn
i want my program to receive analog value from analog pin A0 A1 A2 selected by sending character in serial monitor.
AWOL
mickeleckorn
Thanks all i'm finish my code, serial monitor can read analog value continuous now.
 pinMode(9, OUTPUT);
int incomingByte;
 if (Serial.available() ) {
   case 'a':
      break;
   case 'b':
      break;
   case 'c':
      break;
   case 'H':
      break;
   case 'L':
      break;
   delay(300);
Grumpy_Mike
but this not work ,program still monitoring single value.
Have you set the serial monitor to not send any new line characters?
Select "no line ending" from the drop down at the bottom corner of the window.
