Topic: updated library UTFT version 2.1 with a CTE shield (Read 4520 times) previous topic - next topic
ageurtse
Hello,
I have altered the latest UTFT library (version 2.1) so it also run's with a CTE TFT shield.
I only altered the 16 bit mode.
you have to setup your display as follow
UTFT myGLCD(display_type,shield_type,25,26,27,28);   // Remember to change the model parameter to suit your display module!
there are 2 shield types (default_shield and CTE_shield)
the pin numbers for a CTE TFT shield are as follow (pin rs=25, wr=26, cs=27, rst=28)
in the attachement is the complete library.
It is also alone for the DUE because i don't have a Mega, but it think this could be done also easely
promacjoe
Unexpected end of archive.
Please check your file.
ageurtse
Because my uploads get corrupt i try it this way
https://mega.co.nz/#!pg5FWDxb!GXp_5TgLlTMmD5vs6o46fVbbHatGZszYGParvbVh18o
promacjoe
I was able to download the complete drivers. I tested the drivers using both the "default_shield" and  "CTE_shield" switch. I could not find any difference between the two functions, both were displayed the same, "mirrored", and is unreadable.
I am using the CTE DUE shield + CTE 7" display  "CTE70".
What is supposed to be the benefit of using one or the other switches, and how can I tell if it's working properly.
Thank you for your effort, but as of yet I cannot see any benefit to your drivers.
ageurtse
I wrote it for the CTE Shield, you have to add a driver for yout 7" tft.
that is what you have to get from the UTFT_CTE library and put it in the version i posted here.
The CTE library is version 2.0 and the last version online is 2.1
so you have to do some programming yourself.
